#1 |
SupraForums Member
2JZ install into a DeLorean
Hello,
I am going to install a Aristo engine into my 82 DeLorean. I have a few ECU/ electrical question. 1. How do i trick the stock ECU to think the traction controll is disabled? must be grounding a pin or two. 2. The DeLorean uses a cable driven speedo so i don't have a signal pulse to provide the ECU. I'll be using the stock DeLorean transaxle. do i need to even provide a pulse? 3. the DeLorean provides a +12v signal to activate the A/C compressor. i see the Aristo ECU has two pins that correspond to the A/C. what do i need to do. I'm also looking for a wire harness for an Aristo. Mine came cut. The motor is in very good shape thank goodness. I would like to extend my thanks in advance for any help. I'll continue to use the search feature to try and answer these but i have not been Successful. -Ed |
#2 |
SupraForums Member
Wow, that's going to be a lot of customization and welding. Are you sure you want to do this? It will lower the collectability of your car. Isn't the vaue of the Delorian back up to what it was off of the show room floor for stainless steal editions and off the chart for gold plated editions?
#3 |
SupraForums Member
not realy worried about that. i already had a fully built version of the original motor in it. I sold it to anouther owner. the fabrication part is no problem for me.
#4 |
SuperMember
I dont think many people if any here uses the aristo ecu, you got lots of work ahead of you, good luck
#5 |
SupraForums Member
The Aristo engine harness and ECU are identical to the supra one, all you need to do is leave the Trac unplugged, there is a seperate ecu for trac just leave it out.
__________________
Link To My Car & Videos HKS 2835 Twins Built Motor Veilside Plenum AEM EMS TRD Diff 825 bhp & 627ftlbs at the hubs. |
#6 |
SupraForums Member
I used an Aristo ecu in my swap ( MkIII ) and haven't hooked up anything pertaining to Traction. I see no problems at all nor do I get a code. I actually pulled all the traction and automatic tranny related wires from the harness.
The MkIII supra also uses a cable driven speedo however the signal is converted to electronic at the speedometer to feed into the ecu and abs unit. Check to see if the Dolorean has a similar setup with signal converted to electronic at the speedometer. The AC signal that you would need is the one for the MAG. Same thing in a MKIII Supra, we use only two wires , and all the rest is for the speed sensing of some kind I believe. Which part of the harness is cut? The two connectors for the ECU ( e-9 and e-10) Is what you will really need. The other is the body harness connector and the plug is basically chopped of and only some wires used. |
#7 |
paid cash 4 my mkiv
Cool bud, It's gonna be one of a kind project. I haven't seen any Delorean 2jz yet.
__________________
![]() sig by Boostrush 1997 geo Metro DD 1998 Civic 2dr EX all the ricer mods aka weekend warior. Ferrari F40 sold Ferrari F50 sold Ferrari Enzo sold Saleen S7 sold Bugatti Veyron sold Koenigsegg CCX sold Maserati MC12 sold Pagani Zonda sold Mercedes McLaren SLR sold |
#8 | |
SupraForums Member
Quote:
I planned on pulling all the trac control and auto tranny related wires and plugs too. Is there any benefit to finding a manual ECU? The delorean does not convert to an electronic speedo pulse so i'll make something. Trigger wheel on the axle hub and a hall sensor should to the trick. I'll just trigger the A/C MAG signal with the +12V i guess. Am i correct in saying that? The main engine harness is cut between the engine and ECU plugs. i would like to get a replacement so it looks clean going though the fire wall. |
#9 |
SupraForums Member
That's an interesting project... best of luck! keep us informed of how it's going! got some pics of your car?
#10 |
SupraForums Member
#11 |
SupraForums Member
the engine i just took out:
![]() my car ![]() The engine when i first finished it ![]() when i first pulled the motor way back when
#12 |
SupraForums Member
i like this thread! i always wondered if anyone did anything cool with these
good luck , and i hope to see a finished result |
#13 |
MK3 kid in a MK4 world
Is the stock transaxle going to hold up under that kind of power?
#14 |
SupraForums Member
Anouther item you guys can help me with is what is the "lowest profile" flywheel that will fit the 2JZ. not a flex plate. i do not care about what pressure plate will fit. I need to have the least distance between the engine and transmission.
#15 |
SupraForums Member
#16 |
TORC09
Wow! That would be cool if you can pull it off.
__________________
CLICK HERE TO REGISTER YOUR TOYOTA SUPRA ![]() My Twins--------------SILV08------------Supra Registry |
#17 |
SupraForums Member
There is no "if" about it, it's when i get it done. it'll just take time and of course money.
#18 |
SupraForums Member
wouldn't a Mr. Fusion Home Energy Reactor be a better drop in motor with all the crazy gas prices? 1.21 gigawatts of power!! nah just kidding. good luck with the project.
http://bttf.wikia.com/wiki/Image:Refueling.jpg |
#19 |
SupraForums Member
You can use either ecu's - manual or auto. both works.
#20 |
2JZ S13
that sounds pretty badass! G/L with the build
#21 |
'94 TT Blk/Blk 6 spd
Really cool project. I haven't seen one in person in years.
What does the DeLorean tip the scales at? |
#22 |
ex BPU'er
sweet project. definitely better than that dodge avenger...
#23 | |
SupraForums Member
Quote:
no because Mr. Fusion only powers time circuts, the car still need to run on the internal combustion engine
__________________
1997 Supra 2JZ-GTE 2001 Celica GT-S 2ZZ-GTE 1990 All-Trac 3S-GTE 1997 Celica GT 5S-FTE 1998 Dodge Cummins ------------------------------------ 5 Vehicles ALL BOOSTED!!!!!! Last edited by Smaay; 08-06-2008 at 02:57 PM. |
#24 |
SupraForums Member
im not exactly sure how the astro tb is but im pretty sure you have to install resistors to the tb sub tps in order to tell the comp that its open. you can search and find the awnsers i did the same thing to my usdm car over the winter.
Andrew |
#25 |
SupraForums Member
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Gamimnon's Thief found... | dejacky | Naturally Aspirated | 39 | 12-11-2007 12:45 PM |
| 2jz water pump install (pics) | jizake1jz | 1JZ/2JZ Swap | 4 | 05-02-2006 08:50 PM |
| DEFI install in 2jz (esp. oil temp) | Arnout | MKIV (1993-1998) | 5 | 07-15-2004 03:45 PM |
| 2jz NOS Fogger install? | toypro | MKIV (1993-1998) | 4 | 02-24-2003 02:33 AM |
