#1 |
SupraForums Member
HKS Vpro 2step
Can anyone with a HKS FCON VPRO give testimony on the 2step function?
I am curious how long it takes to build up boost, high high and configurations such as rolling 2 step (still engaged for x amount of feet after launching) on your particualr setups. Since there is no real anti-lag on the VPRO, I'd like to know how launching from a dead stop is especially on the drag strip.
__________________
if(engine != 2JZGTE) { slow(you); panic(); } ![]() ![]() ![]()
#2 | |
SupraForums Member
Quote:
1. Sit at a stop 2. Mat the throttle 3. POP the clutch 4. Enjoy the ride
#3 | |
SupraForums Member
Quote:
What is your turbo setup to build 18psi at 4500tpms? Also, how long does it take to build it there? 1-2 seconds? 3-5 seconds?
__________________
#4 | |
SupraForums Member
Quote:
Maybe I'll try to get a vid for you this weekend.
__________________
If you are rich you buy things that impress you. If you are not you buy things to impress other people.-Steve McQueen |
#5 | |
SupraForums Member
Quote:
![]() I have a PTE76GTS so we should be similiar, but I have a Tilton. I'm looking to spool about 25psi out of the whole it 28" Drag slicks. So, I'm curious if 25psi can be achieved at 5500rpms.
__________________
#6 | |
SupraForums Member
Quote:
I would PM FactorXTurbopineapple on SF's for more V-pro questions. (He's at the Time Attack this weekend with the turbo NSX though) Mike Angel at Factor X tuned mine. Their is SO much capability on this unit. I cannot believe how driveable my supra is at this power level and the better fuel economy with the knock amp. I can't see ANY other unit in my supra. BTW I'm sure you can get 25 psi on the 2 step. You just might have to set it at a higher rpm on the step to get there. 18 lbs for me on the street is plenty. I already roast them with my BFG dr's!
__________________
#7 |
SupraForums Member
Oh, I don't doubt the VPRO is a bad MOFO. It will be installed next month. I will have the knock amps as well. THe Navigator is nice as it can allow you to trim +/- 5% on AFR or timing without the Power Write Software from what I heard.
I'm also getting the mixture controllers to adjust the 2step set at my desireable RPM launch. I'll be patiently waiting for that video.
#8 | |
SupraForums Member
Quote:
From what I heard from John at HKS, that navigator is a bad unit. But with the knock amp running closed loop for me and with a conservative tune up top, I really don't need to make much changes. And I haven't got her out to the track yet. I thought of putting the switch in for multiple maps so I can run different gas (if needed) but I don't drive her that much to stray from C16 at this point. BTW who's doing the install and tune?
__________________
#9 |
SupraForums Member
Mr. Obiwan.
#10 |
SupraForums Member
Your in good hands then. With the V-pro on your car and set up right, you will love it.
__________________
#11 |
SupraForums Member
#12 |
SupraForums Member
Car sounds great man. When the time comes for me to go stand alone Im gonna be giving Ben a call as well for the vpro.
#13 | |
Twin Meister
Quote:
So true. Donkeypunch will think he's died and gone to heaven. Ken.
__________________
www.sp-power.com HKS 3.4L: 1110 all-boost whp/839 lb-ft @ 2.6KG/CM^2 1994 "SP ENGINEERING" TWIN HKS GT3240 TOYOTA SUPRA TURBO 1995 Toyota Supra Turbo 6MT (BPU) 2006 Toyota 4Runner Limited V8 2007 Lexus IS 350 2010 Lexus IS-F |
#14 |
Hawtness
V-pro is a tad less than AEM right?
#15 |
SupraForums Member
I'm not really sure. I guess it also depends on your set up. If you go AEM you might need the injector driver, UEGO, etc.... which could get costly. I bought the VPRO from Mike Angel at Factor X with the harness, all the sensors, and the knock amp. It was pretty much plug and play as far as installation. She started up first try and idled perfect even with my 272's. I also like that since my car is OBD2 that it will pass smog. (Wont pass the visual but they don't bother with that here.
Just plug it in and pass) It runs like stock. No stalling or cranking it forever to get a crank signal to start up. Mike is also an awesome tuner and John at HKS is always a phonecall away if there is any questions. Great bunch of guys. I couldn't see going with a different unit.
__________________
If you are rich you buy things that impress you. If you are not you buy things to impress other people.-Steve McQueen Last edited by QSMKIV; 04-29-2007 at 01:07 AM. |
#16 | |
Greddy T78
Quote:
I only got out 510 rwhp out of mine t78 setup at 21 psi....with the F-Con V Pro Gold Going with the AEM now, but if you have a GOOD HKS dealer that can map the F-Con, then i bet its great... ![]() // André Last edited by Ulrik; 04-29-2007 at 02:09 AM. |
#17 |
SupraForums Member
Great vids Kerry. Thank you! How much boost were you bulidning there?
