R154 Swap Noise - Page 3
+ Reply to Thread
Page 3 of 3 FirstFirst 1 2 3
Results 51 to 72 of 72
Thread: R154 Swap Noise
  1. #51
    SupraForums Member
    Join Date
    Mar 2014
    Location
    Michigan
    Posts
    347
    Trans is pulled and ready to go back to DM. I drained the trans fluid and once again I have a ton of aluminum coming out. To have that much aluminum after 50-75 miles seems to be excessive and I wonder if one of the shift forks is out of spec or installed incorrectly. Anyone else get a Marlin crawler or DM modified r154 and seen this much aluminum?
    I noticed the clutch disc is wearing towards the outside against the flywheel and evenly on the pressure plate side. Anyone else seen this?
  2. Remove Advertisements
    SupraForums.com
    Advertisements
  3. #52
    SupraForums Member
    Join Date
    Mar 2014
    Location
    Michigan
    Posts
    347
    Update: DM pulled the trans apart and essentially found no issue with it. They indicated there was some countershaft wear, but nothing they hadn't seen before (pic attached). So, the trans shows up tomorrow and I'll reinstall it and not worry about the sound I'm hearing.
  4. #53
    SupraForums Member
    Join Date
    Mar 2014
    Location
    Michigan
    Posts
    347
    R154 Swap Noise
    Okay the trans is back in and now won't go in to any gear. I reached out to Aaron at DM and he indicated the the shift rods can move during shipping. Usually it's the reverse one. He recommended pulling the reverse light switch to inspect to see if the rod moved and then move it back.
    I pulled the switch and see a square piece of steel that is almost centered in the hole. I tried to move it but could not.
    Any ideas on how to fix this issue in the car?
  5. Remove Advertisements
    SupraForums.com
    Advertisements
  6. #54
    SupraForums Member
    Join Date
    Jul 2014
    Location
    United States
    Posts
    530
    Use a flat head to move it. Use a cloth to protect the threads.
  7. #55
    SupraForums Member
    Join Date
    Mar 2014
    Location
    Michigan
    Posts
    347
    Dumb question, but does it need to go toward the back of the car?
    I'm assuming if other shift rods moved then the transmission will need to be opened?
  8. #56
    SupraForums Member
    Join Date
    Jul 2014
    Location
    United States
    Posts
    530
    R154 Swap Noise
    In the R154, the reverse gear sits towards the plate, so push the lever back. Also, turn the driveshaft which will help. Do it with feel, not forcing anything.
    Since you can start the car and it is not trying to move when you crank, the trans is not in gear. The reverse gear is a straight cut kind of gear, it sits on a shaft and can move freely.
  9. #57
    SupraForums Member
    Join Date
    Mar 2014
    Location
    Michigan
    Posts
    347
    R154 Swap Noise
    The driveshaft is actually locked up. The engine does turn which tells me the trans is not in gear. I haven't started the car yet.
    There's not a whole lot of room to get a screw driver in there while the trans is installed. I tried lowering the tail of the trans, but don't think I can get it low enough.
  10. #58
    SupraForums Member Jostar's Avatar
    Join Date
    Aug 2004
    Location
    Chicago IL
    Age
    38
    Posts
    3,318
    Put the car in 1st gear, press and hold the clutch and try to start the car, if the car jumps foward, you have clutch problems.
    Maybe the TB clips came out? maybe the fork is not doing it's job?
    Getting out Boosted by Turbobozzer... for now...
  11. #59
    SupraForums Member
    Join Date
    Mar 2014
    Location
    Michigan
    Posts
    347
    R154 Swap Noise
    The car cannot go in to any gear. It appears the reverse shift rod moved during shipping from Driftmotion and it is stuck between gears. When I pulled the reverse light switch I could see the shift rod reverse light tab in the hole. So I'm trying to push it back in a confined space so I don't have to pull the trans again.
  12. #60
    SupraForums Member
    Join Date
    Mar 2014
    Location
    Michigan
    Posts
    347
    Okay I can't budge that SOB at all. Does it matter if the clutch is engaged or not? Why is the drive shaft locked up? The engine turns freely acting like it's in neutral.
  13. #61
    Join Date
    Aug 2004
    Location
    Chicago IL
    Age
    38
    Posts
    3,318
    Quote Originally Posted by Elibutton View Post
    It won't go into any gear with the motor running or motor off?
  14. #62
    SupraForums Member
    Join Date
    Mar 2014
    Location
    Michigan
    Posts
    347
    Motor off.
  15. #63
    Join Date
    Aug 2004
    Location
    Chicago IL
    Age
    38
    Posts
    3,318
    Trans needs to be opened to get it fixed.
  16. #64
    SupraForums Member
    Join Date
    Mar 2014
    Location
    Michigan
    Posts
    347
    Okay pulled the trans and popped the reverse rail back in place with a screw driver. Everything works! Trans is back in the car.
  17. #65
    SupraForums Member
    Join Date
    Mar 2014
    Location
    Michigan
    Posts
    347
    Just closing the loop on this saga. R154 is back in for the 4th time and it's running smooth. It does make a slight sound at idle that my OCD can hear, but it functioning perfect.
  18. #66
    SupraForums Member plaaya69's Avatar
    Join Date
    Jun 2007
    Location
    Waukegan, IL
    Posts
    781
    Good to hear everything worked out for you.
    87 Turbo Supra - Daily Summer Cruiser
    87 Non-Turbo Supra - Sold
    04 GS300 - Daily Driver
    2019 Updated Build Thread - https://www.supraforums.com/forum/sh...ore&highlight=
  19. #67
    SupraForums Member
    Join Date
    Mar 2014
    Location
    Michigan
    Posts
    347
    Thanks!
  20. #68
    Join Date
    Jul 2017
    Location
    Milwaukee
    Posts
    2
    Reviving this thread. Mine does the exact same thing. Did you ever figure the cause of this noise?
  21. #69
    Join Date
    Jul 2017
    Location
    Milwaukee
    Posts
    2
    Bump!
  22. #70
    Join Date
    Jun 2007
    Location
    Waukegan, IL
    Posts
    781
    Quote Originally Posted by Tonyl86 View Post
    Post #64
  23. #71
    SupraForums Member
    Join Date
    Mar 2014
    Location
    Michigan
    Posts
    347
    No I never did. Sent it back to driftmotion and they tore it down again and found nothing. It shifts smooth, but still makes the same noise. Noise seems to lessen after everything warms up. It fucking annoying to hear that noise over the idling engine sound.
    Please provide more detail on your scenario. Are you using a CM FX400? Rebuilt by DM? Wondering if there are some common things between our set ups?
  24. #72
    SupraForums Member
    Join Date
    Mar 2014
    Location
    Michigan
    Posts
    347
    Bump!
    Tony, sorry I missed your post. Quoting you so you can see my response.
+ Reply to Thread
Quick Reply Quick Reply
Register Now
List your Car(s)
Where you live
Log-in
Similar Threads
  1. R154 noise
    By shaodome in forum MKIII (1986.5-1992)
    Last Post: 04-06-2017, 07:03 PM
  2. WTB MK3 Turbo Driveshaft for R154 for my 1UZFE+R154 Swap
    By Sezio31 in forum For Sale/Wanted
    Last Post: 07-29-2009, 09:33 AM
Posting Permissions
  • You may post replies
  • You may not edit your posts
