Supraforums.com
Go Back   Supraforums.com > Performance and General Modification Forums > MKIV (1993-1998)
Register FAQ Members List Calendar Mark Forums Read
Reply
Thread Tools Display Modes
Old 10-04-2007, 10:19 PM   #1
Winnipegman
SupraForums Member
Why the dual Walbro craze?
Why does everyone or almost everyone use dual or tripple walbro pumps. I have had nothing but problems with them. That is why I sumped the tank and went with an external gear driven pump. No more fuel issues after that one. Magnafuel EFI625
Winnipegman is offline   Reply With Quote
Old 10-04-2007, 10:24 PM   #2
Supralative
TO4R.com Member
Supralative's Avatar
I have ran twin factory pumps in my old Supra and currently running twin walbros in a customer Supra with no issues.
Our Eclipse runs twin walbros with no issues either so far.
Supralative is online now   Reply With Quote
Old 10-05-2007, 02:36 PM   #3
KenHenderson
Twin Meister
KenHenderson's Avatar
Quote:
Because they are fixing something that's not broken. The Walbros are physically smaller than the OEM Densos and draw less current which some consider an advantage. I don't. When it comes to the actual task of pumping fuel, the Densos demonstrably outperform the Walbros and are significantly more reliable. I've seen too many of my personal friends have Walbro-based problems with their fuel system and I do not believe the Walbros are worth the risk. When it comes to 1000 + whp cars, twin HKS/Densos (like I have), triple Walbros or a big Weldon are pretty much required. If a guy's power goals do not exceed the capacity of dual OEM Denso pumps, I can't, for the life of me, figure out why he would go with Walbros or any other non-OEM fuel pump.
Ken.
__________________
www.sp-power.com
HKS 3.4L: 1110 all-boost whp/839 lb-ft @ 2.6KG/CM^2
1994 "SP ENGINEERING" TWIN HKS GT3240 TOYOTA SUPRA TURBO
1995 Toyota Supra Turbo 6MT (BPU)
2006 Toyota 4Runner Limited V8
2007 Lexus IS 350
2010 Lexus IS-F
KenHenderson is offline   Reply With Quote
Old 10-05-2007, 07:25 PM   #4
slither
SupraForums Member
slither's Avatar
What kinda issues are some people having with walbro's?
slither is offline   Reply With Quote
Old 10-05-2007, 07:46 PM   #5
Wreckless
MK3 kid in a MK4 world
Wreckless's Avatar
Quote:
They just up an fail randomly. They start functioning intermittently when stressed. Some just never work right.
I think that when you get a 'good' Walbro, its a good pump. The flipside is that the quality control seems to suck and I'm not the kinda guy who wants to weed out the bad pumps from the good pumps when the fate of my engine hangs in the balance.
If I can spend $350 a tire on good tires, thousands on a turbo kit, hundreds on a steering wheel or seat, etc... I can afford to spend a couple hundred bucks on a truly trustworthy fuel pump and never have the worry of a pump dropping on me at 1.7 bar.
__________________
"I spent a lot of money on booze, chicks and fast cars. The rest I just squandered." -- George Best
"Make the suspension adjustable and they will adjust it wrong -- look what they can do to a Weber carburetor in just a few moments of stupidity with a screwdriver." -- Colin Chapman
Wreckless is offline   Reply With Quote
Old 10-05-2007, 09:29 PM   #6
HotSoup
SupraForums Member
HotSoup's Avatar
AEM must make Walbro pumps.....or vise versa LOL...
Jason
HotSoup is offline   Reply With Quote
Old 10-05-2007, 09:41 PM   #7
KenHenderson
Twin Meister
This is true. Only one of my buddies has been truly unfortunate....popped a motor while racing another buddy's ZX-12R (pre-turbo). No warning whatsoever. The pump had been functioning as envisioned until it went....in a big way. Two others noticed the intermittent operation operation of at least one of two pumps before it became truly costly. Far too many, IMO, are bad right out of the box but, as Wreckless said, if you get a good one, you should be alright, assuming you want to run that risk in the first place.
Ken.
__________________
www.sp-power.com
2007 Lexus IS 350
2010 Lexus IS-F
Old 10-05-2007, 10:25 PM   #8
Smokey1226
Hawtness
Smokey1226's Avatar
Quote:
Jason
LOLOLOL i couldnt of said it any better myself
__________________
Smokey1226 is offline   Reply With Quote
Old 10-06-2007, 11:28 AM   #9
scottinhawaii
SupraForums Member
scottinhawaii's Avatar
I couldn't have said it better myself. I can't believe anyone still buys Walbros for our cars. Leave them for the Eclipse guys.
