How much do more aggressive cams affect gas mileage ?
+ Reply to Thread
Results 1 to 9 of 9
Thread: How much do more aggressive cams affect gas mileage ?
  1. #1
    SupraForums Member
    Join Date
    Sep 2009
    Location
    CT
    Posts
    554
    I have a 94 TT with stock twins, just BPU. Last summer I refreshed my engine to replace all the leaking hoses, gaskets etc. Valve stem seals were the biggie, but there were small leaks everywhere due to rubber hardening etc.
    While I was doing the valve stem seals, I also replaced the cams with Kelford T-202C (268/272) and the springs/retainers with Supertech TS1012 dual springs. Titan V2 adjustable cam gears, and they're degreed in just right.
    I used to get at least 240 miles to the tank of 93 octane, and sometimes a lot more with just easy highway driving. But now it's down around 200 or so with general around-town driving, short highway stints, and no really hard pulls or anything. At first I thought it was "just that tank" but it's been pretty consistent last few fill-ups. I'm hoping it's the crappy winter gas, but in general the car barely goes out in the cold.
    So, do cams have that much of an effect ?
  2. Remove Advertisements
    SupraForums.com
    Advertisements
  3. #2
    SupraForums Member
    Join Date
    Jun 2016
    Location
    Cali
    Posts
    98
    More lift = more fuel. Yeah it will effect it. We donít buy these cars for gas mileage though lol
  4. #3
    i recorded mark7m001.mp3 Mark 2JZ's Avatar
    Join Date
    May 2002
    Location
    So Cal
    Age
    36
    Posts
    1,980
    I would say yes as far as worse gas mileage. Also maybe since the cam overlap at lower rpms/low load it’s less efficient.
    I could be wrong but that’s my $0.02
    1994 Supra PT71GTQ
  5. Remove Advertisements
    SupraForums.com
    Advertisements
  6. #4
    SupraForums Member
    Join Date
    Sep 2009
    Location
    CT
    Posts
    554
    I kept rationalizing it as more lift = more fuel/air = more power, so less throttle needed for same power ==> same mileage.
    But nooooo, guess not
    Didn't think about the overlap. Last couple of tanks have been "regular" driving, not Supra pulls on the highway at higher rpm. Heading from CT down to Philadelphia for Northeast meet in a few weeks, 2.5 hours of highway. We'll see how that does for mileage.
  7. #5
    Game Over Boost Wang's Avatar
    Join Date
    Apr 2008
    Location
    Portland OR
    Age
    27
    Posts
    1,146
    Quote Originally Posted by Mark 2JZ View Post
    I would say yes as far as worse gas mileage. Also maybe since the cam overlap at lower rpms/low load itís less efficient.
    I could be wrong but thatís my $0.02
    Stock ecu playing things safe, paired with any big exhaust removing any remaining exhaust reversion with more overlap will do it.
    OP's gas mileage will likely be worst if he didn't degreed those cams.
    -Sam
    1993.5 White turbo hardtop. 1 of 26
  8. #6
    Super Moderator Wreckless's Avatar
    Join Date
    Feb 2002
    Location
    Albuquerque, NM
    Posts
    9,843
    More lift by itself won't affect gas mileage nearly as much - the 'more air = less throttle needed' would mostly apply.
    The overlap and increased duration does lower overall efficiency at lower RPM's which means worse fuel mileage when idling and at light throttle vs stock cams. There's always a tradeoff, until we start talking VVTi which is awesome when it's tuned well because you can get a lot of the cake and eat it too.
    But no, most of us don't buy these cars for fuel milage
    Jeff
    "I spent a lot of money on booze, chicks and fast cars. The rest I just squandered." -- George Best
    Quote Originally Posted by KING View Post
    Who would have ever thought.....the impact an automobile can make.....
  9. #7
    SupraForums Member
    Join Date
    Sep 2009
    Location
    CT
    Posts
    554
    Heh, no, no I didn't get them for the mileage ... but I wasn't really expecting a hit unless I really got into it on the highway etc. Ah well.
    I do have a vvti head sitting in the garage, waiting to be installed. Well, that plus single, plus standalone, plus plus plus. Hrm, can I get an Aristo 2jzgte vvti ecu for now ? Until I can do the whole single upgrade that is ?
  10. #8
    Join Date
    Feb 2002
    Location
    Albuquerque, NM
    Posts
    9,843
    Quote Originally Posted by Halfwalker View Post
    That'd be a lot of work to do a VVTi swap with a VVTi ECU just to rip the VVTi ECU out and go standalone anyway. I'd recommend just doing the VVTi and standalone at the same time, and change fuel/turbos/etc as your build plans dictate.
    Just don't skimp on tuning costs. If there's a local guy that a lot of Supra people highly recommend, but he's not cheap, there's a good reason why he's not cheap and that is money well spent.
  11. #9
    SupraForums Member
    Join Date
    Sep 2009
    Location
    CT
    Posts
    554
    So, pick a standalone that can handle the twins and vvti ? I thought most of the standalones didn't handle the sequential twins, only in true-twin ? The main players seems to be ProEFI, Haltech and AEM, right ?
+ Reply to Thread
Quick Reply Quick Reply
Register Now
List your Car(s)
Where you live
Log-in
Similar Threads
  1. Most aggressive 1jz cams?
    By 93 twintrbo in forum 1JZ/2JZ Swap
    Last Post: 09-25-2013, 10:25 AM
  2. Most aggressive non-interference cams?
    By Tim1137 in forum MKIV (1993-1998)
    Last Post: 11-10-2012, 05:27 PM
  3. most aggressive setting for HKS 272 cams for outright power?
    By Supra96-JDM in forum MKIV (1993-1998)
    Last Post: 12-18-2008, 01:32 PM
  4. Replies: 5
    Last Post: 11-25-2005, 04:57 PM
Posting Permissions
  • You may post replies
  • You may not edit your posts
