Supraforums.com
Go Back   Supraforums.com > Supra Specific > Shops & Part Reviews
Register FAQ Members List Calendar Mark Forums Read
Reply
Thread Tools Display Modes
Old 11-11-2009, 10:09 AM   #1
TitanMotorsports
Newbie
Precision Vs Tial
When Precision released their new 46mm Wastegate, we were asked by our clients to do a side by side comparison with the Tial 44mm, you are probably wondering, why not against the Tial 46mm?? and the reason is because even though Tial makes a 46mm, it is the 44mm that has the same mounting flange as Precision’s therefore if you have a header with that mounting flange already on it the decision would be between the Tial 44mm and the Precision 46mm. Below is the observations we were able to make by taking them apart, and comparing their internals.
To begin lets lay out the facts, Tial is a 44mm Wastegate that comes in a multitude of colors and we sell them for $450 to the public HERE. Precision’s has a bit of a larger valve 46mm, and it is only available in black and we retail it to the public for $314.10 Found in HERE. So let’s begin with the photos.
Boxes are the same size and they both come packed with the same foam material that completely protects every part from damage during shipping.
Below are the contents of the boxes the way they come, the clear difference is that the Precision comes with 3 extra springs in the box, that way you have the possibility to replace them without having to make a separate order for them.
As for the hardware, both have the banjo design, but the Precision brings an extra plug in case you don’t use one of the ports of the Wastegate and the Tial doesn’t have this in their hardware.
When side by side they look very similar, however the Precision unit is a bit smaller in height compared to the Tial,
The underside again is the same basic design, however you can see how the valve in the precision is a little bit larger (2mm) than the Tial unit
Once apart, the precision comes standard with 2 springs, and the seat materials are visibly different, I ‘m not qualified to give a breakdown on the materials, however the structure of the seat itself is the same, and even though is hard to tell from the pictures they both use a 4 Allen key setup to hold the seat to the valve itself.
Internally the main difference is Precision uses a longer sleeve to hold the stem of the valve
And last but not least the literature. Precision comes with a multi page full color instruction’s manual, Tial half a letter size paper printed in both sides.
Hope this can help you make an educated decision when in the market for a Wastegate.
__________________
Titan Motorsports
email: info@titanmotorsports.com online: http://www.titanmotorsports.com
tel 407.277.8423 | EXT: 247| fax: 407.277.8525
11370 Boggy Creek Road Orlando, FL 32824
Blog | Twitter | Facebook | Myspace
TitanMotorsports is offline   Reply With Quote
Old 11-11-2009, 10:23 AM   #2
samacs
SupraForums Member
samacs's Avatar
Nice write up, I didn't even know Precision made a WG.
samacs is offline   Reply With Quote
Old 11-11-2009, 10:28 AM   #3
N1ck Z
Newbie
yea me ether haha
tial seems better tho... shiny!
N1ck Z is offline   Reply With Quote
Old 11-11-2009, 10:48 AM   #4
2jzMK3
With all due respect.....
2jzMK3's Avatar
they were just released.
__________________
Quote:
Originally Posted by Mark Conte View Post
Sean has spent more money on his MK3 Supra than Toyota.
Engine Built and Tuned by: Darin Dichiara
http://blog.titanmotorsports.com
2jzMK3 is offline   Reply With Quote
Old 11-11-2009, 11:29 AM   #5
LexISpooled
SupraForums Member
LexISpooled's Avatar
Does the precision have a spring that can hold a base boost around 14-15psi and can then hold up around 26psi w/o having to swap springs?
I believe the tial has the .9bar spring which can do that sufficiently..
LexISpooled is offline   Reply With Quote
Old 11-11-2009, 11:42 AM   #6
Sound Performance
SPRacingOnline.com
Sound Performance's Avatar
Location: Well, Dick, here's the deal: I'm the best there is, plain and simple. I mean, I wake up in the morning and I piss excellence. You know, nobody can hang with my stuff.
