Hose Clamp Kit for Silicone Hoses
+ Reply to Thread
Results 1 to 6 of 6
Thread: Hose Clamp Kit for Silicone Hoses
  1. #1
    SupraForums Member
    Join Date
    May 2002
    Location
    Honolulu, HI
    Age
    36
    Posts
    1,454
    So many many moons ago I bought one of those silicone hose kits off of eBay (says SAMCO Sport on 'em). I haven't gotten around to using them until just recently to replace the coolant line that runs along the side of the head on the exhaust side into the thermostat housing (hose got too hard and clamp couldn't put down enough pressure so it started shooting out coolant onto the manifold and turbo, quite the show! ). That's when I discovered that the OEM squeeze clamps don't really fit these new hoses! I see that the kits nowadays come with a free set of SS clamps. Anyone know a place that sells just the hose clamp kit? Am I better off just getting a general purpose kit like this? Amazon Kit
    Hose clamp recommendations welcome as well. I've heard T-Bolt clamps being the preferred choice for things like the IC pipes.
    '91 Supra Turbo 5spd - White Package
    2018 BRZ tS - WRB
  2. Remove Advertisements
    SupraForums.com
    Advertisements
  3. #2
    SupraForums Member seoul4korea's Avatar
    Join Date
    Dec 2008
    Location
    San Diego
    Posts
    923
    They sell T bolt clamps for this reason, you just have to measure the size you need and order it. It should be better as well as it won't dig in like the normal worm drive hose clamps do.
  4. #3
    2JZA70 SDstreetracer's Avatar
    Join Date
    Dec 2001
    Location
    San Marcos, CA
    Age
    37
    Posts
    2,525
    https://www.murraycorp.com/clamp/con...al-clamps-tss/
    These Murray Turbo seal clamps are a much better option over T bolts IMO.
    91 Black 7mge auto
  5. Remove Advertisements
    SupraForums.com
    Advertisements
  6. #4
    SupraForums Member plaaya69's Avatar
    Join Date
    Jun 2007
    Location
    Waukegan, IL
    Posts
    781
    Regular t-bolt clamps suck and I personally would never run those ever again on my Supra. The clamping force in uneven with t-clamps and I had 3 spots with boost leaks with those t-clamps but the only thing I did like was they did not dig deep into the silicone couplers. I only run Breeze stainless steel marine grade worm clamps since they are high quality and work great for me at 23 psi of boost. When my Supra was at Sound Performance they also said that they only use worm gear clamps for the same reason. Here is a good read:
    https://www.amsperformance.com/wp-co...Gear_Clamp.pdf
    87 Turbo Supra - Daily Summer Cruiser
    87 Non-Turbo Supra - Sold
    04 GS300 - Daily Driver
    2019 Updated Build Thread - https://www.supraforums.com/forum/sh...ore&highlight=
  7. #5
    Question to suit. 220's Avatar
    Join Date
    Dec 2002
    Location
    Abalama
    Posts
    3,550
    Good shops all around look down on T - clamps for that reason.
    However, smaller clamps for coolant may not leak or cause the issues vs boost pipes.
    There are some excellent worm clamps out there.
  8. #6
    YotaMD.com author
    Join Date
    Sep 2007
    Location
    Arizona
    Posts
    650
    Interesting topic here. Glad it was asked. I used T-clamps on my last 7M and liked them better than the worn out OEM worm clamps, but I can see why T-clamps may not be the best solution. I'll bookmark those Murray clamps. I like the theory there.
+ Reply to Thread
Quick Reply Quick Reply
Register Now
List your Car(s)
Where you live
Log-in
Similar Threads
  1. Can anyone recommend a good spring-band hose-clamp kit ?
    By Halfwalker in forum General Supra Forum
    Last Post: 08-21-2018, 07:23 PM
  2. Do the oem vacuum hose clamps fit silicone hoses?
    By supra-raleigh in forum MKIV (1993-1998)
    Last Post: 04-08-2016, 06:35 AM
  3. Replies: 0
    Last Post: 09-29-2011, 11:30 AM
  4. Just got my new Hose Techniques Silicone hoses- PICS!
    By OldskoolSUPRA in forum MKIII (1986.5-1992)
    Last Post: 09-23-2004, 05:10 PM
Posting Permissions
  • You may post replies
  • You may not edit your posts
