Fuel System Question only get power to the pumps when jumping 3 to 5 on EFI 2
+ Reply to Thread
Results 1 to 3 of 3
Thread: Fuel System Question only get power to the pumps when jumping 3 to 5 on EFI 2
  1. #1
    Nucking Futs ocapella's Avatar
    Join Date
    Nov 2007
    Location
    Colorado Springs CO
    Age
    41
    Posts
    350
    My car has been down for 8 months as I upgraded the entire fuel system and swapped my AEM V1 for a MoTec M130 (in my spare time). With the previous set-up the car had a rigged 12 volt mod (pump ECU removed) with both pumps on separate relays. I undid the 12v mod and now have one pump triggered by the pump ECU and one by a relay. My issue is (and I probably don't understand how the fuel system works) that the only way the pumps turn on is if I jump terminals 3 and 5 on EFI 2. I tested the relay and it works fine.
    98 blk/blk 35k miles 6466 E85 RWHP TBD
    '05 E55 AMG Kleemann Stage 2 480 RWHP 550 RWTQ
  2. Remove Advertisements
    SupraForums.com
    Advertisements
  3. #2
    Stock Twins King Stu Hagen's Avatar
    Join Date
    Jan 2002
    Location
    Kirkland, Wa.
    Posts
    4,315
    Quote Originally Posted by ocapella View Post
    I can only assume the power is not getting to EFI 2. As you can see, EFI 2 gets the turn on signal from EFI 1. If that isn't getting the turn on power EFI 2 will never fire the relay. Trace out what turns on EFI 1 to find out why. I didnt spend a lot time here but reading the EWD you can trace where it all goes and comes from. Not sure why the power is not getting to EFI 1
  4. #3
    SupraForums Member
    Join Date
    May 2004
    Location
    San Diego
    Posts
    3,549
    Sounds like it isn't configured correctly in the M1 software. Have you checked and tested your outputs in the M1?
+ Reply to Thread
Quick Reply Quick Reply
Register Now
List your Car(s)
Where you live
Log-in
Similar Threads
  1. FS: Bosch 044 fuel pumps and Walbro GSS342 fuel pumps
    By TeeLex in forum Florida For Sale/Wanted
    Last Post: 07-09-2011, 07:51 PM
  2. Question about running fuel pumps on STOCK fuel system?????
    By farzad3kgt in forum MKIV (1993-1998)
    Last Post: 10-31-2007, 06:46 PM
Posting Permissions
  • You may post replies
  • You may not edit your posts
