Southbend Clutch cone direction for installation?
+ Reply to Thread
Results 1 to 2 of 2
Thread: Southbend Clutch cone direction for installation?
  1. #1
    Boost Addict TRBO2NR's Avatar
    Join Date
    Jan 2003
    Location
    Milwaukee, WI
    Age
    35
    Posts
    550
    For those of you that have a southbend clutch, I am in the process of installing my new Southbend Stage 3 clutch and I just want to make sure which direction the clutch disk cone should be facing? Towards the engine or towards the drive shaft? Please let me know ASAP.
    1994 Supra TT Red on Tan 6 Speed BPU++
    RMM downpipe, BL 4" Exhaust, Arias Pistons, BC Valve Springs, HKS 272/272 Cams, Greddy Profec B Spec II EBC, G-Force ECU, Sparco harness bar and harness, Goodridge SS Brakelines, DBA 4000 slotted rotors, Carbotech XP10/XP8 pads, custom Catch can, SP modified Oil Pump, Fidanza Cam Gears, HID's...
    -2011 Subaru WRX Wagon 5 Speed (daily driver)
    -1994 Supra TT Black on Tan 6 Speed *Sold*:(
    -2003 Honda CBR600RR
    [email protected] (First time at strip, bad launches)
  2. Remove Advertisements
    SupraForums.com
    Advertisements
  3. #2
    Join Date
    Jan 2003
    Location
    Milwaukee, WI
    Age
    35
    Posts
    550
    As far as I can tell, South Bend must be opposite of every other aftermarket clutch? It doesn't seem to fit if I put the cone facing the rear like all other aftermarket clutches...
+ Reply to Thread
Quick Reply Quick Reply
Register Now
List your Car(s)
Where you live
Log-in
Similar Threads
  1. Replies: 2
    Last Post: 04-22-2016, 11:48 PM
  2. Replies: 41
    Last Post: 09-26-2013, 08:24 AM
  3. Emanage Blue Installation Direction on Chaser 1JZ
    By quickgs in forum 1JZ/2JZ Swap
    Last Post: 10-21-2009, 06:40 AM
  4. Cone washer direction on release hub
    By phorcefed00 in forum MKIV (1993-1998)
    Last Post: 07-27-2005, 10:14 PM
  5. JE Piston installation direction
    By JG_XSBOOST in forum MKIII Technical
    Last Post: 12-30-2002, 09:48 AM
Posting Permissions
  • You may post replies
  • You may not edit your posts