__________________
Activate interlock... dyno-therms connected... infra-cells up! Mega-thrusters are go!
scottinhawaii is online now   Reply With Quote
Old 10-06-2007, 11:55 AM   #10
Prodigy
I'm grounded
Prodigy's Avatar
make it sticky?? i have countless friends and my self that have run into fuel problems and turn out to be the pumps. even you know the dual denso takes more power i just add a 160amp alt. volts never drop lower then 14v...
Prodigy is offline   Reply With Quote
Old 10-06-2007, 01:44 PM   #11
damianhindley
SupraForums Member
damianhindley's Avatar
walbro in my supra, 3 years no probs. Walbro in my civic, I went through 2 in a year. I plan on going stock but the walbro came in the supra.
__________________
White 97 6speed tt.
Greddy T78 and other parts
1999 Honda CR-V ex
2007 Yamaha R6s
Apple Computer user for life!
aim: damianhindley
appledamian@gmail.com
damianhindley is offline   Reply With Quote
Old 10-06-2007, 03:47 PM   #12
TooJayZee
Cheifbootknocka
TooJayZee's Avatar
Jason
Quote:
Who are you guys to laugh. Aems work 100% perfect......80% of the time
__________________
TooJayZee is offline   Reply With Quote
Old 10-06-2007, 04:50 PM   #13
Winnipegman
SupraForums Member
The thing is I spent say 20 grand on an engine, why cheap out on the pumps? Who first decided to use dual walbros to begin with? Why not just get one big pump. I suppose it's because they are intank pumps and it saves a little hassel then having to run an external. But if you build your engine up to need that much fuel then you can spend the hundred bucks to sump the tank and run an external. I dunno any more thoughts on this?
Old 10-06-2007, 06:04 PM   #14
LexISpooled
SupraForums Member
LexISpooled's Avatar
If you spent $20k just on your engine then your first problem is finding out who ripped you off..
Why do so many run dual walbros its very simple, for the most part they work perfectly fine (personally I do not know of a failure other then the internet stories), cost less than half of the OEM denso's and need half of the power denso's require..not rocket science that most will go that route..
Why dont people run one huge pump, simple thay sound horrible and loud..for me no thanks..
With that said I have one inline and one intank walbro, at one time I had the denso pumps but decided with the amount of people running twin walbros w/o issues I decided stick with them..
I know ray at pfs here in md got a single walbro to fuel 600rwhp, and honestly I run that power level or less 95% of the time for pump gas so even if I had one fail I'm still ok..
If I did it all over again I would probably have gone with the denso's just because I want the best of the best and OEM toyota parts for the most are just that..
__________________
'02 MSM IS300TT 6spd.
PFS Built and Tuned
HKS Drags for sale pm me
LexISpooled is offline   Reply With Quote
Old 10-06-2007, 06:16 PM   #15
Winnipegman
SupraForums Member
I did hit 676hp on a single walbro but the fuel pressure actually started dropping at 520hp. But if you're running over 700 hp and need more than one pump or a bigger pump then what's a little extra noise?
Old 10-06-2007, 11:07 PM   #16
2JayZCres
SupraForums Member
What are some alternative fuel pump options, i am looking to make about 700WHP and was going to go with dual walbros but the more i read about failures the more i gets antsy about trusting my engine to them.
suggestions?
2JayZCres is offline   Reply With Quote
Old 10-06-2007, 11:56 PM   #17
Morefaster
(overspooled)
Morefaster's Avatar
Quote:
suggestions?
dual oem denso's
Morefaster is offline   Reply With Quote
Old 10-07-2007, 01:36 AM   #18
Griffon
SupraForums Member
Griffon's Avatar
Reading this has me a bit worried as my car is in the shop being worked on right now... Fuel system wise I have HKS fuel rail 780cc injectors, Greddy E-managment and a 255 LPH pump running a T60 single at no more then 18psi at the most... Is this safe, or should I be looking at different pumps?? (Its a 95 NA-T)
Griffon is offline   Reply With Quote
Old 10-07-2007, 10:58 AM   #19
StokerSix
SupraForums Member
StokerSix's Avatar
Running a 67 turbo using 2 walbros on stock wiring for 6 years +...zero problems. Well, I did use 12awg for the bracket wiring.
Running off the stock fuel ECU instead of ghetto rigging it to the battery is what sold me on the walbros. Many advantages to running off the stock fuel ECU.
