vi-peg ecu supra
+ Reply to Thread
Results 1 to 10 of 10
Thread: vi-peg ecu supra
  1. #1
    SupraForums Member
    Join Date
    Jul 2010
    Location
    in the middel off nowhere
    Posts
    762
    vi-peg ecu supra
    Somebody have some experience with this ecu? i have tried google but that dont help me much?? is it a good upgrade ecu, or??
  2. Remove Advertisements
    SupraForums.com
    Advertisements
  3. #2
    SupraForums Member
    Join Date
    Jun 2014
    Location
    Top Secret
    Posts
    200
    Open it up and look inside, if you have a search you will find plenty of info regarding Vipec.
  4. #3
    SupraForums Member Seattle Express's Avatar
    Join Date
    May 2008
    Location
    WA <---> MI
    Posts
    1,085
    Is it a V or I series? 44 or 88? There's good info out there on these models. I've never seen Vi-PEC guts packed into a stock 2jz ECU casing before though.. I assume that's the case and it's not just a stock ECU with a Vi-PEC sticker on it..
  5. Remove Advertisements
    SupraForums.com
    Advertisements
  6. #4
    SupraForums Member
    Join Date
    Jul 2010
    Location
    Posts
    762
    i don't know anything about it, it is a used that are for sale, and only have those 2 pictures, so just want to know if it is real or as you have said a stock ecu with a sticker. are there only one way to check it by pulling is apart or is there others ways??
  7. #5
    Join Date
    May 2008
    Location
    WA <---> MI
    Posts
    1,085
    I'm not sure what the boards look like exactly. I think an easy way to determine what's inside that case is to supply it with power and connect to it from a laptop. You can verify whether or not it's a Vi-PEC, and beyond that you'll be able to know the model.
    VTS software download:
    https://www.vi-pec.com/software
  8. #6
    SupraForums Member
    Join Date
    Jun 2014
    Location
    Top Secret
    Posts
    200
    Quote Originally Posted by supra mkiv View Post
    Its a few screws. If the seller can't be bothered to open it up and photograph the internals to prove its a Vipec, walkaway. If you can't contact the seller to get the internal shots walk away.
  9. #7
    SupraForums Member
    Join Date
    Jul 2010
    Location
    Posts
    762
    It seems like it is a vi-peg ecu. But is says it is to a single turbo but I have Twin turbo. Can i use it, and is it posible to test it works without mounting it in a car?
  10. #8
    SupraForums Member
    Join Date
    Jul 2010
    Location
    Posts
    762
    Ecu
  11. #9
    SupraForums Member
    Join Date
    May 2004
    Location
    San Diego
    Posts
    3,549
    You would most likely have to convert the factory turbos to TTC because that ecu can not control the factory sequential operation.
  12. #10
    SupraForums Member
    Join Date
    Jul 2010
    Location
    Posts
    762
    Quote Originally Posted by cwtt View Post
    ok.. is it a good ecu?? how to test it?? what is the value on that kind of ecu??
+ Reply to Thread
Quick Reply Quick Reply
Register Now
List your Car(s)
Where you live
Log-in
Posting Permissions
  • You may post replies
  • You may not edit your posts
