Stock twins replacement/upgrade - Hybrid GT28R's - Page 5
+ Reply to Thread
Page 5 of 120 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 55 105 ... LastLast
Results 101 to 125 of 2992
Thread: Stock twins replacement/upgrade - Hybrid GT28R's
  1. #101
    Join Date
    Oct 2005
    Location
    in the casino. LV
    Age
    38
    Posts
    158
    also, the OEM exhaust housing shield still... just fits! It bolts to the unchanged exhaust housings. So it will bolt rite up btwn both compressor covers.
    Water connections... this is where it gets interesting. With the oil feed and return... I have a write up with all the part numbers needed. Only the oil return needs to be modded. But i found a simple solution for that. As far as the water connections, I bent New hard lines to route around in a factory configuration. But im not totally happy... it uses the original 2 feed and 2 return locations, but i then had to route connecting hose through the OE heatshield. This will work fine... but i have some ideas brewing that will make this more of a bolt on kit.
    BTW. STU do u have a clean OE heatshield you can sell me? i had a hole cut in mine for my EGT....
  2. Remove Advertisements
    SupraForums.com
    Advertisements
  3. #102
    GO 'Cats! bonz's Avatar
    Join Date
    Sep 2005
    Location
    Austin/South Padre Island, TX
    Posts
    1,001
    I dub this GT28R turbo upgrade once, twice, thrice..... "Hammerheads".
    In sentence form, I have the Hammerheads. OR I have the Hammerhead upgrade.
    This is not the original Stu/Aaron300 hybrids but the ones Stu and Hammerhead have been working on with the GT28R's.
  4. #103
    Twin Meister
    Moderator
    KenHenderson's Avatar
    Join Date
    Feb 2002
    Location
    SoCali
    Posts
    9,924
    ^^^Brian, are you referring to the hybrids as well as the GT28Rs?
    Ken.
  5. Remove Advertisements
    SupraForums.com
    Advertisements
  6. #104
    Join Date
    Sep 2005
    Location
    Posts
    1,001
    Ken,
    Edited for clarity, I think?
    Thanks,
    Brian
  7. #105
    Join Date
    Oct 2005
    Location
    in the casino. LV
    Age
    38
    Posts
    158
    bonz...
    sounds good to me...
  8. #106
    Blue Thunder $9ktt's Avatar
    Join Date
    Jun 2006
    Location
    MD
    Posts
    3,229
    Are the original hybrids still being made? The ones that use the OEM housings?
    Not the GT28R version
  9. #107
    Join Date
    Sep 2005
    Location
    Posts
    1,001
    $9ktt
    PM sent. Hope that helps.
  10. #108
    Stock Twins King Stu Hagen's Avatar
    Join Date
    Jan 2002
    Location
    Kirkland, Wa.
    Posts
    4,315
    "$9Ktt"
    Both versions are made with the OEM compressor housings. They are both bored out to allow for the 60mm 12 fin T3 compressor blade.
    "hammerhead"
    Bobby, I have at least 7 heat shields laying around. PM me your address and I will ship it gratis ~ (-: (Get that damn dyno bud! Were dying here!)
    "Bonz"
    I like "hammerhead-turbo's" (not plural)
    I think best way to call these out would be Aaron's are the T3 Hybrids, and these new versions as the GT28 Hybrids.
    As earlier discussed, oil and water lines need to be "refined". If not for the purposes of being all exactly the same. The cost to fab up 24 sets will be easier and less cost than 1-off's. My 12 of 24 sets are not done quite yet. I want to study them on my mock up system, and with help from hammerhead, I will come with up with something that has "installation" in mind as well as asthetics and durability. There are issues here like banjo vrs AN, conversion adapters, line size factors, etc. Maybe hammerhead's way might be the best, dunno.
    Stu
    PS, oh ya, and maybe the manifold might be part of the kit too. We need to make sure this thing doesnt crack tho, or cause large amount of backflow on the #2turbine, creating a vacuum to the #1 prior to full transition. The OEM log has that little corrugated coupler between manifold banks for a reason.
