BC 264 cams?
+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 25 of 26
Thread: BC 264 cams?
  1. #1
    SupraForums Member
    Join Date
    Jun 2011
    Location
    Littleton Colorado
    Posts
    91
    BC 264 cams?
    I had my engine built about 3-4 years ago and had purchased a parts car to rebuild that engine so that I could still drive the car in the meantime. I knew that the car had some upgrades done but never really new the extent of them. I recently contacted them about making some additional upgrades such as turbo and cams based on advice received from members here. When I had mentioned upgrading the cams to the shop and they all were pretty sure that I already had the stage 2 bc cams, but if I do it would be from the original owner of the engine.
    I feel like I might already know the answer to this question but is there a way to tell other than removing the valve covers and looking?
    Such as me posting audio of the car at idle?
  2. Remove Advertisements
    SupraForums.com
    Advertisements
  3. #2
    Question to suit. 220's Avatar
    Join Date
    Dec 2002
    Location
    Abalama
    Posts
    3,550
    Open up the covers and take a good look.
    Only way to be sure.
  4. #3
    SupraForums Member plaaya69's Avatar
    Join Date
    Jun 2007
    Location
    Waukegan, IL
    Posts
    781
    There should be some marking all the way in the back of the cam at the end of cylinder 6, at least that is how my BC 264 cams were. Here is how they looked new with the green and orange marking and you can barely see the marking on them which might help you:
    87 Turbo Supra - Daily Summer Cruiser
    87 Non-Turbo Supra - Sold
    04 GS300 - Daily Driver
    2019 Updated Build Thread - https://www.supraforums.com/forum/sh...ore&highlight=
  5. Remove Advertisements
    SupraForums.com
    Advertisements
  6. #4
    SupraForums Member
    Join Date
    Jun 2011
    Location
    Littleton Colorado
    Posts
    91
    Quote Originally Posted by plaaya69 View Post
    What exactly is the marking that I am looking for if the orange and green markings are gone?
  7. #5
    On the very back of the cam it should be stamped with letters and numbers (INT for intake and EXH for exhaust). I can’t remember if it’s on the circumference or flat of the back, but that’s where to look.
  8. #6
    SupraForums Member
    Join Date
    Jun 2011
    Location
    Littleton Colorado
    Posts
    91
    I am going to open up the valve covers this weekend to see exactly what I have. Seeing as there is less than 5,000 miles on the ones installed without leaks should I plan on just reusing or should I just plan on replacing?
  9. #7
    7M Fanatic sixpack's Avatar
    Join Date
    Jun 2006
    Location
    San Antonio, Texas
    Age
    66
    Posts
    2,955
    Read the TSRM before installing the cam covers, or you WILL have leaks.....
  10. #8
    Join Date
    Jun 2007
    Location
    Waukegan, IL
    Posts
    781
    Around 3:37 you will see some of the markings on the 7m BC Cams
  11. #9
    Join Date
    Jun 2006
    Location
    San Antonio, Texas
    Age
    66
    Posts
    2,955
    About all that BC cams are worth......
    Sorry for those of you who have BC, but I still have a sour taste in my mouth after being part of the first release of Brat Crower's first 7M cams, and his bull shit attitude when I called him about the shit he sent me.
    Also wondering what you left behind ?
    Aftermarket rods, or pistons ?
  12. #10
    Join Date
    Jun 2007
    Location
    Waukegan, IL
    Posts
    781
    Quote Originally Posted by sixpack View Post
    I know the exhaust ring gear not lining up properly for the CPS on a bad batch of BC cams was a nightmare for some 7m owners in the past. The 264 cam set I bought new in 2017 have been good and pack a nice midrange punch I was looking for. I would have probably went with some one else but that was all I can find for a new set. Do you have any other recommendations on cams besides a regrind?
    That video is just a channel I am subbed to but he got very lucky with that find.
  13. #11
    Join Date
    Jun 2006
    Location
    San Antonio, Texas
    Age
    66
    Posts
    2,955
    No economical options.
    Once in a while a set of used Toda, or HKS, or Jun cams pop up in Japan, but they will go for a grand.
    There is a cam guy in Canada that will make billet new ones for two grand, about what I sold the TRD Group-A cams I had went for.
    (still regretting selling the 288 set)
    If your willing to put up with the BC problems, that is a great find.
    Regrinds suck ass due to the need to run extra thick (and heavy) shims, and thee fact that they still only hold the valves around fully open for the same duration as stock cams. A 264 cam that was cut from a stock cam will not make the power that a true 264 cam.
    I got around the issue of thick shims by running custom valves with longer stems, but they are stock diameter.
    They are still sitting here, and if anyone wants them, I'll sell them cheap, as I only run big valves now, and sold my Schneider regrinds.
    On the BC cam issues, it wasn't just the out of phase timing gear.
