2JZ-GE to MK3 engine mounts
+ Reply to Thread
Results 1 to 3 of 3
Thread: 2JZ-GE to MK3 engine mounts
  1. #1
    Join Date
    Jan 2017
    Location
    Houston
    Posts
    10
    Hey guys, I'm reading conflicting data on how the engine rests. Older threads aren't specifying between motor mounts and mounting brackets.
    I have the 2JZ mounting brackets and I want to make sure they'll work with the 91 7MGTE motor mounts? I'm thinking they will, but just want confirmation. Thank you!
    Edit: I just read in another thread that post-89' mounts will work. So I think I'm in the clear.
  2. Remove Advertisements
    SupraForums.com
    Advertisements
  3. #2
    Super Moderator Wreckless's Avatar
    Join Date
    Feb 2002
    Location
    Albuquerque, NM
    Posts
    9,898
    The engine brackets are what get changed to make a JZ fit in a MK3. There's different bracket designs for the 86.5-88 and 89-92's, and you need brackets to suit the JZ and those specific mounts. The early mounts are square, the later mounts are round. Being a 91 your car definitely had round mounts originally. 89 cars need to be careful as early 89's had square mounts later ones had round mounts.
    You will use those JZ brackets along with your factory original engine mounts and it'll all bolt up to your existing crossmember.
    Jeff
    "I spent a lot of money on booze, chicks and fast cars. The rest I just squandered." -- George Best
    Quote Originally Posted by KING View Post
    Who would have ever thought.....the impact an automobile can make.....
  4. #3
    SupraForums Member
    Join Date
    Jul 2014
    Location
    United States
    Posts
    552
    Search for 1jz/2jz swap for dummies. It is a sticky.
+ Reply to Thread
Quick Reply Quick Reply
Register Now
List your Car(s)
Where you live
Log-in
Similar Threads
  1. FS: 2jz-Ge fully built motor/ 2jz-ge obd1 manual ecu/ 2jz-ge tps
    By fastandthefurious305 in forum Florida Forum
    Last Post: 07-08-2012, 02:29 AM
Posting Permissions
  • You may post replies
  • You may not edit your posts
