Supraforums.com
Go Back   Supraforums.com > Supra Specific > Exterior , Interior, and Detailing
Register FAQ Members List Calendar Mark Forums Read
Reply
Thread Tools Display Modes
Old 05-17-2005, 11:46 PM   #51
Track Addict
Probably at the track...
Track Addict's Avatar
I'm glad our mis-understanding has finally been cleared up...
What specs were you looking for regarding the ballasts? They are Hella ballasts. Let me know exactly what you're looking for so I can post it up...
Quote:
Originally Posted by Chucky Doll
Hmm, I disagree until Supdawg discloses the spec's of his ballast. The ballast that he posted look very similar to the Phillips kit (wiring too). I'm running mine of the factory wiring and have been for years.
Supdawg post the spec's of the ballast (if you have them). I'll see if I can find the info on mine. If they are similar then you should be fine without a realy.
__________________
| '93 TT/MT/HT - Sold | '97 TT - Sold | '95 Hardtop - Sold | '95 NA Auto - Sold | '95 5-Spd - Sold |
Track Addict is offline   Reply With Quote
Old 05-18-2005, 04:44 AM   #52
Track Addict
Tested out the first completed headlight this evening...
Here is an H.I.D. projector mounted on the Supra headlamp assembly:
Old 05-18-2005, 09:15 AM   #53
Ascari_2
SupraForums Member
Ascari_2's Avatar
Looks good but you need to rotate that projector cc so that it is level with the ground or you'll be blinding the hell of out oncomming traffic.
Ascari_2 is offline   Reply With Quote
Old 05-18-2005, 10:38 AM   #54
junito
Posts: n/a
Quote:
Originally Posted by Ascari_2
Let him believe that 8000k is just as bright as 4200k. But if you would've told me that you had a 4200k kit that was close to the TLs I would consider it but an 8000k kit I don't even have to see to know the outcome. Unless you're running some 55W ballast they are going to be less intence; and even if you are running a 55W ballast the road must be very blue as opposed to white.
yes i do have two ballast wit my kit.
Old 05-18-2005, 11:03 AM   #55
hawkeye
SupraForums Member
hawkeye's Avatar
Quote:
I sure hope so... but huh?
hawkeye is offline   Reply With Quote
Old 05-18-2005, 11:03 AM   #56
Ascari_2
SupraForums Member
Ascari_2's Avatar
Every HID system has ballasts...one per bulb. What I am saying is that unless you have 55W aftermarket ballasts as opposed to the standard 35W ballasts used in every normal HID system. Believe me there has been a lot of research done by many people on this subject and there is NO kit out there that will perform on par with top of the line OEM projectors. Some kits may be pretty good, but they will not equal or surpass the OEM projectors.
Old 05-18-2005, 11:38 AM   #57
Ascari_2
SupraForums Member
Ascari_2's Avatar
Look at the cut off. Make sure it's parallel to the ground. Here's an example of my cutoff. You can see it's parallel to the ground. But yes you have to rotate the projector.
Old 05-18-2005, 11:47 AM   #58
Track Addict
Gotcha...It seems a little hard now that the bolts are there. Do you think I'm going to have to re-drill the hole to lower the left side in order to make it parallel? Also, how was your wiring done? I am following this diagram:
Old 05-18-2005, 12:20 PM   #59
Ascari_2
SupraForums Member
Ascari_2's Avatar
You need to use a different diagram which is for the 9006 bulbs. They are pretty similar but the other is simpler. http://faqlight.carpassion.info/hid-...t-bi-xenon.gif this is the link to it. As far as aiming it correctly, drill the holes in the projector so you can rotate it. If you do not do that you will have a very funky looking HID setup which will be very bad for you and the people comming towards you. Having them straight is a MUST.
Also make sure to lower it as it's aiming waaaay high, but I am sure you're aware of that at the moment.
Old 05-18-2005, 02:49 PM   #60
Track Addict
Here is my finished wiring harness:
__________________
Old 05-18-2005, 03:02 PM   #61
Track Addict
I think this is worth reading:
H.I.D. Awareness
Old 05-19-2005, 01:13 AM   #62
Track Addict
Hey Chris,
Sorry bro, didn't mean to offend you. I meant it in a way where if someone winds up dis-satisfied, it's all on them. I am following your instructions on my project by the way. It was a great write up indeed!
