Pig rich and popping
Results 1 to 16 of 16
Thread: Pig rich and popping
    Mar 2012
    Washington State
    20
    Looking for some help and direction here.
    Just got done with a rebuild and my 7mgte is popping and running rich once warm. Plugs are an hour old and badly carbon fouled.
    550cc injectors, Lexus afm, etc. tested for leaks and found a couple. Ohm Tested and set tps, ohm tested afm per fsm, tested cold start timer, coolant temp sensor, idle control.... I’m still leaning towards a possible afm but I just don’t know. Any ideas for my next step? Afm is the only thing I don’t have an extra of or I would have just tried it. Thanks
    Mar 2012
    Washington State
    20
    Maybe worth noting, no HAC sensor. Never had one. Car had a popping rich issue before rebuild with same afm and injectors but also had low compression so did the rebuild. Problem persists but is worse than before. Here’s a pic of the plug with less than an hour run time.
    Also (more things keep popping in my head) walbro 255 pump and bypassed J tube.
    Mar 2007
    madison wisconsin
    428
    have you tried checking to see if its thrown any codes (jumping diag connector pins and watching check engine light flashes)
    do you have a functioning oxygen sensor ... the stock ecu will need that so it understands how to trim the injectors / run at stoich during part throttle
    do you have a wideband 02 to see whats going on ?
    there is some info on tricking the stock ecu HAC input so it does not throw a code here :
    http://www.fadingworld.com/CRE/Autom...d%20Codes.html
    1986.5 Supra NA-T Targa [email protected] BPU / MAFT-Pro sd
    2001 OG Prius
    2007.5 2500HD GMC 6.0 gas
    2011 Prius
    gas, grass or ass - nobody rides for free
    Mar 2012
    Washington State
    20
    Yes initially I got an HAC sensor code and throttle sensor code. Once I set the tps that one went away. My o2 sensor is stock but I would love to go wideband soon. I do have a spare I could try that. And thanks for that info on the HAC code!
    I’ve also set the timing a couple times since I set the tps. First time was 10 degrees and second time was 12 degrees because I thought advancing it might help a little but it didn’t
    Mar 2012
    Washington State
    20
    My walbro seems louder than normal or maybe I’m just tuned into everything. Is it possible the fuel pressure regulator went bad or the fuel return line is collapsed or clogged? When I had the rich condition before I always though it was from that restrictive j-tube so I bypassed it during the rebuild hoping it would fix my problem. There’s so much fuel that I’m sure it’s geting passed the rings right now so need to figure this one out. It can also be tough to start cold but the rich popping stuff doesn’t start until it runs for a couple minutes
    Mar 2012
    Washington State
    20
    Would love some advice guys. I’m getting really concerned I’m washing the cylinders with fuel and don’t want to do in the new engine. Today I’m going to check and bypass vsv, test fuel pressure, blow through return line and see if it’s clogged. I might even bypass the cold start injector. but if I use the cold start injector port on the rail to test pressure and it runs better, I’ll probably know if I need to or not. Any other bits of advice is more than welcome.
    I’m also putting in my spare o2 today as Madison suggested
    90T 3p141592654's Avatar
    Sep 2005
    Thousand Oaks CA
    417
    It would seem you are not running closed loop. I would check for cross counting on the O2 sensor. Also, install the HAC sensor.
    http://www.cygnusx1.net/Supra/Librar...spx?S=FI&P=119
    Mar 2012
    Washington State
    20
    Quote Originally Posted by 3p141592654 View Post
    Thanks for that I will check for sure. A couple updates though, I checked the vsv per fsm and it failed everything and smelt like there was gas in it. I also retro fitted my old snap on fuel pressure tester to the cold injector spot in the rail and my fuel pressure is too high. Here’s what I got-
    Static 38 psi seems ok
    Running vacuum unhooked 42 psi
    Running vacuum hooked up 34 psi
    I also watched the bleed off and it held over 30 lbs for over 15 minutes. It’s arill at 12psi and I shit it off a half hour ago so that seems good. Gonna check the return line and move on.
    Besides a plugged fuel return, what could cause the extra pressure? I’ve read that even 2psi can cause problems and I’m 4 over
    Mar 2012
    Washington State
    20
    Fuel return had a lot of restriction so I got my hopes up and blew it out but it’s still not doing great. Maybe a little better? Still need to test the o2 or just get a wideband coming. Need an HAC sensor and I guess a AFPR to turn back my pressure. Here’s a video of it running. Phone audio sucks but you’ll get the idea. Also there definitely has in the oil. Has me concerned
    https://m.youtube.com/watch?feature=...&v=iw8ITlj8l9o
    Mar 2007
    madison wisconsin
    428
    man looking at that video its really hard to say. could be the video but that is a very loud misfire, almost sounds mechanical (hollow knocking) through the phone.
    saw the ffim and am wondering what turbo you are running
    any yes get that wideband 02 I don't understand how there is a ffim and no wideband / electronics in there to tune it
    you had the vac line off the regulator I assume, so its not spraying out there (fuel reg diaphram failure)
    are all plugs fouled the same ?
    did you check the 02 with it running (like the tsrm shows) ?