    Other issues were rough, uneven edges on the lobes, inconsistent journal diameters, which lead to some people ruining their head when the cams locked up, and the oil grove being way to wide on the intake cam, lessoning the actual bearing support area, leading to bearing surface wear on the head.
    And yes, 264s are good to about 7000.
  14. #12
    SupraForums Member
    Join Date
    Jun 2011
    Location
    Littleton Colorado
    Posts
    91
    Would you just recommend using cygnusx1?
    I would also be interested in any trick/tips for members that have done it before.
  15. #13
    Canada, Eh? Enraged's Avatar
    Join Date
    Oct 2001
    Location
    Victoria, BC, Canada
    Age
    37
    Posts
    2,392
    It's not that complicated. Use a new gasket, put RTV in the corners at the front where the covers go over the cams, and throw the stock hardware in the garbage. Replace them with hex head bolts and lock washers.
    About the cam regrinds, I spoke with Colt Cams, and he suggested using lash caps to make up the distance lost to the regrinding. I figured some 40 thou lash caps and new shimless buckets would fix the valve clearance issues, get rid of the risk of spitting shims, and take a bunch of weight out of the valvetrain. There is also Shadbolt Cams, i haven't spoken to them yet. Both companies are near Vancouver BC Canada. FYI, Colt Cams sells their top 7M regrind for CDN$475. Downside is as sixpack mentioned, but at the cost of about a third of a new BC cams, I'd say it's worth it.
    88 Turbo, Burgandy
    Shiny makes you faster!
  16. #14
    2JZA70 SDstreetracer's Avatar
    Join Date
    Dec 2001
    Location
    San Marcos, CA
    Age
    37
    Posts
    2,525
    Toda has one set of cams left for the 7M. After that they are gone for good. $1500 for the set so they aren’t cheap but if someone wants the real deal there you go.
    91 Black 7mge auto
  17. #15
    Join Date
    May 2011
    Location
    Auckland, New Zealand
    Posts
    11
    I also down vote bc cams, sent months trying to degree them in, but they just dont match the cards for duration. My bc264 came in at 211degree at 50" (should have been 220) and at over 300degree at 01"...
    Idle has around 8 to 11 inch of vacuum. Doesn't matter much if I advance or retard.
    Sent from my SM-G930F using Tapatalk
  18. #16
    Join Date
    Jun 2006
    Location
    San Antonio, Texas
    Age
    66
    Posts
    2,955
    I have a set of TODA shim under buckets, sort one retainer (or was it the bucket - I would have to check), and since they are the same as the 4AG, TODA should have replacements.
    Sell them cheap.
  19. #17
    Join Date
    Dec 2002
    Location
    Abalama
    Posts
    3,550
    The centerline's on BC cams just weren't consistent for a few folks.
    I went with Kelford for that reason.
  20. #18
    Join Date
    Jun 2006
    Location
    San Antonio, Texas
    Age
    66
    Posts
    2,955
    Yeah, I can see that being an issue.
    Didn't keep mine long enough to put on a degree wheel, and actually check lobe centers from one cylinder to another, but I always suspected this to be the case.
  21. #19
    SupraForums Member
    Join Date
    May 2004
    Location
    Los Angeles Area
    Posts
    166
    Quote Originally Posted by 220 View Post
    Kelford 7m cams?
  22. #20
    Join Date
    May 2011
    Location
    Posts
    11
    Dont think kelford do a 7m cam or ever have. I spoke to them about my issues with BC and what options there were. They said they wont to grind the factory cams due to not enough material to get a good profile but they would grind the BC cams to make them accurate as they had done this before. $550NZD to do that.
  23. #21
    Join Date
    Dec 2002
    Location
    Abalama
    Posts
    3,550
    I am 1JZ. The issue with the degree from card to real life was with the JZ cams.
  24. #22
    Join Date
    Jun 2006
    Location
    San Antonio, Texas
    Age
    66
    Posts
    2,955
    If you read through other forums, it's with ALL their cams, Honda, Nissan, Subaru, etc..
  25. #23
    Join Date
    Dec 2002
    Location
    Abalama
    Posts
    3,550
    Good to know.
  26. #24
    SupraForums Member
    Join Date
    Dec 2013
    Location
    Florida
    Posts
    78
    Web cams can grind whatever you want very knowledgeable if your in the market for cams this the only way to go.
    Also running supertech buckets quality parts much lighter than stock
    https://www.supertechperformance.com...5-cam-follower
  27. #25
    SupraForums Member
    Join Date
    Dec 2013
    Location
    Florida
    Posts
    78
    sorry double post not sure how to delete
+ Reply to Thread
Quick Reply Quick Reply
Register Now
List your Car(s)
Where you live
Log-in
Similar Threads
  1. BC 264/264 cams, drop in? Non interferance?
    By itsmeek in forum MKIV (1993-1998)
    Last Post: 08-22-2013, 09:25 AM
Posting Permissions
  • You may post replies
  • You may not edit your posts
