No Check Engine Light when key inserted in ignition
+ Reply to Thread
Results 1 to 4 of 4
Thread: No Check Engine Light when key inserted in ignition
  1. #1
    Great White mysupratoy94's Avatar
    Join Date
    Nov 2003
    Location
    Duarte, CA
    Posts
    437
    Its been so long since ive had issues with my car that I forgot if my CEL should light up when I insert my key on the ignition. My battery and oil light come on but no CEL. Is that normal? I believe my CEL should briefly come on then go away.
    Im having issues with my engine starting but then idles very rough then dies. If I step on the gas I can keep it going for a few seconds but it idles rough and runs rich. After it stalls the check engine light comes on along with all other lights. Since I dont have an odb1 scanner I tried jumping the connectors with a paper clip but i cant get my CEL to blink even if I blink at it lol.
    One other weird thing is the the VSV valve that actuates the IAC inlet on the 2JZGE throttle body clicks like crazy the minute I turn the key to the on position in the ignition.
    Anyhow, my car sits most of the time, its a 94 NA and its mainly driven on weekends but not much. I drove it a few days ago and it ran fine, I parked it in the garage, a week later this happens. Any thoughts on what it could be?
  2. Remove Advertisements
    SupraForums.com
    Advertisements
  3. #2
    SF Contributing Member bitshftr's Avatar
    Join Date
    Jan 2009
    Location
    Raleigh, NC
    Age
    51
    Posts
    2,904
    Yes, the Check Engine telltale light on the left pod should come on when the key is turned to the ON position. Try tapping on the pod with your knuckle. If that doesn't get it to come on, then you have a cold solder joint in that pad, or your copper bulb contacts are worn.
    1995 Supra NA, Baltic Blue, targa, TRD LSD, Recaro Sport seats, Cusco carbon fiber front/rear strut tower bars, 97+ front turns
    Passport hardwired, w/ amped remote speakers in seat harness slots
    Hidden/hardwired garage door opener w/ custom Supra dash button
    1995 Supra TT, BPU+, Baltic Blue, targa, TRD front/Cusco rear strut tower bars, 98 headlights w/ 6k HIDs, 97+ front turns, BNR turbos, Tial BOV, HKS Super Drager exhaust, SSR Professor SP1 wheels, Racelogic TC, VPC/GCC
    Passport hardwired
    Subtle white LED dash backlights
  4. #3
    Join Date
    Nov 2003
    Location
    Duarte, CA
    Posts
    437
    Quote Originally Posted by bitshftr View Post
    Thanks, weird thing is the CEL will light up when the engine stalls and stays on so could it still be a contact issue?
  5. Remove Advertisements
    SupraForums.com
    Advertisements
  6. #4
    SupraForums Member
    Join Date
    Feb 2008
    Location
    Ireland
    Posts
    534
    That cluster was the first to go intermittent on me
    I would resolder it, fixed mine, no issues last 6 years
    Sent from my G8141 using Tapatalk
+ Reply to Thread
Quick Reply Quick Reply
Register Now
List your Car(s)
Where you live
Log-in
Similar Threads
  1. Ignition key ring light question
    By redddevil07 in forum Exterior , Interior, and Detailing
    Last Post: 04-16-2012, 03:00 AM
  2. ignition key light ring?
    By aautomotive in forum Elmhurst Toyota Scion
    Last Post: 01-19-2011, 08:11 AM
  3. Track light on/ OD light blinking/ and check engine light on
    By zerorecall in forum MKIV (1993-1998)
    Last Post: 06-27-2006, 08:02 PM
  4. Check Engine light, and brake light/reverse light?
    By DTSupra30 in forum MKIV Technical
    Last Post: 05-29-2006, 09:56 AM
  5. O/d Light Blinking, Trac Off Light On, Check Engine Light On...help
    By volcom stone 906 in forum MKIV Technical
    Last Post: 01-14-2004, 10:20 PM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
