Supraforums.com
Go Back   Supraforums.com > Performance and General Modification Forums > MKIII (1986.5-1992) > MKIII Technical > 1JZ/2JZ Swap
Register FAQ Members List Calendar Mark Forums Read
Reply
Thread Tools Display Modes
Old 11-28-2005, 08:25 PM   #1
HamsMKIV
Your Neighborhood Pikey
HamsMKIV's Avatar
1JZ Head Info
I was on the phone with Eric (Zazzn) this evening and we were pondering 1JZ valve specs. I happen to have my head sitting on my bench so I went out to measure it. Everyone posts up what they "think" they know about 1JZ vs. 2JZ so I thought we could put this crap to bed.
Eric, I think we need to create a sticky that is an actual comparison between both the 1JZ and the 2JZ with actual specs, no myths. I have both shortblocks on engine stands so we can do this legit.
Here are the head specs:
1JZGTE
Intake Valves: 31mm
Exhaust Valves: 30mm
2JZGTE
Intake Valves: 33.6mm
Exhaust Vavles: 29mm
- Chris
__________________
Out of the game for a while.
HamsMKIV is offline   Reply With Quote
Old 11-28-2005, 08:36 PM   #2
Ckanderson
Republican
Ckanderson's Avatar
how about taking the 1jz to a flow bench?
Ckanderson is offline   Reply With Quote
Old 11-28-2005, 09:49 PM   #3
tissimo
Stock is boring :(
tissimo's Avatar
Quote:
tissimo is offline   Reply With Quote
Old 11-28-2005, 09:52 PM   #4
HamsMKIV
HamsMKIV's Avatar
Okay so who's the dickhead who gave me a -1 rating for posting up 1JZ head info? That's pretty messed up!
lol "Thanks for the 1JZ head info" and a big ole' -1 RED rating for it.... Fookers.
- Chris
__________________
Old 11-28-2005, 10:09 PM   #5
tissimo
Stock is boring :(
tissimo's Avatar
lol.. i have never got this rating thing.. i dont even know what my rating is/how to check it haha...
Interesting on the vavles though.... I wonder how the intake (manifold) flow compairs between the two.... How do the intake ports compair? seems the 1jz has a higher velocity intake to give it some low end i guess??
Old 11-28-2005, 10:09 PM   #6
RudyMTR
SupraForums Member
RudyMTR's Avatar
- Chris
Sent you a +1 to offset you -1, and great info... BTW
RudyMTR is offline   Reply With Quote
Old 11-28-2005, 10:10 PM   #7
Ckanderson
Republican
Ckanderson's Avatar
ok i +1n'd ya....
Old 11-28-2005, 10:19 PM   #8
eps
Oops, that was me. It was supposed to be a +1! Sorry.
eps is offline   Reply With Quote
Old 11-28-2005, 10:20 PM   #9
JZA70 QC
Member!
JZA70 QC's Avatar
- Chris
That's prity low! You give use good info and some idiot does this prity stupid if you ask me, it happened to me too not long ago. How can you figure out hoo did this cause I want to know hoo did it to me.
Anyways great info man thanx alote and can you check the intake port differences?
1JZ HEAD
2JZ HEAD
Great thread by the way
Quote:
Clic on your User CP
JZA70 QC is offline   Reply With Quote
Old 11-28-2005, 10:21 PM   #10
NJsupraA70
NJsupraA70's Avatar
Great info. Thanks!
NJsupraA70 is offline   Reply With Quote
Old 11-28-2005, 10:22 PM   #11
HamsMKIV
HamsMKIV's Avatar
Quote:
LOL that's funny. No worries dude, I was kidding around anyhow.
I'm a dickhead and I know it!
- Chris
__________________
Old 11-28-2005, 10:23 PM   #12
HamsMKIV
HamsMKIV's Avatar
Ok so next, like tomorrow, I'm going to compare the 1JZ and the 2JZ internals with pictures. I have stock 2JZ internals all broken down, but I need to pull the 1JZ shortblock apart to compare. I think getting the nitty-gritty specs will give us a lot of info.
- Chris
__________________
Old 11-28-2005, 10:27 PM   #13
JZA70 QC
Member!
