Who Has The Quickest Spooling 500-600RWHP Single Supra On Pump Gas?
+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 25 of 39
Thread: Who Has The Quickest Spooling 500-600RWHP Single Supra On Pump Gas?
  1. #1
    SupraForums Member
    Join Date
    Jun 2014
    Location
    Top Secret
    Posts
    200
    As my research into going single continues I would like to hear from members who are in the 500-600RWHP bracket, who only use pump gas. Ideally 94 but 93 would be just as good.
    Spec along with dyno printouts would be ideal.
    Thanks.
  2. Remove Advertisements
    SupraForums.com
    Advertisements
  3. #2
    SupraForums Member
    Join Date
    Jul 2009
    Location
    Winnipeg, Manitoba
    Posts
    185
    Following.
    Sent from my SM-G955W using Tapatalk
  4. #3
    SupraForums Member 57trimMKIII's Avatar
    Join Date
    Jun 2010
    Location
    Roanoke, TX
    Posts
    2,646
    A turbo that is capable of 500-600 whp on pump gas (limited to < 20 psi) will be much larger and therefore not spool as quickly as a smaller turbo that would easily be capable of the same power at higher boost levels on E85. If you're searching for a quick spooling setup I feel you'd be better off running a log style manifold, smaller turbo (i.e. 6266) and E85 making 500-600 whp at 20+ psi.
    I am currently making 460 whp on pump gas (16 psi) with a PHR log style manifold and JB PT6266
  5. Remove Advertisements
    SupraForums.com
    Advertisements
  6. #4
    SupraForums Member
    Join Date
    Feb 2014
    Location
    toronto
    Posts
    230
    im on pump 6266 JB make 530 whp on stock cams , and cast iron manifold 23psi did spool 3500-3700
    on new cams 262 with tubular manifold the same 23psi made 642 whp i have lost 5-600 rpm 4-4200
    fun to drive
  7. #5
    Garage Queen Club dre99gsx's Avatar
    Join Date
    Oct 2001
    Location
    Somerset, NJ
    Posts
    2,800
    I have the quickest spooling single on a "supra" on pump gas.
    You can read about my specs and dyno if you click on my Z4 build thread. Plenty of youtube videos of the car at the track showing you spool characteristics (search 2jz z4 on youtube). 600whp/500wtq - stock engine, can handle the abuse of road coarse. BW 60mm turbo.
    Andre
    2JZ in a BMW Z4 Project -> https://www.supraforums.com/forum/sho...1-BMW-Z4-Build
    PTE6768 RSP MKIV - 845whp/Pump/Meth -> http://www.youtube.com/watch?v=C6HEN...eature=related
    Start your supra with a push button -> http://www.youtube.com/watch?v=2n6F-owxgyY
    "I'd rather be a famous drunk than an anonymous alcoholic..."
  8. #6
    Game Over Boost Wang's Avatar
    Join Date
    Apr 2008
    Location
    Portland OR
    Age
    27
    Posts
    1,146
    503whp, and peak boost of 14psi at about 3,500 rpm.
    Stock block, modded plenum intake manifold, 264 cams, bowl work in cylinder head. FP HTA35R 0.82A/R
    Pump 92 octane.
    -Sam
    1993.5 White turbo hardtop. 1 of 26
  9. #7
    Moderator
    l337 M0d3r4t0r
    ZaZZn's Avatar
    Join Date
    Feb 2002
    Location
    Toronto/San Francisco
    Age
    36
    Posts
    12,082
    Well, on stock twins at 20 PSI I made 430whp/450tq, I mean if you add cams you are almost to your lower number nothing spools faster than the sequential IMO. Especially if you are on ceramic twins like me, i have 10 PSI on the first twin at 2000 RPM 15 by 2300 in 5th. Car is real fun on stock twins.
    You'll need at least a 61MM turbo to get you to your goals, the thing that you will want to look at is getting a mismatched wheel.
    Meaning getting a 61mm compressor wheel with a small exhaust wheel so that you can spool faster and sacrifice some top end flow. (kind of irrelevant because to max out your 61 you could get to 700-750 WHP)
    Eric W
    87 TT E85
    91 T 60k miles
    98 SC 300
  10. #8
    NiSmO [email protected] supergoji's Avatar
    Join Date
    Sep 2006
    Location
    westchester NY
    Age
    30
    Posts
    491
    Quote Originally Posted by Boost Wang View Post
    Pump 92 octane.
    What manifold?
    What size intake tube diameter
    What size downpipe and exhaust
    Why only 14? you could jack it up another 8-10lbs...
    Quote Originally Posted by dre99gsx View Post
    you're on 70/30 meth. He was asking for straight pump.
    I'm also seeking a wide powerband and superfast spool. I was looking at the GTX3582 , 6466 and 8474.
    I believe the G42-1200 series turbos may end up displaying great spool characteristics. I'm looking to see what the efr8474 can do.
