General maintenance
Closed Thread
Page 1 of 2 1 2 LastLast
Results 1 to 25 of 31
Thread: General maintenance
  1. #1
    Dr Wheelspin Rh.D. Bishop92T's Avatar
    Join Date
    Apr 2002
    Location
    Red Stick Supras
    Age
    41
    Posts
    4,393
    General maintenance
    I'm seeing a lot of posts with people asking about basic maintenance - fluid capacities in particular. This is all basic stuff found in the owners manual. I'd like to see a moderator put a sticky on this and possibly some input on other common maintenance questions.
    Engine Oil
    7M-GE
    dry fill: 5.2qts
    drain and refill with filter: 4.7qts
    drain and refill w/o filter: 4.3qts
    7M-GTE
    dry fill: 5.7qts
    drain and refill with filter: 5.0qts
    drain and refill w/o filter: 4.7qts
    Cooling System
    7M-GE: 8.6qts
    7M-GTE: 8.7qts
    Manual Transmision Oil
    7M-GE W58: 2.6qts
    7M-GTE R154: 3.2qts
    Automatic Transmission Oil
    Dry fill: 7.6qts
    Drain and refill: ~1.7qts
    Rear Differential Oil
    1.4qts
    Spark Plugs
    7M-GE: .043" (1.1mm)
    ND PQ16R
    NGK BCPR5EP11
    7M-GTE: .031" (.8mm)
    ND PQ20R-P8
    NGK BCPR6EP-N8
    Wheel Lug Torque: 76 ft/lbs
    Quick reply to this message Reply
  2. Remove Advertisements
    SupraForums.com
    Advertisements
  3. #2
    viviana
    Actually, this leads me to ask a question that I had quite forgotten about. When I was shopping around for my Supra, I happened upon a Supra in very, very nice condition, except for a couple things that I probably would've mucked with anyways (interior stuff). However, it had no owner's manual. I wanted the car, so I hopped down to my local Toyota dealer to see if they could get me an 89T owner's manual. Nope, they couldn't. I ended up not buying the car, and the one I did get has the owner's manual, but incase anything happens to mine and because I now have a friend possibly in the market for a Supra... Does anyone know where you can get owner's manuals? Or is that a lost cause?
    -V
    Suspecting Ebay...
  4. #3
    Classic Cars = Secks Typenamehere's Avatar
    Join Date
    Mar 2003
    Location
    Washington State
    Age
    32
    Posts
    490
    Yeah, I have the '89 owners manual, its pretty useless. TSRM online and SupraForums are far more helpful
    * = I now am aware that the collective I.Q. of supraforums is below room temperature in an igloo. The asterisk, or "*", signifies humor and I shall use it as a marker so that you may understand when something I say is not literal.
  5. Remove Advertisements
    SupraForums.com
    Advertisements
  6. #4
    Get These Balls INDO1472's Avatar
    Join Date
    Feb 2002
    Location
    NA
    Posts
    69
    http://www.supras.nl/view.php?page=m...ceOverview.htm
    www.supras.nl
    also some very good info (1st link shows by mileage)
  7. #5
    SupraForums Member
    Join Date
    Jul 2002
    Location
    TX
    Posts
    10
    Try contacting Toyota Publications @ 800-622-2033. Just purchased new manual and cover for a 4Runner and it was less than any being offered on ebay.
  8. #6
    ///M3 > MKIII 1QwikMK3's Avatar
    Join Date
    Oct 2001
    Location
    Rons front yard :-(
    Age
    39
    Posts
    2,302
    Differential oil info: Thank you to wera172 for this.
    quote:
    Originally posted by supraian
    what size is the filler and drian plug?
    Both plugs have a wrench size of 24mm. You'll need two qts of the 80w90 "rear axle lubricant" and one bottle of the LSD additive; about $12 total.
    To fill it, I used a clear hose long enough to reach up through the wheel well from the diff - much easier to put the oil back in that way...
    Put the LSD stuff in first, and then mine took 1.2 qts of the diff oil.
    hth...
    Brands?? Yeah, the Ford stuff from the Ford dealer. Seriously! Read my first post. lol. I guess I should've made it more clear...the 80w90 "rear axle lube" is for the differential - I just said it that way because that's how the bottle is labeled to make it easier for those running to the Ford dealer to buy some.
    You do have to tell the parts guy that you also need a bottle of LSD additive to go with it. The diff holds a little over a quart, so you'll need to get 2 qts of the diff oil (rear axle lube), and one bottle of the lsd additive will be enough.
