Idle control
Results 1 to 4 of 4
Thread: Idle control
    Jul 2017
    Australia
    9
    Idle control
    are there any part/part number gurus that would know if the 1fz fe and the 1jz or 2jz idle controls are the same or at least the same bolt pattern /flange?i need to convert to 2 wire iac for and aftermarket ecu and was hoping to use the supra kit thats floating around.any help apreciated.regards Dale
    Sent from my SM-N950F using Tapatalk
    SF Vendor Member Robert@RSP's Avatar
    Jun 2016
    Justin, Tx
    32
    348
    Hello,
    From what I can see of both IACV's from the 1FZ and 2JZGTE engines they do not look to be the same sensor unfortunately. You would purchase just the adapter flange from PHR and see if it bolts one but would have no way to know if the flange specs are the same. If you want to measure the flange out I can send it to PHR to see if theirs is the same.
    Robert
    www.RealStreetPerformance.com
    Email: [email protected]
    Work: 407-695-7223 x122
    Cell (Whatsapp / Text / iMessage): 321-295-4728
    Jul 2017
    Australia
    9
    Quote Originally Posted by [email protected] View Post
    Hello,
    Robert
    Thanks robert I'll take some measurements
    Jun 2016
    Justin, Tx
    32
    348
    Sounds great!
    Robert
  1. Replies: 3
    Last Post: 02-25-2016, 08:48 AM
  2. NA high idle problem cured w/o buying idle control valve
    By TheProPilot in forum Naturally Aspirated
    Last Post: 07-06-2008, 11:57 PM
  3. Idle control screw? need to raise the idle.
    By twinturbozs in forum MKIV (1993-1998)
    Last Post: 04-20-2007, 10:57 PM
  4. A/F idle way rich at idle! Ideas?
    By dg_performance in forum Naturally Aspirated
    Last Post: 11-21-2006, 10:44 AM
  5. *help/urgent* Stalling at idle (idle dropping)
    By SupraPolak in forum MKIV Technical
    Last Post: 04-22-2005, 08:01 PM
