Supraforums.com
Go Back   Supraforums.com > Performance and General Modification Forums > MKIV (1993-1998) > MKIV FAQ
Register FAQ Members List Calendar Mark Forums Read
Reply
Thread Tools Display Modes
Old 10-14-2002, 10:48 AM   #1
RSA Supra
Administrator
Auto Admin
RSA Supra's Avatar
Tech Article: Boost Leak Test
This will vary a little depending on what intake you have, etc. But its pretty much universal.
Please read the entire thread before commencing testing. I take no responsibility for any mistakes made or damages caused on your part. Potential damage from over 60-80psi to oil pan gaskets, oil seals, etc.
Here is what you'll need:
Soup can, small bolt, hose clamp, tire valve stem. (stop by a tire shop and ask for a used one)
Unhook your intake piping and clamp the soup can into the hose. (you'll do this at different positions depending on your intake, but you get the idea right? plug up the intake so no air can get out)
Take the hose off of the intake manifold, (find it by moving back on the outside from the throttle body) plug it with a bolt or screw and clamp it tight.
Take the valve stem and press it up against the nipple.
Then take a high pressure air hose with a tire inflation attachment and pressurize the system. This is where it helps to have a second person, but it isn't necessary.
Hopefully you have a boost gauge because you'll want to watch it for a couple of reasons. First you'll want to see if it is actually building pressure (if not, you either didn't seal things off correctly, or you have a really bad boost leak) and second to make sure that you aren't putting too much pressure in the system. Be careful not to pressurize the system with more than about 12-14psi (should be more than enough to locate any leaks) at which the pressure will probably cause air to rush out of your oil cap. (this is normal)
If you have a boost leak, you should be able to audibly hear it. If you can't figure out its exact location, you may either want to have someone move their hand around and listen/feel for air escaping, or put soapy water on the intercooler piping and look for bubbles.
Happy boosting!!!
__________________
-Ryan Hawkins
1993.5 Supra
PHR Stage 1+, 3.4L Stroker, BL Auto
My Website My Mods My Pictures
RSA Supra is offline   Reply With Quote
Old 10-14-2002, 12:12 PM   #2
WeaponX
Posts: n/a
Very helpful, thanks for the post
Old 10-14-2002, 02:55 PM   #3
Zerosoul
Posts: n/a
I hate when either the oil cap pops or the can pops off the intake, jumpy...
good post Ryan, its about time someone did an article on this properly.
one thing though, I wonder if its ok to pressure test the system with the oil cap off, since its gonna pop anyway
Old 10-14-2002, 09:05 PM   #4
RSA Supra
Administrator
Auto Admin
RSA Supra's Avatar
Thanks! I took pictures a couple of months ago when I tested mine and just got around to posting.
I'm not sure if you could pressure test the system w/ out the oilcap because air is rushing through the crankcase. I guess you could try it by taking it off and watching the boost gauge. But I doubt it'd work.
Perhaps someone can make this sticky or add it to the FAQ.
Old 10-14-2002, 09:10 PM   #5
BrianJ
Posts: n/a
is the soup can empty or is it unopened?
Old 05-21-2005, 04:21 AM   #6
NickT916
SupraForums Member
NickT916's Avatar
hahaha use a soup to test the soup. Well instead of using one of those huge compressors so you wont blow up your seals, use one of those hand pumps or the electrical car pumps and pump yuor engine up to like 20-30 psi and then listen for the leaks.
im gonna do this tomorrow, ill try and get some picture if i can, sounds like fun.
If ill use the hand pump tomorrow and be pumping my engine , my neighboors will think im on crack or something.
NickT916 is offline   Reply With Quote
Old 06-20-2005, 09:49 PM   #7
VickSupra
Hoosier Daddy?
VickSupra's Avatar
I want to see you pump 20-30 psi by hand...
Actually you only need to go to 8-10 psi. And even that is a fair volume of air.
VickSupra is offline   Reply With Quote
Old 06-20-2005, 09:56 PM   #8
michaelvanle
Newbie
michaelvanle's Avatar
I don't see how the compressor will blow any seals. On the compressor, it has a knob that you adjust what psi you want it to spray out. Just set it to like 25psi (or whatever your high boost is) and listen for leaks.
BTW this is hard as shit. I have a bunch of leaks around the VSV but I can't pinpoint it out. I replaced most of the vacuum lines, but some of them are hard as shit to get to.
michaelvanle is offline   Reply With Quote
Old 06-20-2005, 09:58 PM   #9
jdmuscle
SUPRAS FOR LIFE
jdmuscle's Avatar
wow..nice post!! i have a boost leak and it is driving me nuts, cause the car to run too rich at idle.
__________________
94 BALTIC BLUE......720RWHP
06 Z06...................541RWHP
04 LS430................241RWHP
jdmuscle is offline   Reply With Quote
Old 09-29-2005, 06:48 PM   #10
bahraini_zupra
JZ Enthusiast
bahraini_zupra's Avatar
THIS IDEA IS AWSOMMMMEEE i tested this and it worked like dream
thanks aloot guys ..
ali
bahraini_zupra is offline   Reply With Quote
Old 03-11-2006, 10:40 PM   #11
KevinB6876
SupraForums Member
I suspect I have a boost leak, so I just did this test with both a hand pump and a bicycle tire pump.
I could not build any pressure in the intake mani with either pump. not even 1psi. I even tried with a 12V pump. Instead, all I heard was the sound of air hissing from behind the engine and the hissing got worse the more I pumped. However, pressure remained at 0psi on the pump gauge and the boost gauge while the hissing was occurring.