Of course they have a 14-15 psi spring. I would not think that you should have any problem getting 26 psi but that is really not as much WG dependent as it is your setup. Turbo size, header design, back pressure etc.
__________________
XXSUPRAXX@AOL.COM Cell# 630-205-6690
Do Not PM Me!! IM me @ XXSUPRAXX
Sound Performance is offline   Reply With Quote
Old 11-11-2009, 11:43 AM   #7
Sound Performance
SPRacingOnline.com
Nice writeup BTW !!
__________________
Old 11-11-2009, 11:45 AM   #8
Mdeniz
9's Club
Mdeniz's Avatar
Quote:
Originally Posted by Sound Performance View Post
Nice writeup BTW !!
Sank you sirr
__________________
AIM: MarioAtTitan
Phone# 407-447-5864 x247
E-mail: Mario@titanmotorsports.com
92 SC300 9.44@145
93.5 Hardtop TRD Widebody Supra 1115WHP@37psi
Mdeniz is offline   Reply With Quote
Old 11-11-2009, 11:46 AM   #9
Nero
SupraForums Sponsor
Nero's Avatar
If you mean you can use the low spring for base setting and then use a boost controller to run higher boost like the below description then yes the precision wastegate can do this, this is also the function of pretty much all wastegate's on the market today
__________________
World's Fastest and Quickest 2JZ's
Supra Hardtop BPU 11.23
Supra Pro Street Tire 7.66 / 188
Pro RWD Celica Black 6.47 @ 216 For Sale
Pro RWD Scion Copper 6.407 @ 218.90 / 6.450 @ 220.10
Pro RWD Scion Black 6.42 @ 219
www.TitanMotorsports.com
Nero is offline   Reply With Quote
Old 11-11-2009, 11:53 AM   #10
Flicktitty
2JZ S13
Flicktitty's Avatar
looks like a pretty good product.
thanks for the writeup.
do you have any customers that have used this yet? how are the results?
Flicktitty is offline   Reply With Quote
Old 11-11-2009, 01:02 PM   #11
Bottle
SupraForums Member
we have shipped about 20 units out and just got them a few days ago. So we have not heard back from those customer yet.
Bottle is offline   Reply With Quote
Old 11-11-2009, 01:39 PM   #12
boost dr
Not Banned
Seems like a better deal for the money. I like the fact that it comes with multiple springs. Tial springs are like what an exctra $25 a piece?
boost dr is offline   Reply With Quote
Old 11-11-2009, 03:27 PM   #13
SUPRMSC
[SFOT] Carbon2
SUPRMSC's Avatar
Beautiful writeup, precision ftw
SUPRMSC is offline   Reply With Quote
Old 11-11-2009, 03:51 PM   #14
agm
SupraForums Member
agm's Avatar
hm im in the market for exactly this right now, can anyone confirm the resistance of all 3 springs?
Quote:
Originally Posted by titan website
and can accommodate a wide range of boost pressures (anywhere from 1.5PSI up to 25.5PSI).
one of them is a 1.5psi spring?
i might be able to utilize a 1.5psi spring for initial testing, and the price for this is seeming very efficient.
if someone can confirm a 1.5psi spring, i will likely order this upcoming monday
agm is offline   Reply With Quote
Old 11-11-2009, 04:22 PM   #15
TonyN
Im A Fuking Ninja!!!
TonyN's Avatar
nice, seems like a quality part from precision. I just bought my tial 44 a few months ago, if i would have seen this i might have gone with precision, the quality and material seems as good and the price difference is substantial engouh. plus with a well trusted shop like Titan backing it up im sure its good.
__________________
94 SP63, Auto 3.8k stall, meth/pump 91= 550+RWHP
TonyN is online now   Reply With Quote
Old 11-11-2009, 04:41 PM   #16
Sooco100pf
SupraForums Member
Sooco100pf's Avatar
Any info on how the Precision does with leaded race gas? I know a Tial 38MM wastegate is not recommended to be used if leaded gas is used often, just wanted to check.
