Supraforums.com
Go Back   Supraforums.com > Performance and General Modification Forums > MKIII (1986.5-1992)
Register FAQ Members List Calendar Mark Forums Read
Reply
Thread Tools Display Modes
Old 05-12-2004, 03:04 AM   #1
CassMori
Boost Addict
CassMori's Avatar
pink engine sticker?
I found this sticker while cleaning my 7mgte transplant engine. can anyone translate for me ('splain it to the newb)? the letter behind the tube is a "T".
thanks
CassMori is offline   Reply With Quote
Old 05-12-2004, 03:14 AM   #2
ma71supraturbo
SupraForums Member
ma71supraturbo's Avatar
appears to be a jdm engine importing sticker to me, but I can't read it..
ma71supraturbo is offline   Reply With Quote
Old 05-12-2004, 03:15 AM   #3
Joker Fuel
Knockin the rod in slopra
Joker Fuel's Avatar
it says "cooler".. but no Idea...
Joker Fuel is offline   Reply With Quote
Old 05-12-2004, 03:41 AM   #4
Thermactor
SupraForums Member
Looks like the motor came out of an MZ20 Soarer
Thermactor is offline   Reply With Quote
Old 05-12-2004, 03:49 AM   #5
Z0rn
Posts: n/a
The Kanji next to the big G means "orange".
Actually what Joker Fuel thought was "cooler" is actually "colour"
It must be some sort of manufacturing code.
I would guess the "T7M" would stand for Turbo 7M motor... 7M GTE is the Toyota serial code for that motor.
Old 05-12-2004, 08:33 AM   #6
boyer
Bay Area Supras
boyer's Avatar
I have same thing on mine, but its not pink :P its white :P
boyer is offline   Reply With Quote
Old 05-12-2004, 02:04 PM   #7
Joker Fuel
Joker Fuel's Avatar
actually.. it does say cooler in romaji it says "koo lah" colour will be "ka lah"
Old 05-12-2004, 10:04 PM   #8
CassMori
Boost Addict
CassMori's Avatar
thanks for the info, guys, i really appreciate it. using some if the info provided, this is what i was able to find out about the motor, from http://www.abautos.com.au/specs/engines.html
which is the only place i found any specs (in english, anyway) after much searching.
7M-GTEU
Specs: 2954cc EFI DOHC 24-valve 6cyl turbo
Power: 179kW @5600rpm (179 kW == 240.043hp)
Torque: 343Nm @3200rpm
Gearboxes: RWD 5-speed and 4 speed auto
Vehicles: MZ20 Series Soarer. 1990 Supra 3.0GT
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by: Mvp Motorsports
Credit Card Processing