I suspect this means that I have a bad boost leak. The noise is coming from somewhere behind the engine, but I can't find it! I'm starting to think its either under the car or in an area behind the engine that I can't get to. So far I haven't been able to pinpoint it and its PISSING ME OFF *frustrated*. lol.
I just want to say, I think this idea to test for a turbo boost leak by pressurizing the system is an excellent idea. I was initially skeptical of it, but the more I looked at it and thought about it, the more I started to think it sounded like a good idea. And this was proven in application, because it seems to have found a major leak on my car.
Too bad I can't pinpoint it yet.
Toyota doesn't even have a boost leak test procedure in any of their manuals. Sad. My respect goes out to RSA Supra for coming up with this idea. Thank you RSA. Lemme know if you got any more good ideas.
KevinB6876 is offline   Reply With Quote
Old 03-12-2006, 03:09 PM   #12
JohnA
Misty and Wet
JohnA's Avatar
An easier way to do this is to use a bicycle inner tube cut in half.
It's easier to clamp on both ends (being elastic) and already has a tyre valve attached to it.
Hasn't got a boost gauge but you can sure as hell hear any airleaks.
JohnA is offline   Reply With Quote
Old 03-12-2006, 03:31 PM   #13
VickSupra
Hoosier Daddy?
VickSupra's Avatar
Quote:
Originally Posted by KevinB6876
...... Instead, all I heard was the sound of air hissing from behind the engine and the hissing got worse the more I pumped. However, pressure remained at 0psi on the pump gauge and the boost gauge while the hissing was occurring.
I suspect this means that I have a bad boost leak. The noise is coming from somewhere behind the engine, but I can't find it! ......
Was the sound near the EGR valve? Mine did that.
But it does sound like a bad leak.
Is someone helping you? I found I needed help (more ears) in locating the leak.
Old 03-13-2006, 01:22 AM   #14
KevinB6876
SupraForums Member
I've got a friend coming over tomorrow to help me.
Old 03-13-2006, 01:24 AM   #15
KevinB6876
SupraForums Member
I didn't exactly understand. What do I do with the inner tube? Please explain in more detail, I'd like to know.
Old 03-13-2006, 02:57 AM   #16
JohnA
Misty and Wet
JohnA's Avatar
Here is a picture posted from another enthusiast in the UK Supra forum
Old 03-13-2006, 03:11 AM   #17
Boostinhard
Posts: n/a
yeah but that only checks intercooler pipes. how would you check the turbo piping or the intake manfiold ?
Old 03-14-2006, 01:03 AM   #18
KevinB6876
SupraForums Member
Ok fellas, here's an update.
A friend and I did the test again together and once again we got 0psi on the gauge and we heard the hissing noise. The friend noticed the hissing noise was coming from the EGR vacuum modulator (the valve with the green top that sits right on the top of the intake manifold next to the EGR valve). I also listened and verified it, the hissing noise was coming from inside the EGR vacuum modulator. Is this modulator supposed to be making a hissing noise when the system is pressurized? Is this normal? Vicksupra said he had a noise coming from near the EGR also, but he didn't elaborate. Is the EGR vacuum modulator leaking the pressure or is this noise normal?
After realizing that the noise was coming from the EGR vacuum modulator and suspecting the modulator might be bad and leaking the pressure, we disconnected the hose to the EGR vacuum modulator, bypassing the modulator, and did the pressure test again hoping that we could build pressure this time. Once again, 0psi was showing on the gauge, except this time we heard a hissing sound from the intake where the soup can was clamped. Suspecting that the soup can was leaking the pressure, we reinstalled the soup can into the intake to get a more firm fit and tightened the clamp on it even tighter than before. We then did the pressure test again using a 12V air compressor, and the soup can popped off the intake! lol.
At this point, we realized that the soup can wasn't holding properly into the stock plastic intake hose and was leaking pressure, so im ordering a boost leak tester from http://www.speedforsale.com/newparts...d35257368c53c4
and we're gonna try the test again. Hopefully this time the boost leak tester will hold the pressure dammit.
Old 03-14-2006, 05:20 PM   #19
KevinB6876
SupraForums Member
So guys, is the EGR vacuum modulator supposed to be making a hissing noise when the system is pressurized?
Old 03-14-2006, 08:39 PM   #20
house_of_senate
SupraForums Member
house_of_senate's Avatar
mine also makes the sound from the egr.
house_of_senate is offline   Reply With Quote
Old 03-15-2006, 12:48 AM   #21
KevinB6876
SupraForums Member
Quote:
So is this considered normal? Or does this mean that our EGR vacuum modulators are leaking?
If normal, shouldn't we disconnect the EGR vacuum modulator so that its hissing doesn't make it harder to hear other potential leaking noises?
Old 03-15-2006, 06:12 PM   #22
house_of_senate
SupraForums Member
i would also like to know if its normal or not...
Old 03-15-2006, 10:25 PM   #23
house_of_senate
SupraForums Member
yes it is normal.
Old 03-17-2006, 07:13 PM   #24
KevinB6876
SupraForums Member
yes it is normal.
Wait. How can you say its normal if you don't know if its normal and would also like to know if its normal or not?
Old 03-18-2006, 02:50 AM   #25
JohnA
Misty and Wet
JohnA's Avatar
this guy's mother thinks he's normal, but others beg to differ
(i.e. Define 'normal')
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by: Mvp Motorsports
Credit Card Processing