    Here is the quote from Reg:
    2.2: Differential Carriers : Another condition that may trouble your Supras differential is lack of regular oil changes; this will lead to differential failure or premature wear out. The MA-70 differential holds a very small amount of oil so it needs to be changed regularly. Cold climates are very hard on the differential. I recommend using a good quality synthetic in cold climates. I do not recommend standard 80/90 wt oils in any Toyota differentials used in cold climates. Using 75/90-wt LSD differential carrier oil from Ford motor company makes Supra differentials run quieter and smoother than any other oils tested.
    Some LSD differentials in MA-70 and MA-71 cars have excessive LSD {limited slip differential} cage pressure causing premature clutch pack failures after some cars have become stuck in mud or snow, I have opened up badly abused differentials where the LSD oil is completely burnt and Dried up from the heat of one wheel smoking while the other is locked. If you notice some chattery noise from the rear of the car when turning corners donít panic: you have a supra with a very tight LSD differential carrier. On a Supra with tight LSD you can avoid the above clutch pack failure by using the previously mentioned LSD differential carrier oil from Ford motor company. This oil has increased protection for the clutch pack and has proven to be the best differential oil for all Supras from 1982 to 1992. Don't ask me why, all I can say is this oil works like magic. Note: A number of club members are using synthetic oils from Amsoil and Esso in their differentials with good results, one word of caution should be noted." Synthetic oils may make a some differentials that are already noisy, noisier."
    Here is a link to the whole page:
    http://www.supras.com/~riemer/sonic...3/mk3_pmtn.html
    Keep in mind that Ford doesn't make the 75w90 anymore, only the 80w90 that you have to add the lsd additive to.
    Jeremy W.
  9. #7
    ...heading for 500+ RWHP
    Join Date
    Aug 2003
    Location
    Murfreesboro, TN
    Age
    35
    Posts
    467
    Has anyone ever heard about needing to change out the power steering fluid after (x) number of years?
  10. #8
    27836-12121 ARTSUPRA's Avatar
    Join Date
    Jan 2002
    Location
    Vancouver BC Canada
    Age
    28
    Posts
    1,310
    I tought that user manual says:
    " As per Toyota design powersteering fluid will leak out from the system on continues basis, there is no need for it to be changed because it will be refilled with new fluid over time"
  11. #9
    SupraForums Member dziuggy's Avatar
    Join Date
    Sep 2002
    Location
    san francisco, ca
    Age
    40
    Posts
    1,160
    what do you guys think about redline oil and MTL and diferential oil etc i heard it is preaty good stuff. ziggy
  12. #10
    Hardcore Night Warrior chevydude's Avatar
    Join Date
    Nov 2002
    Location
    Texas, where it's full and we have no more room for people from out of state looking to move here. Seriously, we are full.
    Posts
    2,294
    Just wanted to throw in my two cents. Take out and Clean out that overflow bottle. That thing gets filthy. ESPECIALLY if youve had a BHG. Heres my simple walk through. Get yourself a 10mm ratchet, get under the car where the bottle is, unbolt the mounting bracket, unplug the sensor, get back up out under neat the car and take of the top bolt it will come right out, clean that thing out, you'll see what I mean. To reinstall, repeat the disassembly orders backwards.
  13. #11
    SupraForums Member Mostly Thumbs's Avatar
    Join Date
    Jun 2003
    Location
    Oshawa, Ontario
    Posts
    372
    I cleaned mine too. Use a 30% bleach solution (i did mine overnight) now it's nice and white!
  14. #12
    Join Date
    Apr 2002
    Location
    Red Stick Supras
    Age
    41
    Posts
    4,393
    That overflow bottle should come straight out without needing to take the two 10mm bolts off. Pull straight up on the bottle and it should snap out of place. Then disconnect the sensor and you're ready to clean.
  15. #13
    Join Date
    Nov 2002
    Location
    Posts
    2,294
    Really? Mine was stuck, and in fear of damaging I just unbolted seeing how it took like a minute.
  16. #14
    on vacation makenzie71's Avatar
    Join Date
    Dec 2002
    Location
    Texas
    Age
    37
    Posts
    3,062
    For those of you who have a hard time filling things like the differential and trannies and such...get a super soaker. I still have an original SS50 that I use. You can fill the tank and break off the barrel, inside the barrel is a rubber hose which leads to the nozzle. Cut the hose off the nozzle and it's easily long enough to reach into your various lube resavoirs.
