Introduced late 2017 the new Manley Turbo Tuff pistons are the latest generation of shelf pistons by Manley for the 2JZ platform. These pistons are a fantastic set of shelf pistons for anyone running a Precision 7675 all in or smaller turbo(~1250rwhp max). You will not find another set of equally equipped pistons that are normal shelf stock without placing a custom order and waiting 4-6 weeks from any manufacturer. These come standard with an array of options such as:
- Vertical Gas Porting(ideal for vehicles running Ethanol fuel)
- .250 wall wrist pins
- Skirt Coating
- Machine Strutted Pin Piers
- Increased Deck Thickness
If you are in the midst of an engine build and unsure what pistons to choose these are the best bang for the buck set you can get your hands one without waiting weeks. We can pair these up for you with any set of rods, steel or aluminum, to match your power goals as well as bearings, studs and gaskets to wrap up the entire build.
Price - $1156.76 SHIPPED anywhere in the 48 states
Available for 86mm and 94mm stroke in 9.0:1 or 10.0:1 compression ratios. Bores in .25 increments from 86.25mm up to 87mm.
Contact us today to secure your set!
Robert