StokerSix is offline   Reply With Quote
Old 10-07-2007, 11:57 AM   #20
SupraHULK
FK URV8
Last time i got on the dyno,Sept,14th 2007, i was running twin Denso pumps,one was brand new,the other was the orginal pump the car came with. well the orginal took a shit on me on the dyno.
and the shop i was at had Walbros in stock,so i bought 2 brand new walbros installed them,everything went fine.
But the other day im driving,and i get on my car get into boost,and start leaning out,im like WTF
check my fuel pressure on my adj.FPR gauge, only at 20psi
turns out one of my Brand New Walbros already took a shit,with less than 500 miles on it.
So now im pulling my motor,and building it. looking to hit 1000whp, but not sure of which fuel system set up to go with???
any ideas? no more Walbros!
SupraHULK is offline   Reply With Quote
Old 10-07-2007, 01:10 PM   #21
Cordeez
Z06 Now.
Cordeez's Avatar
I had a 255 in my 240sx, ran perfectly for 1+ year and 4K miles.
Put one in my supra, and it started sputtering after about 250 miles, then it finally went out at 255 miles.
Replaced it with another walbro and has been going good for about 1 year and 5K miles. Looks like its hit or miss.
Cordeez is offline   Reply With Quote
Old 10-07-2007, 02:49 PM   #22
KenHenderson
Twin Meister
Your Denso pump failing is an extreme rarity in my experience but, obviously, it can happen. Twin Densos can get you 1000 whp, but it will be close. Twin HKS Densos (much more expensive) can do it all night long (1110 whp on my black car). Triple Walbros are necessary at this power level because they do not flow as much as the Densos and as Mark Conte said, they do not necessarily handle stress that well. Look at all the hit and miss Walbro stories in this thread alone. Talk to anyone associated with a top-notch Supra race team, as Conte was, and you'll hear a lot more. Guys should go into this deal with their eyes wide open. It is a SF myth that Walbros are superior to OEM or HKS Densos. (My assumption is that most of you are building high-powered street cars as opposed to purpose-built race cars).
Ken.
__________________
www.sp-power.com
2007 Lexus IS 350
2010 Lexus IS-F
Old 10-07-2007, 04:02 PM   #23
Tony the Tiger
SupraForums Member
I just spend the money on a nice fuel pressure gauge with warning light. When pumps go, at least the direct result is fuel pressure drop. It's easy to pay attention to a nice red light on your dash notifying any fuel pressure drop (just like oil pressure drop w/ oil pressure light!).
On the other hand, injectors for example are far more important. When injectors fail, it barely registers on the wideband (esp when using one wideband for all 6 cyl's), and it easily pops one cylinder. Enough to kill the motor.
When running dual walbros, just install a trusty fuel pressure gauge if you are afraid of bad pumps. If pressure is dropping, it means that the fuel pump isn't keeping up for whatever reason. Bad wiring, loose electrical connections, fuel pump physically failing, etc.. You can install two Denso pumps but can still run into a risk from bad wiring for example. I'd personally go with dual Denso pumps if I were to max out dual Walbros. Even up to today, I don't trust my Walbros if I were to use them up to 80% of its capacity.
__________________
1044 WHP @ 36.5 PSI GTX45R '94 Supra TT 6spd
567 WHP @ 26.5 PSI Mom's Twincharged TRD SC/HKS T51R SPL '94 Camry V6
659 WHP @ 30 PSI Acura Integra (now with T51R KAI)
440 WHP @ 14.5 PSI GT3076R Lexus IS300
Dynamotorsports Tuning
Tony the Tiger is offline   Reply With Quote
Old 10-07-2007, 04:26 PM   #24
StokerSix
SupraForums Member
StokerSix's Avatar
Quote:
Ding ding!
Exactly. All modifed cars with a fuel system should have a fuel pressure gauge.
My FP red light will catch my attention immediately as it's right in front of my face on the A-pillar.
Old 10-07-2007, 04:41 PM   #25
Speed King
Top Secret T88H
Speed King's Avatar
Quote:
Ken.
Triple Walbros are required on 1000rwhp?
__________________
'94 Toyota Supra Top Secret Wide Body T88H
'00 Mercedes-Benz E-Class 430 Sport (DD)
Sold
'89 S-13 KA swap (Daily Drifter)
'04 Modded STi
'03 Yamaha R1
'99 Modded GS-R
'99 Champion's Ltd Edition R1
"In this society; We kill people, for killing people, to teach other people not to kill people.."
Speed King is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by: Mvp Motorsports
Credit Card Processing