Quote:
Originally Posted by MTR
So about the zip tie method, I agree, it's not the best way but they're mine and I can live with that. And just to clear things up, they're not "zip ties" they're "adjustible mounting brackets" alright? I have an shit ton of supra headlight guts so "if" a HID type projector happens to come into my posession, I'd really like to try my new idea. When I was doing my last one with 99yellowstang, I was holding the new projector up to the stock assembly and I'm confident that with a little bit of dremmeling I could cut out the old one, drill some mounting holes, and mount the new one in(with screws), that way the stock adjustment screws could be used.
Only thing is I would have to be careful to preserve the clear R-L aiming cylinder and screwing the two screws back into that green thing could be a sonnuvabitch, and how the projector be oriented in relation to the backing, i.e. too far in or out, but I'm sure that could be accounted for.
Old 05-19-2005, 03:00 PM   #63
TheMook
Pimpin it hard
No offense taken at all; I don't know how I would come off that way. Anyway thanks for the compliment on the writeup
TheMook is offline   Reply With Quote
Old 05-20-2005, 02:49 PM   #64
Track Addict
I've been playing around with just re-using the stock projector assembly. This is how it would look:
The H.I.D. lense seems to fit in very well:
Now I am figuring out what to do behind with the cutoff shields:
More shots of the stock assembly modified:
Old 05-20-2005, 03:09 PM   #65
TheMook
Pimpin it hard
The distance of the lense away from the bulb is important too; people modify the amount of color at the cutoff (location of the focal point relative to the reflector part) by placing washers between the bulb and its mounting hole. What I was proposing was cutting that entire metal cylinder out and mounting the entire assembly in.
Old 05-23-2005, 09:39 AM   #66
SupraTT93
Windy City
SupraTT93's Avatar
Modifying Stock Proj Housings.
I have 3 questions for you HID guys..
I have a 6000k HID P&P kit, and im very interested in this idea of retrofitting because of clarity and quality. The cut-offs are really nice. I was wondering if anyone here has modified the stock projectors so that the cut-off was ideal for a P&P kit.
Where did you get your X5 HID assemblys from, and for how much?
In my kit, my ballast blew out and i needed to get another one. I went to their website and it was $140. Is it possible to mix and match ballasts in a HID kit if the wattage is the same?
TIA
SupraTT93 is offline   Reply With Quote
Old 05-23-2005, 11:41 AM   #67
Ascari_2
SupraForums Member
Ascari_2's Avatar
It would be pretty hard to do it but it is possible to try since the shield is movable.
eBay. Make sure you're getting HID projectors and not the standard ones.
TIA
Yes but you need to make sure that the wiring will be the same.
Old 05-23-2005, 06:59 PM   #68
kevganzon
Made in Stuttgart
kevganzon's Avatar
TIA
What kind of brand are your HID's that blew???
kevganzon is offline   Reply With Quote
Old 05-24-2005, 11:23 AM   #69
SupraTT93
Windy City
SupraTT93's Avatar
I tried looking for the brand but i couldn't find the box.. The ballast looks like this.
It is a standard 35W ballast. The projectors i'll check on ebay for. This whole project got me motivated into doing this myself!
Old 05-27-2005, 04:39 PM   #70
Ascari_2
SupraForums Member
Ascari_2's Avatar
Here is someone with Tl lights...sames ones I have.
http://videos.streetfire.net/Player....9-6E6ECFAC2739
Also here's another reason why kits will never equal OEM. Look at how freaking WIIIIIIIIDE that beam is.
Old 05-31-2005, 12:21 AM   #71
NooBSupra
SupraForums Member
NooBSupra's Avatar
I was wondering if its possible to fit S2000 projectors in my 98 headlights? Anyone did this before? Hopefully its the same as the TL headlights.
__________________
93.5 TT 6sp
97 GSR Turbo
JDM Front
NooBSupra is offline   Reply With Quote
Old 05-31-2005, 07:43 AM   #72
Ascari_2
SupraForums Member
Ascari_2's Avatar
TL lights are about 50% bigger then the S2ks
Old 05-31-2005, 09:17 AM   #73
Brown Duckz
WilKillya County Sheriff
Brown Duckz's Avatar
mcculloch hid 6000k
__________________
Please pray for the Gulf Coast!
SoWal.com
RTR
Brown Duckz is offline   Reply With Quote
Old 05-31-2005, 09:45 AM   #74
Ascari_2
SupraForums Member
Ascari_2's Avatar
Can you post some down the road pics?
Old 05-31-2005, 09:46 AM   #75
Brown Duckz
I'll try and snap some tonight.....
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by: Mvp Motorsports
Credit Card Processing