    Mar 2012
    Washington State
    20
    Quote Originally Posted by madisonMK3 View Post
    The phone audio is garbage. I listened to the video and I see what you mean and when you’re here it’s definitely an exhaust pop. Like Unburnt fuel hitting the manifold and igniting. Last time I started it, it backfired on start up.
    Stock turbo. My analog meter is toast so I’m waiting on my buddy to come with his high dollar diagnostic probe. Tried it with my digital meter but it wasn’t fast enough to measure “bounces”.
    All the plugs are fouled the same and I have new ones coming because these ones can’t be working great anymore. The regulator doesn’t obviously shoot gas but like it said, it smelt like gas inside the vsv pressure up solenoid so it certainly could be leaking very little under vacuum?
    Could you recomend a wideband setup?
    Would the apsx wideband kit be acceptable? Looks like it has a simulation wire I can run to the ecu
    Mar 2012
    Washington State
    20
    I think I’ve decided on the aem wideband because no need to calibrate it all the time. I’m going to stop running it for now out of fear of washing the cylinders and bearings with gas. I’ll still do the o2 test when my buddy can make it out. Also need to get an AFPR so I can turn my pressure back.
    Mar 2007
    madison wisconsin
    428
    I don't know anything about aem, I have an Innova lc-1 --has worked great for years / on my 3rd sensor as they foul up if you run leaded race gas. it uses a common wb sensor that is like $40 on amazon.
    calibration is easy, hold a button for 30 seconds. honestly I would assume they all wear somewhat (wb o2 sensors) and calibration only helps (I don't see that as a feature). i put a new wb sensor in every 2 years anyway, its cheep insurance.
    what I like about the lc1 is 2x programmable outputs and a serial connection (+software) that lets you update firmware on the device / program outputs / log o2 on your pc during a pull
    the programmable outputs are important imho, I use one of the outputs to drive the stock cars ECU (WB simulates a narrow band signal)
    other output feeds my maft-pro computer a true WB scale (I datalog with maft pro, the 02 only log is somewhat worthless as it has no other data points ie:rpm / boost ) **I should note you have to give the toyota ECU the 02 signal AND a load across the 02 heater circuit. I run an LED resistor across the heater circuit to trick my car and prevent throwing an 02 code with this setup
    it is critical the stock ecu gets 02 info to adjust the fuel trims / understand where stoich is during cruise / part throttle
    but super duper uber piggy rich, gas exploding in manifolds... (I imagine its reeking of gas by the car correct) makes me wonder if its something else...ecu jacked and holding injectors open / etc
    Mar 2012
    Washington State
    20
    Yeah I kind of feared something like a fried ecu. Would the resistor pack cause any problems like this? And yes the gas smell is overwhelming lol.
    Also, I can leave my stock sensor and just put the wideband down lower right? Let the stock one take care of the ecu
  17. #15
    Mar 2012
    Washington State
    20
    I just wanted to follow up on this in case anyone searches. There’s so many unresolved threads out there. I installed an adjustable fuel pressure regulator, lowered my fuel pressure, installed an aem 30-0300 wideband, and a new denso factory o2. When I first started it, the computer took a bit to relearn and it was running worse than ever and had me stressed out but I went ahead and let it warm up, took it on a short drive and it is running great now. I still have a very slight intermittent pop at idle but I understand tons of these engines out there do this and with a straight 3” exhaust, it makes it more pronounced. Gonna try a few things to get rid of that but overall it’s running really nice and I’m very happy. I think just the new denso o2 would have solved most of this even tho the original one wasn’t “technically” bad. It was fouled and confusing the computer. But I’m happy to have control over my fuel pressure and at least some control over afr in open loop.
  18. #16
    Mar 2007
    madison wisconsin
    428
    good to hear man!
    now that you have o2 working, the toyota tccs ecu has a way to tell you info on its "learned fuel trim"
    if you google tccs vf trim there is good info out there. basically the car takes its base injector map (aka best guess map) and compares it to actual data from the o2 / real injector pulse width to achieve stoich. the difference between the two is called the "trim". you want to set your static fuel pressure so that the car is making as little adjustment ( injector trim) as you can, under idle/light throttle. also your lex AFM screw will influence the injector trim at idle. its a balance between that screw and base FP
    if your vf is always pegged at 0v or 5v the cars ecu will assume something is wrong because its fuel trim is excessive.
    one thing I have learned is the cars ECU is much more predictable (keeps its tune consistent under high load open loop maps) if its injector trim is reasonable (minimal, under 10% adjustment).
    if the trim is over 10% the ecu pulls timing and uses very pig rich open loop (high load) maps bc the car assumes there is an issue due to excessive inj trim
  1. Replies: 0
    Last Post: 07-30-2009, 06:28 PM
  2. 7mgte hiccup and pig rich
    By flatblack in forum MKIII (1986.5-1992)
    Last Post: 04-08-2009, 08:50 AM
  3. 7mgte hiccups and pig rich
    By flatblack in forum MKII (1982-1986)
    Last Post: 02-12-2009, 04:04 PM
  4. Rich rich rich
    By hornick in forum MKIV Technical
    Last Post: 05-18-2007, 09:09 AM