Sooco100pf is offline   Reply With Quote
Old 11-11-2009, 04:42 PM   #17
chevyeater-on-sf
wastegate hose is pulled
chevyeater-on-sf's Avatar
Where are the castings made for these wastegates (tial/precision)?
I may be wrong but I'm getting a whiff of "China"...
chevyeater-on-sf is offline   Reply With Quote
Old 11-11-2009, 05:16 PM   #18
Errol @ TPS
Just an old Redneck
Errol @ TPS's Avatar
No way man. That is a bonified Chinese Knock off, of a Chinese Knock off.
__________________
Errol @ TPS
Taken from the cult classic movie, "the ninth configuration"
In order for life to have appeared spontaneously on earth, there first had to be hundreds of millions of protein molecules of the ninth configuration. But given the size of the planet Earth, do you know how long it would have taken for just one of these protein molecules to appear entirely by chance? Roughly ten to the two hundred and forty-third power billions of years. And I find that far, far more fantastic than simply believing in God.
Errol @ TPS is offline   Reply With Quote
Old 11-11-2009, 05:23 PM   #19
agm
SupraForums Member
agm's Avatar
even if they come from chinese factories, i would like to believe precision puts them through some intense quality control.
the fit and finish is probably a cut above.
Old 11-11-2009, 08:46 PM   #20
4wd-eclipse
Boost Addicted.
4wd-eclipse's Avatar
Is the Precision 46mm will mount perfectly into Tial 44mm weld in/out flanges? ... If not dose the Precision 46mm come with welding flanges?
__________________
MK
*95 JDM Supra TT 6-Speed Hardtops .. BB 6765, HKS F-Con V Pro + HKS AFK, GReddy 3 Row, HKS 1000cc, In-tank 044 + BAP, HPF Bronze/RPS Clutch, SARD Radiator, Evo7 Recaro Seats, Volk TE37, GReddy Brake, Velside Hood, RMM Spoiler.
*90 JDM AWD 1G DSM .. AEM EMS with 500hp+ mods.
My DSM pics: http://www.dsmtuners.com/gallery/bro...imageuser=3696
My DSM vid:
http://www.youtube.com/watch?v=dAqsxHam_3E
4wd-eclipse is offline   Reply With Quote
Old 11-11-2009, 11:33 PM   #21
NickD.
SupraForums Member
NickD.'s Avatar
Looks like we got a new kid on the block when it comes to wastegate. Quality and price= a winning combo. Undercut Tial by $135...............i am in. Precision comes with pretty box and full color manual seal the deal. Thanks Titan for the great review.
NickD. is offline   Reply With Quote
Old 11-16-2009, 10:20 AM   #22
Nero
SupraForums Sponsor
Nero's Avatar
Yes to my knowledge a Precision Gate will bolt to both the inlet and outlet flanges of a Tial Wastegate 44mm piece. V-band style. If you already have a header the Precision will bolt right on.
I am not Precision, but from my knowlegde of the products and housings they make, I believe this pieces is made in the USA or cast in the USA on the housing and the CNC Billet pieces are likely made at the Precision Turbo Factory. As you can see there are no foriegn stickers saying "made in china" on any of the pictures which is common when products are made overseas.
Quote:
__________________
Old 11-16-2009, 10:32 AM   #23
sickboy
SupraForums Member
sickboy is offline   Reply With Quote
Old 11-16-2009, 11:44 AM   #24
agm
SupraForums Member
agm's Avatar
lol...
Old 11-17-2009, 02:49 AM   #25
4wd-eclipse
Boost Addicted.
Sound Great ... I was planning to get Tial 44mm very soon, so I'll order the Precision 46mm instead.
__________________
MK
My DSM vid:
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by: Mvp Motorsports
Credit Card Processing
