Error Code 63, automatic transmission bad shifting
Results 1 to 4 of 4
Thread: Error Code 63, automatic transmission bad shifting
    Jul 2007
    Germany
    65
    Hello and good evening
    For a long time I have now the problem with the Error code 63.
    Defective no2 shift solenoid or shirt circuit severed wire harness or shirt circuit.
    I checked my SLD, Oil ... and everything is fine.
    Before i check the shift solenoids inside the tranny, where should i check if it is just a wire problem...
    Do you know which pin it would be to check at the ecu ?
    Or any other tips and ideas to check before i open the tranny...
    Thank you in advance and have a nice weekend
    Regards
    Nov 2004
    Sacramento, CA
    1,068
    I cant remember if this is the code that also caused my auto headache years ago. Try and see if your cruise control works or not. Or you can put your cruise control in diagnostic mode and see whether ecu is seeing speed of the car consistently. If not then you might have a short in the ODO causing this problem. I reheated the solder for the ODO several times over the years to correct he problem.
    93 Alpine Silver TT Auto BPU: HKS Super Dragger, Random Tech hi flow cat, IK22 .032", K&N filter, Synapse DV diverter valve, MVP bcc, ebv spring mod x2 @ 13 psi, wg spring mod x3, innovate SCG-1 ~17 psi, emanage blue
    Cooling: AIS W/M injection 12GPH, SM auto trans cooler external filter, CSF rad
    Suspension and Handling: TRD front strut bar, bilstein shock/oem spring combo
    Jul 2007
    Germany
    65
    Hi and thanks for your answer. headache would be nice. Meanwhile, this topic is worse for me than diarrhea 🙂 How can I put my cruise control in diagnosis? Thanks and have a nice Sunday.
    Nov 2004
    Sacramento, CA
    1,068
  1. Transmission error codes 62 and 63
    By USFmk4 in forum MKIV (1993-1998)
    Last Post: 12-26-2018, 05:20 PM
  2. Error Code 24 & Error Code 43
    By Esskiboy in forum MKIV (1993-1998)
    Last Post: 04-29-2015, 08:20 AM
  3. O/D Off flashing with no error code, shifting issues
    By BlakeEM in forum MKIII Technical
    Last Post: 07-27-2013, 09:40 AM
  4. Replies: 4
    Last Post: 12-26-2006, 08:17 AM
  5. Error Code 63
    By 1JZ_Cressida in forum MKIV Technical
    Last Post: 08-20-2006, 10:06 AM