The 2 step sounded smoothe. I was expecting something a little more violent. I didn't hear any back fire, but that maybe due to the camera. I was expecting to hear something like this. Here's a clip of a turbo G35 equipped with an HKS Vpro building 9psi of boost on the 2 -step. http://s140.photobucket.com/albums/r...o2Step9psi.flv Here's another 2 step video with a Supra. But I am not sure of the the EMS. http://videos.streetfire.net/video/c...00014f02a2.htm Again, I just hope the HKS VPRO can build about 25psi at 5500-5100 rpms for my drag racing needs. Last edited by donkeypunch; 04-29-2007 at 10:08 AM. |
#18 | |
SupraForums Member
Quote:
I might have to go like you with ET's and turn it up a little more. Can't wait to see what Obiwan will do with yours.
__________________
#19 |
JDM Driver
Damn Danny, you just can't help but to tease me with your V-pro. Then again, after you guys jinxed me that Thursday night (but seriously, thanks for the help
) with all the horrible AEM stories, maybe its time for me to get one. It's just unfortunate that Mikey's only free time is two weeks from now and I want the V-pro now. I'm getting the V-Pro, the knock amp, all the sensors and the navigator. The total, with all the parts, labor and tuning chimed in at just above 3K but I feel the benefits greatly outweigh the cost.
__________________
'08 Toyota Tundra Limited 4x4 Crewmax (Daily Driver/Hauler) '07 Mercedes-Benz GL450 (Family Car) '95 Toyota Supra 6sp APU HKS V-Pro tuned by Factor X Racing (Spanker) Precision Billet GT4276 on E85, 1015whp 754tq @ 32psi all boost |
#20 | |
SupraForums Member
Quote:
__________________
#21 |
Hawtness
Would you reccomend VPRO for a daily driver/weekend warrior? My car wont be a track wh0re, but then again i will go with race gas to play with some heavy hitters on the weekends? I dotn really need the navi or 2 step so let me hear your opinions? I would really like to get something other than AEM. Idk if there are any real good HKS guys around me but im not too far from the guys at SP.
#22 |
SupraForums Member
anyone using this with automatic???
#23 | |
SupraForums Member
Quote:
When I finally got my supra I had an idea of what I wanted to do to the car (It took me 2 years to find my QS) I didn't want to cut up the car and play the alphabet soup game (BCC, FCD,AFC, Map ECU....) I wanted a unit that would "grow" with my build and not have to be replaced/upgraded. I looked at AEM (talked to Jason at SEMA and talked to other friends with the unit) and at the time Motec wasn't to readly available. As you can see with my previous posts that I NEVER had a problem with my VPRO. I haven't taken mine to the track but I plan on some track time soon to see what she would do. My car was built mostly for freeway fun with bikes and higher end cars. As far as upgrades, it's up to you and your needs. I really don't need a Navigator. When John called Mike, I could have got one of the first units. The real time function is cool but too much information for me. At high speeds, I just watch the tach and try to keep her straight. Friends ask how fast was I going and to be honest I never look! The 2 step is part of the VPRO and isn't extra. It's just a fun little tool that I play with. To be honest I've only used it once in a race on the street. It usually scares the shit out of everybody else once I lay on it at a light. I mostly use it at car meet's (to stir some shit up) or to piss off my old lady when we go out for a ride. I bought the Knock Amp a year later after the VPRO installation and going single. It helped my fuel economy, driveablity, and helped with the tuning of my car since I had no wideband with the BPU. Mike Angel and John at HKS has guided me the whole way too. With their knowledge and understanding of what I wanted from the car, I was was able use the VPRO to suit my needs. The ONLY issue I see with the VPRO is finding a tuner. Everyone "seems" to think they are a AEM tuner but to get a VPRO tuned, it has to be a VPRO tuner. I got lucky with Mike being local (but never here ). But even looking back with the options today and if I didn't have a local HKS tuner, I would still go VPRO and either ship the car out or fly the tuner in. You get what you pay for and in my case I got EVERY penny's worth!
__________________
#24 |
Hawtness
You my friend have just writin a PERFECT review! Oustanding! I think a VPRO is right up my alley. And a knock Amp is a must for be being i like to keep driviabilty my #1 concern!
Do you by chance know any VPRO tuners in the midwest? More a less, SouthEast WI area? Thanks again for the help! |
#25 | |
SupraForums Member
Quote:
I am as excited as you. THis year my goal is to hit 9's on the 6spd. I want to prove how the VPRO wil perform on the track. AEM and MOTEC 6spd cars have been proven on the drag strip, but not many 6spd VRPO (that I have seen) VPROs are kicking ass at the strip. Ross @ Dynosaur performance has already ran 8's with a GT47-80 & TH400. I'd like to see the potential of the VPRO on a 6spd car.
__________________
| Thread Tools | |
| Display Modes | |
