Stock twin question - Page 2
Page 2 of 2 FirstFirst 1 2
Results 26 to 38 of 38
Thread: Stock twin question
  1. #26
    SupraForums Member okinawa-supra's Avatar
    Dec 2008
    Vista California
    756
    Looks like he is in sequential mode. At 28 seconds in the video, he is at 3500 RPM and floors it. right at about it 3800-4000 RPM the Turbo system seems to “transition” with the slight dip in boost. I believe while your in full boost with both twins online your only boosting to what ever that gauge goes too. But its not much More psi than while it was on the first turbo.
    It almost like your in “stock” boost.
    Here is a link while I was testing my 94 sequential system. Almost the same transition and it boosts to about 12 psi (the supra is stock)
    Maybe you have a weak wastegate.
    1994 6spd Targa Ren Red named "Paris" she has a history.
    1994 6spd Hardtop Baltic Blue.
    1993 Auto TT Ren Red (sold)
    1993 Auto TT white JDM (wrecking yard)
    1993 5spd NA yellow (sold)
  3. #27
    Dec 2008
    Vista California
    756
    I would also “pressure” test your system. When i hooked up coupplers to my system and applied the air compressor, i was surprised to find many little leaks. Its also not uncommon for intercoolers to crack and leak under pressure.
    Good luck.
  4. #28
    NiSmO [email protected] supergoji's Avatar
    Sep 2006
    westchester NY
    30
    521
    copy, will report back.
    Quote Originally Posted by OOBE View Post
    the shop power fucked you at 140 mph too :D
    Quote Originally Posted by x X CLoud X x View Post
    why the Hell is there a FUCKN SAILOR MOON ON A SUPRA!!!
    Quote Originally Posted by SupraLB View Post
    Was it over when the Germans bombed Pearl Harbor?
    Quote Originally Posted by wreckless View Post
    hell, he has a better chance of getting gov't funding to build the playboy mansion into an orbital launch vehicle to set a new record of nonstop consecutive orbital blowjobs from playboy playmates.
    94 Alpine Silver Supra TT 6spd ( for sale) https://www.cargurus.com/Cars/l-Used...ting=234504432
    91 Cherry Red Pearl Z32 TT 6spd
  6. #29
    SupraForums Member supralover93's Avatar
    Mar 2002
    Sacramento, ca
    34
    4,560
    ok, small update,
    i followed steps to pressurize Port "A". system holds pressure. after i release pressure from the pump and remove it, i removed caps from Ports B and lots of pressure came out leading me to believe the new pressure tank is holding just fine.
    one possible issue though. the EBV doesnt open until about 13psi and isnt fully open until about 21-22psi. also discovered my brand new POS mityvac pressure tester is leaking. while the system was pressurized i could hear a creaking while the pressure very slowly leaked down. noticed that the EBV was slowly closing while the pressure was leaking but wasnt closing smoothly. it was a little like it was sticking and closing in small steps until fully closed at about 12psi.
    after i figure out my pressure test leak i'll test all of the VSVs but i'm thinking my EBV is bad. any ideas?
    thank you
    93 turbo targa
    auto
    BPU
  7. #30
    Nov 2004
    Sacramento, CA
    1,066
    mityvac disassembles pretty easily. you can probably find which part of it is leaking. If I remember corectly, I just made a silicone gasket around it and works just fine again! good luck figuring out your seq operations!
  8. #31
    Mar 2002
    Sacramento, ca
    34
    4,560
    ya, if they dont replace it thats probably what i'll do.
  9. #32
    Stock Twins King Stu Hagen's Avatar
    Jan 2002
    Kirkland, Wa.
    4,337
    Quote Originally Posted by supralover93 View Post
    ok, small update,
    thank you
    EBV VSV is a common failure. It either leaks or it fails the resistance check. I would read what it shows for resistance. A poor EBV VSV can lead to a lazy transition but really has nothing to do with overall boost. Its sole purpose is to gradually open the actuator to prespool. I did tests years ago and found that the ECU hardly ever even opened the valve. If the valve (VSV) never opened the the rear actuator would slowly open linear to boost pressure. An brand new VSV may pulsate at 10-11psi opening and closing to maintain exactly the 10psi prior to full transition. If it was stuck open then that is where you could possibly see 11psi pt higher. Same effect as pulling the hose.
    I think what you are seeing is near factory spec on the opening PSI characteristics if I am not mistaken
  10. #33
    Mar 2002
    Sacramento, ca
    34
    4,560
    Thank you Stu. I checked to see if it holds pressure, which it does but did not do a resistance test. I will check that today.
  11. #34
    Nov 2004
    Sacramento, CA
    1,066
    So your boost level goes to 10-12 psi pre transition, then still end up at 10-12 psi after transition with your electronic boost controller.
    You pulled off the hose to your ebc and you got 20+ psi post transition. Stu mentioned electronic boost controller being the possible problem, I dont understand why you are still looking at the ebv. May be there was a misunderstanding of stu saying ebc, and you took it as ebv. Am i missing something?
    on another note, when I pressure tested my system years ago, the ebv would crack open at around your range from what I can remember and so shouldnt be too much of an issue. Total system not boosting over a certain level should be limited to the wastegate being leaky and not allowing you to build up boost or electronic boost controller not able to stop the air pressure to the wastegate actuator and hence opening it up and again not letting you build your boost.
  12. #35
    Mar 2002
    Sacramento, ca
    34
    4,560
    Thank your the reply. I think your right, I might have misread.
    Only thing that had me confused tho was that my EBV was opening at double the pressure that it's supposed to, that threw everything off in my head. Also, yes I removed the hose that goes from the BC solenoid to the top of the WG and my boost would go to 20+. It's weird because I tested the BC and solenoid and it seems to respond like it's supposed to. Sucks because it's new and I just got it but if it's bad I may just go with a MBC.
    I do want to make sure all of my stock twin components work properly because I would hate to chase any problems after the upgrade.
  13. #36
    Nov 2004
    Sacramento, CA
    1,066
    Recheck the routing of the hoses for the ebc solenoids as that can be an issue otherwise MBc and go to town brother.
    93 Alpine Silver TT Auto BPU: HKS Super Dragger, Random Tech hi flow cat, IK22 .032", K&N filter, Synapse DV diverter valve, MVP bcc, ebv spring mod x2 @ 13 psi, wg spring mod x3, innovate SCG-1 ~17 psi, emanage blue
    Cooling: AIS W/M injection 12GPH, SM auto trans cooler external filter, CSF rad
    Suspension and Handling: TRD front strut bar, bilstein shock/oem spring combo
  14. #37
    Mar 2002
    Sacramento, ca
    34
    4,560
    Thank you. I did discover that the hoses were crossed, unfortunately correcting them didn't solve the issue.
    I was also thinking, if it takes 13+psi to open the EBV and I'm only hitting 11-12, doesn't that mean that the EBV would never open?
  15. #38
    Nov 2004
    Sacramento, CA
    1,066
    Static pressure from a pump is different than dynamic pressure in the system with air pushing against the valves on top of the actuator so helping to open them. Seriously, you are dealing with a messed up ebc or poorly routed or wired or both. Go mbc and call it a day unless you really gonna be on this set up for awhile. Add a few spring hooks onto the wastegate and ebv and have fun
  1. Replies: 9
    Last Post: 05-23-2013, 10:46 PM
  2. 97 stock twin VS 93 stock twin
    By Zerosoul in forum MKIV (1993-1998)
    Last Post: 09-19-2002, 08:21 PM
  3. Replies: 3
    Last Post: 03-27-2002, 04:41 PM
