Spec Hydraulic release bearing issue
+ Reply to Thread
Results 1 to 4 of 4
Thread: Spec Hydraulic release bearing issue
  1. #1
    I have a twin plate carpon spec clutch on my 6 speed MKIV & i had replaced two spec hidrolic release bearing so far as it was always leaking, now i wanted to buy a Tilton release from Power house racing but they have told me that its confirmed that it works only with the mini triple clutch & they did not tryed it on a twin plate, have anyone used it or have a solution for my issue ?
    Please refer to PHR Tilton release link below:
    https://www.powerhouseracing.com/pro...le-disc-clutch
  2. Remove Advertisements
    SupraForums.com
    Advertisements
  3. #2
    7M Fanatic sixpack's Avatar
    Join Date
    Jun 2006
    Location
    San Antonio, Texas
    Age
    66
    Posts
    2,978
    Wrong section friend.
    Oh, and it's 'hydraulic'
    Sorry, no answer for your question, as I only use clutches from people like Tilton, OS Giken, Quartermaster, etc..
  4. #3
    Super Moderator Wreckless's Avatar
    Join Date
    Feb 2002
    Location
    Albuquerque, NM
    Posts
    9,898
    Quote Originally Posted by Ali_93 View Post
    With stuff like this, you're going to have to experiment a bit. The fact that PHR made a specific new part to replace the SPEC component tells me it's a known issue.
    According to the link you posted, PHR says it works on the twin plate. Worst case, if you decide to give up on that clutch, you can sell it for a bit more $ with a brand new PHR release bearing system.
    If it were my decision to make, I'd try the PHR unit and if it doesn't work perfectly, talk to PHR about it and work through it with them. They're pretty good about backing up their stuff.
    Quote Originally Posted by sixpack View Post
    Judging by the syntax, it's likely English isn't his first language. Plus he's already tried to solve the problem himself, so let's cut him some slack.
    Jeff
    "I spent a lot of money on booze, chicks and fast cars. The rest I just squandered." -- George Best
    Quote Originally Posted by KING View Post
    Who would have ever thought.....the impact an automobile can make.....
  5. Remove Advertisements
    SupraForums.com
    Advertisements
  6. #4
    SupraForums Member
    Join Date
    Nov 2007
    Location
    RR, NM
    Posts
    589
    Chances are if it works for the triple but not the twin it'll be a piston length issue.
    Not overly familiar with the SPEC release bearing (other than the fact that they fail often) but it appears to be a standard 44mm release diameter. Have access to one of the SPEC release bearings so you can measure the diameter of the contact surface on the bearing?
    If it's a 44mm Tilton makes many different lengths of pistons so it would be pretty easy to get the right piston for it to make it work with the twin disk.
+ Reply to Thread
Quick Reply Quick Reply
Register Now
List your Car(s)
Where you live
Log-in
Similar Threads
  1. Spec Hydraulic release bearing issue
    By Ali_93 in forum Forum Problems & Suggestions
    Last Post: 01-24-2019, 09:42 PM
Posting Permissions
  • You may post replies
  • You may not edit your posts
