#101 |
SupraForums Member
Man that's a hell of a nice project. I've always wanted to do this swap but have since sold my car. Are you going to run the AEM on the stock twins now or are you just going to hold onto the AEM until the twins bore you and you go single?
#102 |
95 240sx w/2JZ
im running aem with stock twins for now, but come next season i should be single with a T72 or T76
![]() Goal is about 700-750rwhp on PUMP
__________________
'95 240sx JDM 2JZ GTE - 2007 Setup "Stock Twins, Stock Injectors [440cc], Brembo GT Brakes, AEM EMS, US Spec Cams, Koyo Rad, Stage 5 Comp Clutch, Volk GT-U" -- 357 RWHP & 389.8 RWTQ @ 10PSI Coming Soon - 2009 Setup "Single Super T72, Custom Turbo Manifold, Full Fuel System, Built Head, 6 Point Cage, Carbon Hood, Carbon Trunk & More" -- RWHP & RWTQ @ PSI Coming Soon
#103 |
SupraForums Member
#104 |
SupraForums Member
240sx project from Sweden with BMW M5 3.6 turbo engine:
![]() Another one from Sweden, this one with a BMW V12: http://videos.streetfire.net/video/e...6c009d96cd.htm |
#105 |
95 240sx w/2JZ
nice
__________________
#106 |
95 240sx w/2JZ
![]() ![]() Car had a bit of a delay!! Have a coolant leak! Will be fixed tmr & the fans wired [ then its off to the shop for the last stage!]
__________________
#107 |
#108 |
95 240sx w/2JZ
LMAO no i would have to get C16 from VP or mix something with my 94 oct
since 94 is the highest!!!
__________________
#109 |
95 240sx w/2JZ
SO THE CAR HAS LEFT TODAY!!! [Just before it left]
I will have pics from the shop tmr when i head down there to see updates! ![]() ![]() ![]() ![]() Once its done it will look like a whole new car suspension needs to be tuned since its all over the place lol anyways more updates as the week goes on. I WOULD LIKE TO THANK Sasha From SG-Motorsport For taking the car today to complete the final task! [LOVE]
__________________
#110 |
95 240sx w/2JZ
updates coming soon!!!
__________________
#111 |
95 240sx w/2JZ
1 update!!
[I need to get Black Hose Couplings + a new AEM filter ]![]() ![]() ![]() Work done by Sasha From SG-Motorsport
__________________
#112 |
95 240sx w/2JZ
Speaking of updates!!!
![]() ![]() BAAHHHA cut that pipe open for the 02 BUNG ---------------------------------------- ![]() Most of it done [there is updated pics just sasha has them ]-------------- ![]() --------- ![]()
__________________
#113 |
95 240sx w/2JZ
__________________
#114 |
95 240sx w/2JZ
Found the coolant leak YES!!!! now to finish off the simple[small] things & get this thing tuned + to the track!!
__________________
#115 |
95 240sx w/2JZ
Almost there just tryin to get the cash to tune the car then YES!!!
Seem to be havin a 3-4k rpm cut but i think it might be to the aem readin that the air flow is maxed out on the aem reading i need to install the aem AIT sensor. ![]() ![]() ![]() ![]() ![]()
__________________
#116 |
lookin good man. Keep up the work.
#117 |
95 240sx w/2JZ
well....i think after i tune the car im going to sell it! WHAT!!! WHY!!! well....i kinda want something diff now start a new project. anyone have any offers!!! lol
__________________
#118 |
Posts: n/a
if u were in the US i would !!!! bah !!! good luck on the sale....ur project got me goin on my s14 2jz
#119 |
95 240sx w/2JZ
how much would u guys pay for something like this...
$20,000-$30,000?? There is over $30,000 invested including the car + parts no labour. If there was labour prob another $5,000-$10,000 Year: 1995 Make: Nissan Model: 240sx Engine: JDM 2JZ-GTE KM: 153 xxx on Body Engine Modifications --------------------- JDM 2JZ-GTE TDF Engine Mounts ATI Crank Damper USDM Water Pump USDM Cams USDM Thermostat USDM Oil Filter USDM Timing Belt Tensioner Tech 2 Pulley Kit NGK Spark Plugs Stage 5 4-Puck Competition Clutch Blitz 80mm Nur Spec Cat-Back Exhaust Hi-Flo Cat SG Custom 3” Downpipe Tech 2 Downpipe Flange SG Custom Intercooler Piping Titan Cam Gears vibrant couplers Vibrant Flange 3" Drivetrain Modifications ------------------------- 1JZ Bell housing TDF Transmission Mount R154 Rubber Transmission Mount R154 Transmission R154 Slave Cylinder 1JZ Flywheel Tech 2 Shifter Extension Tech 2 Clutch Line PD Custom 1 Piece Driveshaft Suspension/Wheels/Brakes Modifications ---------------------------------------- Bings Solid Subframe Aluminum Bushings Front Strut Tower Bar Stance GR Sport Specs 20mm Wheel Spacers Longer Wheel Studs Brembo GT Series Brakes Goodridge Stainless Steel Brake Lines 300zx Brake Master Bings Tension Control Rods VOLK GT-U 18x9 +37 18x10 +44 Volk Center Caps Toyo RA-1 Front “245” Rear “275” Cooling Modifications ---------------------- Flex-a-lite Dual Puller Fans Flex-a-lite Fan Controller KA Koyo Aluminum Radiator NISMO Radiator Cap CryO2 10LB Kit Blitz LM Intercooler Engine Management ------------------ AEM Standalone Electronics ----------------- AEM UEGO Gauge AEM Boost solenoid AEM 3.5 Bar Map AEM AIT Sensor AEM AIT Connector Apex'i Turbo Timer W/Harness Stewart Warner Boost Gauge Stewart Warner 100-260°F Water Temperature Gauge Fuel Modifications ------------------- Walbro Fuel Pump Custom In Bay Fuel Lines ICE --------- Sony Flip Out Deck Infinity 6.5" 2-Way Component Car Speaker (6010CS) Infinity 6 1/2" 2-Way Speaker (6012i) Misc ------ Autometer Dual Gauge Pillar Custom Mid Vent 3 Gauge Pod Phoenix Tuning Wire Harness Battery Re-location Kit [Trunk] New Toyota Gaskets I dunno how up to date this list is, but regardless.
__________________
#120 |
SupraForums Member
Honestly, as much as I love this swap I don't think I would pay anything more than $20k for that car. There are a ton of mods that add to the value but with the V160 and a single I would probably pay a little bit more.
#121 |
SupraForums Member
I may have skimmed over it, but do you have any #'s on the car or any estimates as to what it should put down?
#122 |
95 240sx w/2JZ
380-400rwhp
__________________
#123 |
91 Knockin 5-speed ;)
Nice car, really clean
![]() Zenki's ftw |
#124 |
95 240sx w/2JZ
Got the car free of revin problems and everything YES!!!!
__________________
#125 |
SupraForums Member
| Thread Tools | |
| Display Modes | |