JZA70 QC's Avatar
- Chris
Great man FINALY we'll get all the real specs and differences.
Old 11-28-2005, 10:32 PM   #14
ZaZZn
Moderator
l337 M0d3r4t0r
ZaZZn's Avatar
See the real qestion is can you run 2.6 MM over stock my gut says NO way. but it would have been a nice upgrade for the 1jz for sure to run stock 2jz valves.....
Anyways, why don't we all do our selfs a favor and give each other +1
ZaZZn is offline   Reply With Quote
Old 11-28-2005, 10:34 PM   #15
tissimo
Stock is boring :(
tissimo's Avatar
dont people put 2jz +1mm valves in 7ms.. or was that just talk.. thats 2mm???
Old 11-28-2005, 10:42 PM   #16
HamsMKIV
HamsMKIV's Avatar
I don't know... Maybe the stock sized intake valve would work out ok, but that would still be a big upgrade. I don't know if there's enough room up there to do it. I have a close up shot of the head on my other computer. I'm not sure, I'll have to ask my machinist if he thinks there's enough room to go bigger there. Either way, the +1mm shelf valve for the 2JZ would only be stock size for us. I think we'd have to go with a custom valve for the exhaust side, but that wouldn't be a big deal.
I do think it's interesting that the intake side is 2.6mm smaller.... Very interesting.
- Chris
__________________
Old 11-28-2005, 11:00 PM   #17
JZA70 QC
Member!
JZA70 QC's Avatar
Don't want to change the subject but what thickness head gasket will you use if you keep your GE pistons on your 1.5J Hams?
Old 11-28-2005, 11:05 PM   #18
HamsMKIV
HamsMKIV's Avatar
Quote:
Oh I don't have GE pistons... Have you not seen my new shortblock? I thought I posted pics of it... Oh well here it is:
I'm going to run a stock Toyota HG actually. I've gone 10.92 @138 with my MKIV on a stock shortblock and stock Toyota HG. And that was 300' short of the 1/4 running out of gear and bouncing off the rev limiter
- Chris
__________________
Old 11-28-2005, 11:15 PM   #19
JZA70 QC
Member!
JZA70 QC's Avatar
I ment 2JZ-GE pistons if you thought I ment JE pistons Sorry for the mix up,, yea I saw that thread with you new shortblock, man great project but didn't you say you wanted more compression on your 1.5J or maby I hallucinated this
Old 11-28-2005, 11:20 PM   #20
HamsMKIV
HamsMKIV's Avatar
Oh yeah, I had custom made higher compression pistons made. I want big time response because I was sick of the no-response 1JZ single. I wanted more displacement and more compression. My pistons are punched .040 over and they're 9.0:1.
- Chris
__________________
Old 11-28-2005, 11:23 PM   #21
tissimo
Stock is boring :(
tissimo's Avatar
- Chris
showoff
Old 11-28-2005, 11:25 PM   #22
HamsMKIV
HamsMKIV's Avatar
LOL you goof
Old 11-29-2005, 01:37 AM   #23
Spoolin Turbo
Spoolin Turbo's Avatar
I told you guys already that the 1JZ was +1mm over the 2JZ on the exhaust side. Keep bringin up old news.
What kinda rods you got in your new block. Look like Eagle rods.
Spoolin Turbo is offline   Reply With Quote
Old 11-29-2005, 01:59 AM   #24
perf0rmance
GT40 1.5JZ
I know this is off topic, but I'd like to know what your compression would be if you slapped a 1JZ onto a stock GTE block with a stock toyota MHG.
As for the stock 1JZ head, HAMS, could you get some pictures of the dome and compare it to the 2JZ head? I'm curious to see how they differ.
joseph
perf0rmance is offline   Reply With Quote
Old 11-29-2005, 05:58 PM   #25
GrandLordKhorne
Evil Turbo Penguin...
GrandLordKhorne's Avatar
Two questions… First of all, other than face diameter, how do the valves from a 2J compare to the 1J (length, shaft diameter, weigh, ext?)… I was also wondering how 2JZ rods compare to 1JZ rods and if anyone has ever seen aftermarket H beams for a 1JZ other than the Greddy”s??
GrandLordKhorne is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by: Mvp Motorsports
Credit Card Processing
