Supraforums.com
Go Back   Supraforums.com > General Chat Forums > Other Cars
Register FAQ Members List Calendar Mark Forums Read
Reply
Thread Tools Display Modes
Old 11-07-2006, 01:26 AM   #1
93smgturbo
SupraForums Member
93smgturbo's Avatar
3.4L 1991 Toyota MR2 5VZFE (Pictures)
I never post here but I do a lot of research on this site but I finally decided I would participate. Here is my MR2 project and since Im entering the Toyota 6 cyl. world I figured you guys might care.
Well I picked up this gem with a blown NA motor and a fairly large boo boo over the passenger rear fender. Right now I have taken the motor out and started to strip the car to get all the dents taken out, the body clean, and painted. Then the swap will begin, although I do have pretty much everything except for a bit of knowledge to complete the swap. Here's whats going into the car for phase 1.
2000 5VZ-FE w/ 67,331 miles
1999 Solara Transmission w/ 26,000 miles
Turbo Axles w/ ATS axle cages
Clutchmasters 6 puck, unsprung clutch
Stock 1MZ-FE flywheel
Custom 2.5" Exhaust
255lph Walbro Pump
LSD
Phase 2 and 3 consist of:
57mm, .70a/r turbine T4 turbo
Custom 3" exhaust
Custom Intake manifold
S2S 268/268 Camshafts
S2S Racing Valve Springs
S2S High Volume Oil Pump
Hydra Nemesis EMS
Unkown injector size (at this time)
93smgturbo is offline   Reply With Quote
Old 11-07-2006, 01:29 AM   #2
93smgturbo
SupraForums Member
93smgturbo's Avatar
I did all paint and body work all in my garage. This was my first ever attempt at both so it came out well for a first timer.
Old 11-07-2006, 01:31 AM   #3
93smgturbo
SupraForums Member
93smgturbo's Avatar
Old 11-07-2006, 01:31 AM   #4
DBZ33
SupraForums Member
Looks like alot of fun. Good Luck with your project.
DBZ33 is offline   Reply With Quote
Old 11-07-2006, 06:33 AM   #5
autoXr
AKA Muddy
autoXr's Avatar
Looks like it will be a monster when you are finished. I guess suspension is phase 4?
autoXr is offline   Reply With Quote
Old 11-07-2006, 07:13 AM   #6
Mr. Wob
Wobbiest: Three Laws Safe
Mr. Wob's Avatar
Quote:
Well that could be a hurdle
Good luck though, this could be a fun build.
Mr. Wob is offline   Reply With Quote
Old 11-07-2006, 08:11 AM   #7
94Silver
Administrator
94Silver's Avatar
Pretty awesome swap, even better that you are doing all the work.
Question what kind of compressor / gun did you used?
94Silver is offline   Reply With Quote
Old 11-07-2006, 08:47 AM   #8
cjsmuscle
The Funny Man
cjsmuscle's Avatar
Thats a hell of a way to get some knowledge on things. Congrats on the work so far.
cjsmuscle is offline   Reply With Quote
Old 11-07-2006, 09:00 AM   #9
K2_2
SupraForums Member
Quote:
What he said! Also, when you get time, any details on how you use the Solara transmission to run in the MR2? And good luck with finishing things up!
K2_2 is offline   Reply With Quote
Old 11-07-2006, 09:19 AM   #10
93smgturbo
SupraForums Member
93smgturbo's Avatar
AutoXr, Suspension is already mostly done. It has Tokico Illumina 5 way shocks, Eibach Sportline springs and Suspension Techniques sway bars. Coilovers are probably phase 4 along with some nice wheels to fit big tires under there.
94 Silver, I started out using my 26 Gallon Husky compressor and quickly found it was not up to the task of painting. I borrowed my brother in laws same 26 gallon compressor and T-fitted them together to make a 52 gallon compressor and then it did just fine. I bought a cheap $50 gun at Harbor Freight tools to lay down the primer and then use my Fenix gun to lay the good stuff down. I ended up hating the expensive gun and used the $50 gun for the whole project.
K2_2, the solara transmission actually is the same transmission as the 1993+ E153 mr2 turbo tranny with a different center section(shifter cables face the wrong way), and it has longer gear ratios. I wanted the longer gear ratios for the V6 since it wont rev quite like a 2.0 4cyl. and I'll have tons more torque. Even though the Solara tranny bolts up, you need to use the 1mzfe(3.0 camry/ES300) flywheel because it has the same crank bolt pattern as the 5vz crank but has a smaller diameter flywheel that matches the MR2 turbo clutch size perfectly. So to review I have a 5vz engine, 1mz flywheel, mr2 turbo clutch, solara tranny, mr2 turbo axles.
