ABS and Brake Issue
+ Reply to Thread
Results 1 to 11 of 11
Thread: ABS and Brake Issue
  1. #1
    SupraForums Member daviddi92's Avatar
    Join Date
    Dec 2011
    Location
    NW Suburbs, IL
    Posts
    509
    ABS and Brake Issue
    I am having a few different brake system issues. Not sure if they are related or not but I will explain what has been happening.
    I am getting a ABS code 61. I followed the procedures in the TSRM and nothing seems to really help. Because of this I don't have abs. But the weird part is I don't have any lights on the dash.
    I do have Proefi installed and removed the Trac ecu that is in the passenger footwell. But this seems to be a normal part of the procedure so this shouldn't have caused any issues.
    I also have 3 wheel speed sensors wired to the ABS for the Proefi traction control, as well as 3 wires wired to the Trac ecu plug to use the Trac indicator, Trac On/off button, and light.
    I still have the factory trac actuator pump in the car.
    I have a new OEM rotors, Hawk HPS front pads, and oem rear pads, and stainless brake lines.
    The brake pedal feels like no matter how hard I push the pedal it still doesn't slow the car down like it should. Seems like bad brake fade or really cold brake pads with no initial bite at all.
    Could this be glazed pads, booster, or master cylinder?
    Or, is somehow all of this related to one another?
    I miss having sensitive brakes.
    TIA!
    David
    94' Single Turbo 6 Speed
  2. Remove Advertisements
    SupraForums.com
    Advertisements
  3. #2
    Boost Junkie 1A1's Avatar
    Join Date
    May 2003
    Location
    Indiana
    Age
    45
    Posts
    12,230
    Blog Entries
    1
    Things to check:
    Did you insert the resistor in the Trac plug near the master cylinder?
    Have you pulled all of your ABS sensors to see if one may have debris (metal) on them?
    These are 2 things that happened to me that caused similar issues. Once corrected all was well.
    Steve
    1993.5 Anthracite 6 SPD//PRO EFI//PTE6766//3-Row//E-85Fuel Sys//PHR I/M//GSC//IP 10/1 motor//Manley//RPS C/C//CCW C14//Brembo BBK//TRD LSD//930WHP/38PSI
    2009 BMW 535i Sport FBO
    2011 Land Cruiser
  4. #3
    Join Date
    Dec 2011
    Location
    NW Suburbs, IL
    Posts
    509
    Quote Originally Posted by 1A1 View Post
    Things to check:
    Steve
    Hi Steve,
    I still have the Trac pump with everything hooked up. Am I suppose to disconnect the trac pump connector as if I was deleting it with the 10k ohm resistors?
    I also have not checked the abs sensors for any debris. I will definitely give that a look over as well.
    I believe code 61 is "open or short in THFA, TRCO circuit ABS & TRAC ECU, TRAC ECU"
    Not sure if any of this is causing my horrible braking performance or if it might be glazed pads or faulty booster pump. I checked the booster pump one way check valve on the vacuum line and that works fine.
  5. Remove Advertisements
    SupraForums.com
    Advertisements
  6. #4
    Join Date
    May 2003
    Location
    Indiana
    Age
    45
    Posts
    12,230
    Blog Entries
    1
    The TRAC system won't work without the ECU. Just remove everything and use the resistor. Also, if you have debris in one of the magnetic pick ups, it will cause that code. I had the same issue. Be sure to bleed the brakes once you remove the TRAC pump, etc and protect your paint gains the brake fluid.
    Steve
  7. #5
    Join Date
    Dec 2011
    Location
    NW Suburbs, IL
    Posts
    509
    I'll find some time this week to remove the TRAC system and check the abs sensors for any debris stuck to them. I will report back after that's done and brakes are bled if it changes anything.
    David
  8. #6
    Join Date
    Dec 2011
    Location
    NW Suburbs, IL
    Posts
    509
    Update: I cleaned every wheel speed sensor as there was a ton of debris on every corner. Then deleted the trac pump and actuator, and while I was at it I upgraded to the 98' master cylinder. Rebled the brakes and adjusted the brake booster adjustment rod, now the brakes grab extremely hard right off the top of the pedal. I couldn't believe what a difference adjusting that rod going into the master cylinder made. The pedal was so mushy and would depress halfway before starting to brake.
    Oh, and my ABS works now too!
  9. #7
    Join Date
    May 2003
    Location
    Indiana
    Age
    45
    Posts
    12,230
    Blog Entries
    1
    Quote Originally Posted by daviddi92 View Post
    There you go! Great news that all is well now.
    Steve
  10. #8
    Join Date
    Dec 2011
    Location
    NW Suburbs, IL
    Posts
    509
    Steve
    Thanks Steve! Didn't even think to check the wheel speed sensors like you mentioned.
  11. #9
    SupraForums Member mkivsoopratt's Avatar
    Join Date
    Jun 2010
    Location
    South Florida
    Posts
    791
    Did you adjust the rod at the brake pedal to booster or the rod from booster to master?
    “Lag is foreplay” - Biologist
    1995 Toyota Supra Single Turbo 6 Speed Hardtop VVTI
    1991 Nissan Skyline R32 GTS-T 5 speed
    2017 Toyota Tacoma V6
  12. #10
    SupraForums Member T6Rocket's Avatar
    Join Date
    Mar 2002
    Location
    Raleigh, NC
    Posts
    4,165
    Quote Originally Posted by mkivsoopratt View Post
    I also have the same question because I didn't know there was an adjustment for that. I do know that an adjustment at the brake pedal can leave you with the brake light on because I tried it one time. Also, on an automatic, if the brake light is on, the torque converter won't lock up.
    Side question, I occasionally get the ABS light on. Usually, a restart gets rid of it, and it has never been on more than one start-up (knock on wood).
    Al
    94TT Auto, 6466
    [email protected] 27 psi 4/16/16
    Previous setup: HKS Twin 2835's
    [email protected] 32 psi, 10/29/06
    Previous car: 90 Talon AWD, 5 spd, FP Red (60-1)
    [email protected] built motor, 28 psi, Sept 2000
  13. #11
    Join Date
    Dec 2011
    Location
    NW Suburbs, IL
    Posts
    509
    There is an adjustment rod at the brake pedal to booster, but that only sets pedal height and free play.
    If you pull off the master cylinder by loosening the two nuts and pulling it up over the booster, there is another adjustment rod. Basically this rod sets the gap between where the brake booster rod gets pushed out by the pedal, until the point where it actually contacts the master cylinder. You want this gap to be as close as possible without your brakes dragging. You will need a 7mm wrench and a small vice grip to hold the rod from spinning while adjusting this rod.
    It took me 4 years of chasing poor braking performance to figure this out.
+ Reply to Thread
Quick Reply Quick Reply
Register Now
List your Car(s)
Where you live
Log-in
Similar Threads
  1. Replies: 2
    Last Post: 12-03-2015, 03:50 AM
  2. Replies: 5
    Last Post: 03-17-2011, 09:15 PM
  3. ABS vs. Non-ABS Brake master cylinders the same???
    By Steady Boostin' in forum MKIII Technical
    Last Post: 09-29-2005, 08:57 AM
  4. 87 toyota supra ABS or no ABS
    By t1ger_mkIII in forum MKIII (1986.5-1992)
    Last Post: 05-18-2003, 06:57 PM
Posting Permissions
  • You may post replies
  • You may not edit your posts