  17. #15
    Freedy89T
    Add This To The Faq Sticky
    I would like to have a list of fluid requirements for the car in stock condition and in modified(read best) condition. I just picked up some clutch fluid at Anvanced and the guy said there is a chance that it uses ATF instead of regular DOT 3 brake fluid...for the clutch. I figured other people would want to know fluid types...and also other stuff about adding synthetic after mineral oil and so forth. My mechanic says synthetic is good for over 4-500 deg F while mineral starts to break down after about 220-240 deg F. Just some random stuff like that
    and my question. Do our clutches use regular brake fluid or ATF?
  18. #16
    Blackzilla ridah's Avatar
    Join Date
    Jan 2002
    Location
    Compton, Cali
    Posts
    1,579
    break
  19. #17
    SupraForums Member
    Join Date
    Jan 2002
    Location
    Posts
    5,728
    what kind of a jackass recommends ATF for a hydraulic clutch system? ATF WILL RUIN YOUR MASTER AND SLAVE CYLINDERS.
    Run brake fluid, no questions asked. I filled mine with Valvoline synth but I don't think it makes a difference for the clutch.
  20. #18
    Go All Electric
    Join Date
    Jun 2003
    Location
    Everywhere
    Posts
    1,183
    That's "brake"(DOT 3 AND OR DOT 4).
    Dunno why he told you that you may run ATF for the hydraulic clutch sytem. BUT ... we do/can use ATF for PowerSteering.
    Standard fluid requirements are found with the online TSRM: http://www.cygnusx1.net/supra/library/TSRM/index.html
    and the online handbook: http://www.brandwood.net/supra/handbook/
    I just use all compatible Amsoil fluids and may "upgrade" (EDIT: viscosity/Amsoil product fluctuations /EDIT) according to miscellaneous information and to weather fluctuations.
    As far as temp ratings etc ... I take what people say with a grain of salt and ask for documentation comparisons. I beleive things better when I read/research them for myself.
  21. #19
    SupraForums Member
    Join Date
    Jan 2002
    Location
    Posts
    5,728
    If you want to get really specific, look for the brake fluid that is the least hygroscopic. That way your clutch cylinder seals last a lot longer.
  22. #20
    Destroyer of Turbos MKIIINA's Avatar
    Join Date
    Oct 2003
    Location
    Frisco, TX
    Age
    35
    Posts
    4,461
    one more but back to the point..oil, brake, and antifreeze pop up right off the bat. shop around, research, adn youll be fine
  23. #21
    SupraForums Member ma71supraturbo's Avatar
    Join Date
    Dec 2001
    Location
    Chico, CA
    Age
    37
    Posts
    6,907
    owners manual page 151 (yes they mispelled "engine"):
    *NOTE* this is a manual from 1987 -- 1989 Manuals require Research Octane No. of 96 (Octane Rating 91)
  24. #22
    Join Date
    Dec 2001
    Location
    Chico, CA
    Age
    37
    Posts
    6,907
    page 152:
  25. #23
    Join Date
    Dec 2001
    Location
    Chico, CA
    Age
    37
    Posts
    6,907
    page 153:
  26. #24
    Join Date
    Nov 2002
    Location
    Posts
    2,294
    Heres a helpful hint for those trying to get those valve cover screw gaskets/rings off. I dont have "Heman" strength, but I have a clever mind. Anyway I tried to take off those Valve Cover screw gaskets off. You know, those ones with rubber and metal. I couldnt get them off, so what I did and what you can do to get them off is easy and qucik.
    Heres the items that you'll need:
    1.)Find a 9/16in deep socket or metric equivalent.
    2.) A regular hammer
    3.) A vise grip is highly reccomended, but not needed.
    Get the Deep socket with the open end pointing up and tighten it down in a Vise grip. You dont have to have one, but it keeps you from accidentally smashing your hand by holding it. Now place the screw with the head facing down into the socket. The screw will now be "floating" in the socket. Now get the hammer and you can tap the screw out almost all the way out of the gasket. You'll get to a certain point where its flush and you can take out the screw and the gasket can get pulled right off easily. MUCH better than trying to yank on it for like 2 mins. This is most effective and quickest way with out getting p.o.ed that its not coming off.
  27. #25
    NMS71
    Somebody should pound home the oil change requirement. If you go to see a car for sale, and it is obviously old, dont buy it. If it looks like its just been changed and is real light, they flushed it to hide it and dont buy it.
    Or you will end up with a bad bearing. And the "7M rod knock problem" that isnt really a problem to this engine.
Closed Thread
Quick Reply Quick Reply
Register Now
List your Car(s)
Where you live
Log-in
Posting Permissions
  • You may post replies
  • You may not edit your posts
