Supraforums.com
Go Back   Supraforums.com > Performance and General Modification Forums > MKIII (1986.5-1992)
Register FAQ Members List Calendar Mark Forums Read
Reply
Thread Tools Display Modes
Old 09-09-2005, 12:05 PM   #1
limequat
Dissident
limequat's Avatar
Supra Differential Interchange Guide
Why? Because I love you.
Here's a list of Toyota models that have interchangable ring and pinions with the Supra. Playing mix and match will net you any ratio you need between 2.79 and 5.44. Also it appears the MKIV N/A TORSEN could fit with some hammer work.
Please add to the list if I missed something (I'm excluding lexus at the moment. Some nissans interchange too).
limequat is offline   Reply With Quote
Old 09-09-2005, 12:08 PM   #2
figgie
backpsi is my batsignal!!
this is great.
To bad that the toyota 4x4 is not interchangeable as it is smaller than our diff. See the Toyota 4x4 post about changing diff. They have to take off material off the right side to make it fit.
figgie is offline   Reply With Quote
Old 09-09-2005, 12:37 PM   #3
limequat
Dissident
limequat's Avatar
Link?
Old 09-09-2005, 12:38 PM   #4
drjonez
boost freak
drjonez's Avatar
www.mkiiitech.com
i contend the truck diffs will fit....i think fig thinks you're referring to the diff unit when all you're referring to is the ring/pinion.
drjonez is offline   Reply With Quote
Old 09-09-2005, 01:31 PM   #5
figgie
Quote:
Originally Posted by drjonez
www.mkiiitech.com
yeah sorry about that. Thinking about the detroit locker or trutrac diffs.. my bad!!
Old 09-09-2005, 02:34 PM   #6
PbXAssassinX1524
SupraForums Member
PbXAssassinX1524's Avatar
Wow, 5.44... thats insane. I think I'll stick to me 4.30 for now
Great info tho! Downloaded
PbXAssassinX1524 is offline   Reply With Quote
Old 09-09-2005, 02:45 PM   #7
limequat
Dissident
limequat's Avatar
I don't see why the appropriate electronic lock-up diff wouldn't work. Don't see why you'd want it either
I assume most supra owners are interested in two things if any:
1) Torsen
2) Change ratios on stock LSD
We all know the torsen is available in 1JZ cars, but maybe the 2JZ Auto could be made to fit too. Personally, I'm happy with the clutch pack LSD.
Ratios are something that come up a lot, whether it's fuel economy, acceleration, or trans swaps (we can finally put to bed the myth that 6 speeds "don't fit" because of gearing. Who came up with that nonsense anyway?)
I find comfort in knowing that I could modify my stock diff for anything from a 3.5 to a 4.5 rear just by changing the ring gear! How cool is that?
What's a TrueTrac? Is it disirable over a clutchpack lsd?
Old 09-09-2005, 03:03 PM   #8
tom.supra
I need a boost :(
tom.supra's Avatar
Mmmm... 2.79:1 off the top of my head that should get you to 100kph in first gear and well over 320 top.
tom.supra is offline   Reply With Quote
Old 09-10-2005, 02:23 AM   #9
drjonez
boost freak
drjonez's Avatar
good call on the NA/auto MKIV torsen, i'll have to check it out.
truetrac = helical LSD. i have one i might try to throw in....
__________________
MKIII Technical Information Depot: www.mkiiitech.com
Old 09-10-2005, 08:53 AM   #10
flubyux2
Madd Tyte JDM yo ®
flubyux2's Avatar
for anyone who auto crosses or even takes corners at high rates of speed and has a tendancy to clip apex's, the Torsen is NOT for them. when the torsen is under load and one of the drive wheels loses contact w/ the ground, all power is sent to the unloaded wheel. the wheel spins and when it touches back down, there is a great possibility that the spider gears inside will grenade. its happened on more than one occasion to Miata Auto-crossers and FD autocrossers, and select FC auto-crossers who have swapped in the Miata/FD torsen unit.
for anyone who likes to go in a straight line, id recommend the 4-runner electronic locking diff. its like an ARB air locker, but its lighter with less complications. switches from open diff to "locked" or "Welded" diff, like a spool. no worries about worn clutch packs or any of that noise.