    Quote Originally Posted by OOBE View Post
    the shop power fucked you at 140 mph too :D
    Quote Originally Posted by x X CLoud X x View Post
    why the Hell is there a FUCKN SAILOR MOON ON A SUPRA!!!
    Quote Originally Posted by SupraLB View Post
    Was it over when the Germans bombed Pearl Harbor?
    Quote Originally Posted by wreckless View Post
    hell, he has a better chance of getting gov't funding to build the playboy mansion into an orbital launch vehicle to set a new record of nonstop consecutive orbital blowjobs from playboy playmates.
    94 Alpine Silver Supra TT 6spd ( for sale) https://www.cargurus.com/Cars/l-Used...ting=234504432
    91 Cherry Red Pearl Z32 TT 6spd
  11. #9
    SupraForums Member FirstStateCamber's Avatar
    Join Date
    Feb 2007
    Location
    Delaware
    Age
    40
    Posts
    1,244
    My old setup, 6266, cast manifold, QSV, stock long block made 565whp and was a tire fryer. Only concern was the life of the rods since the boost hit super fast and hard. FUN setup for sure!
  12. #10
    SupraForums Member
    Join Date
    Apr 2017
    Location
    MA
    Posts
    217
    Quote Originally Posted by FirstStateCamber View Post
    Holy shit that thing must of spooled stupid fast.
    What kind of spool time can I see with a JB 6766 on pump gas stock long block, Tubular manifold, divided turbo housing .84ar. ?
  13. #11
    Wheel Whore SupraWillis's Avatar
    Join Date
    Mar 2003
    Location
    UT
    Age
    38
    Posts
    2,208
    My setup spools too fast as ridiculous as that sounds. I am on a Precision 6266 DBB on a cast manifold and 264 cams through a built auto with a 4K stall. I have tried a few different wastegate setups with 1 BAR springs and at wastegate pressure I am still hitting 19-21 PSI spikes on 91 octane. I think this is too much on my rods and feel as if my motor is a time bomb. Going to do a built short block this winter with billet mains and going back to a big lazy turbo.
    My old and current favorites.
    Old:
    https://www.youtube.com/watch?v=r-KrBytvXLE
    Current:
    04 Porsche GT3
    87 Mazda RX-7 Turbo II
    93.5 Premier Edition Original TT
    Poopra by Jeff Willis, on Flickr
  14. #12
    SupraForums Member CasperMK2's Avatar
    Join Date
    Mar 2010
    Location
    Area51
    Posts
    540
    Quote Originally Posted by SupraWillis View Post
    It should be insane with the 4K stall indeed! How do you like the stall?
    Wouldn't a 3200-3500 stall match better with the 6266?
    Casper
    1996 Toyota Supra Turbo
  15. #13
    Join Date
    Mar 2003
    Location
    UT
    Age
    38
    Posts
    2,208
    Quote Originally Posted by CasperMK2 View Post
    Casper
    I didn't mind it at all. Boost was like an on/off switch as soon as you hit the throttle. I am doing a manual swap at the moment but it has been the best auto setup I have had.
  16. #14
    SupraForums Member
    Join Date
    Nov 2010
    Location
    Toronto
    Posts
    105
    605 HP
    520 TQ
    23PSi @ 94 octane.
    GT40R
    Tomi Pncaf cams
    9:1 compression CP pistions
    SP manifold
    3" exhaust/down-pipe (too restrictive)
    with a 3" core intercooler(now upgraded to 4")
  17. #15
    Unlimited Time Attack A70 Twin2Turbo's Avatar
    Join Date
    Nov 2007
    Location
    Mill Creek, Wa
    Posts
    3,540
    thread followed by who makes the best rods and main caps
    -Nick
    1JZ|Link|Precision|Brembo|DBA|Tilton|Carrillo|Diamond|InjectorDynamic|TurboSmart|Technico|ATI|BC|HKS|And Everything Else|
    My Build Thread <-> Www.projecthighrpm.com
  18. #16
    Join Date
    Apr 2008
    Location
    Portland OR
    Age
    27
    Posts
    1,146
    Quote Originally Posted by supergoji View Post
    What manifold?
    PHR intake manifold
    4in intake
    4in DP/Exhaust
    We didn't want to push pump gas numbers. It is right in the efficiency range, and because of the IM, and cylinder head, we didn't need as much boost to make the peak ##'s, not to mention, it is a very small turbine for this motor. The car only makes 630 maxed out on E85 on 22 psi, but it is very responsive.
  19. #17
    Stock Twins King Stu Hagen's Avatar
    Join Date
    Jan 2002
    Location
    Kirkland, Wa.
    Posts
    4,315
    Here is comparison dyno on my GT28 twins over a OEM Twins.