Thanks for the props everybody.
Old 11-07-2006, 10:19 AM   #11
KevinM
Knowledge driven
KevinM's Avatar
Cool swap, there's one running around in Portland, OR with that motor too. Don't know how popular it is, but it def can be done.
Kevin
__________________
Reworking....
KevinM is offline   Reply With Quote
Old 11-07-2006, 10:33 AM   #12
ChampCarWannaBe
SupraForums Member
This is getting posted on customtacos.com Very nice use of the S-Runner powerplant.
ChampCarWannaBe is offline   Reply With Quote
Old 11-07-2006, 10:46 AM   #13
ToSSr
SupraForums Member
ToSSr's Avatar
this is a crazy swap for these cars. there's several turbo versions of it running around too. these things get up and fly with these swaps, and they almost look factory when done right. it's astonishing how the engines sit in the bay like they were meant to be there.
i was playing with the idea of strapping a camry v6 into my mk1 for a while, but now i've decided to just turbo the 4age instead.
good luck with the project, it looks like a ton of fun.
ToSSr is offline   Reply With Quote
Old 11-07-2006, 02:27 PM   #14
Maximus Decimus Meridius
paid cash 4 my mkiv
Maximus Decimus Meridius's Avatar
so far so good.
Maximus Decimus Meridius is offline   Reply With Quote
Old 11-07-2006, 02:53 PM   #15
sks
SupraForums Member
sks's Avatar
As a former mr2 owner, Ive always wanted to take the chasis and put a 6 cylinder in it. What motor are you exactly putting in it? Could you document the costs and estimated labor value to complete the project. thanks.
sks is offline   Reply With Quote
Old 11-07-2006, 04:11 PM   #16
fusionchicken
SupraForums Member
SICK!!! this is exactly what i plan on doing in about half a year....will get an n/a 91 mr2 in about 2 weeks, drive it as beater for half a year while gathering parts, then swap a v6 on it
subscribed.
fusionchicken is offline   Reply With Quote
Old 11-07-2006, 04:36 PM   #17
KNanthrup
SupraForums Member
KNanthrup's Avatar
thats really cool. keep us updated
KNanthrup is offline   Reply With Quote
Old 11-07-2006, 06:35 PM   #18
K2_2
SupraForums Member
Hi 93smgturbo, thanks for the info. It sounds like a bit of work, but doable with the right parts. Definitely keep us updated.
Old 11-07-2006, 06:51 PM   #19
greenstreak
Lost in Dawg-land
greenstreak's Avatar
Good job so far. Keep the thread updated with progress.
greenstreak is offline   Reply With Quote
Old 11-07-2006, 07:42 PM   #20
Wreckless
MK3 kid in a MK4 world
Wreckless's Avatar
Andrew, how dare you not inflict the best picture of the set on this forum!
(actually, I don't want to see that pic again... ever... again.. )
P.S. You should brag about it being a hardtop!
Wreckless is offline   Reply With Quote
Old 11-07-2006, 08:31 PM   #21
CLNSC3
SupraForums Member
CLNSC3's Avatar
That is sweet, I have been looking around for a mr2 with a blown motor waiting for one to pop up at the right price. I think that motor would sound sick as fuck right behind your head!
CLNSC3 is offline   Reply With Quote
Old 11-07-2006, 08:39 PM   #22
GTR-33
Damn Spaniards
GTR-33's Avatar
Quote:
subscribed.
Do a 2GR. Do it.. DO IT!
GTR-33 is offline   Reply With Quote
Old 11-07-2006, 10:38 PM   #23
93smgturbo
SupraForums Member
93smgturbo's Avatar
Quote:
The 5vzfe 3.4L out of a Tacoma or 4-Runner.
If you have a turbo chassis and a good turbo transmission you can do the swap for about $3,000-$4,000.
If you have an NA chassis it will cost you about $4,000-$6,000 depending on what tranny you want to use. A 91-92 will cost you $150-$300. A 93+ will cost you about $1,000-$1,200 with axles. If you have an NA you will need tranny, axles, hubs, shifter cables, and clutch out of a turbo mr2. Im probably forgetting something else.
Im surprised nobody's recognized the color. Its RSP
Old 11-07-2006, 10:48 PM   #24
GTR-33
Damn Spaniards
GTR-33's Avatar
I did, I just didn't say anything. RSP looks good on the MR2. Does that wing have clear on it? Looks like there is some peel in the paint. I love the two tone. It would look killer on some black wheels IMO.
Old 11-07-2006, 11:15 PM   #25
JSupraman
Supraless
JSupraman's Avatar
Good luck on your project and that is some nice paint and body work you have done.
JSupraman is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by: Mvp Motorsports
Credit Card Processing