some say that the 4runner E-diff can drop in, id like to give'er a try at some point, as well as a 3.54 from the 4-runner too. the car would be quite the Roll-monster w/ a 3.54 and 7000rpm shift point
flubyux2 is online now   Reply With Quote
Old 09-10-2005, 10:32 AM   #11
drjonez
boost freak
drjonez's Avatar
Quote:
Originally Posted by flubyux2
for anyone who auto crosses or even takes corners at high rates of speed and has a tendancy to clip apex's, the Torsen is NOT for them. when the torsen is under load and one of the drive wheels loses contact w/ the ground, all power is sent to the unloaded wheel. the wheel spins and when it touches back down, there is a great possibility that the spider gears inside will grenade. its happened on more than one occasion to Miata Auto-crossers and FD autocrossers, and select FC auto-crossers who have swapped in the Miata/FD torsen unit...
eh, i disagree. the torsen was the best diff i've ever driven....
Old 09-10-2005, 10:51 AM   #12
51Cards
SF in my veins... sigh
51Cards's Avatar
Great stuff... now how to modify the speedo gearing for all of the above ratios?
51Cards is offline   Reply With Quote
Old 09-10-2005, 01:31 PM   #13
Robbman
SupraForums Member
Swap drive gears in the transmission...
Robbman is offline   Reply With Quote
Old 09-11-2005, 06:56 PM   #14
limequat
Dissident
limequat's Avatar
Quote:
Crap, now I have to add a new column to the spreedsheet!
Old 09-11-2005, 06:59 PM   #15
limequat
Dissident
limequat's Avatar
But you broke it autocrossing, yes?
Old 09-12-2005, 05:08 AM   #16
drjonez
boost freak
drjonez's Avatar
Quote:
i guess? it actually broke when i was just tooling around on the street on R compounds....i rolled into the throttle in 2nd gear and BAM it fragged. i don't think that killed it, i think the casing was cracked earlier and that just did it in....
Old 09-12-2005, 06:19 AM   #17
limequat
Dissident
limequat's Avatar
Eh, you're probably an extreme case anyway.
Old 09-12-2005, 06:23 AM   #18
drjonez
boost freak
drjonez's Avatar
i don't think so. the T-1 doesn't take kindly towards shock loading....i think any diff in a 3500+ lb car will see a fair amount of shock....we need to look into the MKIV NA/auto torsen....though i doubt it will fit.
__________________
Old 09-19-2005, 11:32 AM   #19
flubyux2
Madd Tyte JDM yo ®
flubyux2's Avatar
fair enough. there are plenty of cases where people havent had any issues with the torsen. for a lighter car that can pull the wheels off the ground easier than we can, it may not be the best choice as far as durablility. that would explain why people like you in the MK3's or similar weighted cars dont have the same problems as those with the lighter miata's and FD's.
i agree, a torsen is a superior diff... as long as both wheel stay on the ground at all times.
i prefer either a viscious due to the durability and smooth transition... if i want to drift, id much rather have a clutch LSD though.
and you can get speedo gears from different MK3's, that would put your speedo close to accurate with similarly geared rear ends... but if you get extreme with a 3.23 or 4.90, your SOL.
Old 09-29-2005, 10:25 PM   #20
outofstep
Senior Member
outofstep's Avatar
So anyone try changing ratios?
outofstep is offline   Reply With Quote
Old 10-16-2005, 09:30 PM   #21
outofstep
Senior Member
outofstep's Avatar
So.... am I gonna be the first person to do this?
Old 10-17-2005, 04:42 AM   #22
drjonez
boost freak
drjonez's Avatar
probably. i've got the junk sitting here, but won't be doing anything w/it for a while....
Old 10-17-2005, 01:13 PM   #23
outofstep
Senior Member
outofstep's Avatar
I've got a 3.9 and a 4.3 laying around but swaping pinions/gears in those won't do anything, just give me whatever I've got already. If I had the ring from a 3.7 I could see if I could make a 4.1. Other than that, I don't know of any other rings/pinions that would be easy to get ahold of.
I've got the spare pumpkin just laying around. Just need rings/pinions.
Old 10-17-2005, 01:21 PM   #24
drjonez
boost freak
drjonez's Avatar
just get a truck ring/pinion....
Old 10-17-2005, 01:39 PM   #25
outofstep
Senior Member
outofstep's Avatar
Is it any of the 8 inch stuff, or just the stuff listed in the PDF though? Only crap I can find on ebay is stuff for the 8 inch.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by: Mvp Motorsports
Credit Card Processing