  20. #18
    Join Date
    Nov 2017
    Location
    N/A
    Posts
    28
    dp
  21. #19
    Join Date
    Nov 2017
    Location
    N/A
    Posts
    28
    Quote Originally Posted by markk View Post
    fun to drive
    I have a similar setup to this now. But its a .68 ar non divided turbo housing, but divided manifold.
    Its not tuned atm, running stock ecu with maf and no boost controller. just running on the wastegate spring (smallest one).
    Full boost seem to be around 4500 rpm. boosting 13-14.5 psi
    6766jb CEA gen1, .68ar
    tube mani
    4" dp and md to 3" back
    tial 44mm wastegate
    greddy 3row ic¨
    Im looking forward to get this setup tuned
  22. #20
    Join Date
    Feb 2007
    Location
    Delaware
    Age
    40
    Posts
    1,244
    Quote Originally Posted by Scalla1384 View Post
    After I was 6266 I went 6766, stock long block, cast manifold, 1.0 undivided. There is some lag but not much at all and it very fun on the street. I like the 6766 so much so that I am now going 10.5:1, built VVTi head, Billet S2's, billet mains, BC rods, etc... This car should feel like a blown V8 once I am done, haha!
    93' PTE6766, Cast Mani, QSVHD, 1260cc, Stock Cams, Pro-EFI, CM850 twin-disk, 4" turbo back, HKS Carbon Ti...
    09' 997.1TT 6spd, GT2 VTG's, UMW tuned
    15' Audi S5, APR Tuned, Intake/Exhaust
    Follow me on IG: @FirstStateMKIV
    Decorative SUPRA Metal logos - https://www.supraforums.com/forum/sh...gns&highlight=
    MKIV Fire Extinguisher Brackets -https://www.supraforums.com/forum/sh...dmin-Approved)
  23. #21
    Join Date
    Oct 2001
    Location
    Somerset, NJ
    Posts
    2,800
    I provided an example with real world use (not just a dyno pull with random highway pulls). To run 600wheel on a roadcoarse will test the limits of everything, and sadly Meth/water is necessary in my case. I will start counting knock on 90+deg weather without it, especially no the long straights of the track.
    If you wish to run 600wheel on my setup/combo with random highway pulls in cool weather, Im' sure you can get away without the meth!
    What manifold?
  24. #22
    SupraForums Member
    Join Date
    Jun 2014
    Location
    Top Secret
    Posts
    200
    Some really nice info posted so far, im really interested in what the cars are producing under 4,000RPM and how long the power lasts.
    6266 or GTX3582R is as big as I want to go, has anyone changed A/R to improve top end and noticed much of an impact in spool?
    dre99gsx - Your thread is great but unfortunately all the photos are dead.
    Boost Wang - Any videos or further spec?
    SupraWillis - Do you have any videos of the car being used in anger that your can post up?
    CzA - your set up sound very interesting.
    Twin2Turbo - I love your thinking.
  25. #23
    handy with the steel CDSaints's Avatar
    Join Date
    Feb 2009
    Location
    Louisiana
    Age
    36
    Posts
    304
    What kind of racing are you planning on doing with a Supra that you're concerned with power output below 4k? I understand the desire not to have a peaky lag monster turbo on a street car, but something like a 6466 up to a 6870 should come on around 4-4.5k, and with valvetrain upgrades you can rev it out to 7.5-8k. That's a nice broad powerband, just select the appropriate gear.
  26. #24
    Join Date
    Oct 2001
    Location
    Somerset, NJ
    Posts
    2,800
    Now that's weird. All the images are hosted (you can see one of them here: http://benchraces.com/img/z4build/20160709_201114.jpg), and I have another forum using the [img] tags with no issues. I wonder if Supraforums restricts linking images from certain sites
    Sorry... don' t know how to fix that one. The were working fine not too long ago!
    Now speaking of power before 4k, my peak torque of 500wheel is right about 4k-ish, and it's too much. Corner exits with that power require good large sticky tire. I actually leave it one gear higher so I can hit it below peak torque to allow the power to ease on. Something to consider... a bit lag isn't too bad of a thing sometimes with a huge power increase.
    Quote Originally Posted by Ben_R View Post
  27. #25
    Join Date
    Apr 2013
    Location
    United States
    Posts
    1
    video
    Relevant?
    All I know is what I see.
    Oh, and Trevor from MotionAutoTv
    -gc
+ Reply to Thread
Quick Reply Quick Reply
Register Now
List your Car(s)
Where you live
Log-in
Similar Threads
  1. Smallest, quickest spooling 2835's
    By Dirk Diggler in forum MKIV (1993-1998)
    Last Post: 03-01-2004, 06:52 PM
  2. quickest spooling turbo to do 650rwhp on turbo alone...
    By hobbzz in forum MKIV (1993-1998)
    Last Post: 03-09-2003, 04:33 PM
Posting Permissions
  • You may post replies
  • You may not edit your posts