  11. #109
    SupraForums Member
    Join Date
    Sep 2005
    Location
    La Mirada, CA
    Age
    29
    Posts
    704
    man i want this done sooooo bad.
  12. #110
    Join Date
    Sep 2005
    Location
    Posts
    1,001
    "Hammerhead turbos"....going once, twice.....Sold! Whew. On with business now.
  13. #111
    SupraForums Member
    Join Date
    Oct 2006
    Location
    NJ/CT
    Age
    32
    Posts
    141
    so how much for a hybrid gt28 conversion? LOL i guess i must of missed that part cause i dont see a price for it anywere.
  14. #112
    I love sequentials!
    Join Date
    Dec 2001
    Location
    MD
    Posts
    2,578
    Nothing permanent so far, but probably around $2500 to $3000
    Quote Originally Posted by DRGSUP View Post
    4 six speed turbos
    Quicksilver TT
    Blue Supra TT
    Red Supra TT
    Corolla XRS (260fwhp)
  15. #113
    Join Date
    Oct 2005
    Location
    in the casino. LV
    Age
    38
    Posts
    158
    Hammerheads ;)
    Ok here are some pics... and some of the areas that where... Well... needed Modifications. A whole write up is coming, as I kept a diary of the install and the hurdles I needed to clear. I tried to keep the modifications to a Minimum, to make future kits costs down and easy to install.
    Oil Return Line:
    All I Could find to bolt up to "BNR" Center sections was a 5/8" adapter... OEM is 7/8" Lines, Future installers you could do 2 things here... get some sort of Reducer to run a small section 5/8" hose and a small section of 7/8" Hose.
    -or-
    I had the OE Aluminum casting modified to 5/8" lines. This is by far cleaner. I think in future kits Bryan may be able to include a modified 7/8" Drain connector for his Center sections. This will allow for one less modification. And probally be cheaper.
    *PICS OF MODDED OIL RETURN*
    Connection piping between turbos:
    I have to get some other pics off my other camara as the one used in these pics the flash was not working. Making things BLURRY. Sorry Guys
    *OE Heatshield Does fit* Not pictured as I was fitting IC pipes in these pics.
    1" trimmed off this OE Coupler
    At these connection OEM Couplers are Corrugated... So you cannot shorten them. I purchased 2 1/4" Silicone that looks OEM.
    NO CUTTING OF THE OEM Intake piping needs to be done.
  16. #114
    Join Date
    Oct 2005
    Location
    in the casino. LV
    Age
    38
    Posts
    158
    Oh BTW: BONZ... I was in the supermarket picking up some food and as i'm walking out I seen a Candy machine made me think of you.
  17. #115
    Join Date
    Sep 2005
    Location
    Posts
    1,001
    Remember guys we can't discuss price as it will be ban-o just fyi not trying to be a buzz kill but we were already asked once by the mods. Thanks.
    Hammerhead: Great write up BTW, thanks for all the hard work. It's gonna save the rest of us hella time and $$.
    I could give a S#$% what THEY say. I actually have never found THEM.
  18. #116
    Join Date
    Sep 2005
    Location
    Posts
    1,001
    Quote Originally Posted by hammerhead View Post
    What are those things? They look like dog bone shaped Jelly Bellies. This is my brother's nick name too so I'll have to send him a bulk box of those. That or just take off with the machine out the front door. So how much did Bonz candy cost?
  19. #117
    Join Date
    Oct 2005
    Location
    in the casino. LV
    Age
    38
    Posts
    158
    Bonz... The candy looked like some hard candy shaped like little bones...It had a Scooby doo on the front.
    Back to business... I am going to make a set of duplicate Water lines to send to Stu or Bryan because that seems to be the only thing that you cant just order and need to make... But they are very inexpensive to make(Tubing Bender $30 and a few feet of 3/8" Hard Line)
  20. #118
    SupraForums Member RRocket's Avatar
    Join Date
    Apr 2005
    Location
    Canada
    Age
    47
    Posts
    1,395
    In lieu of a new manifold, can the stock on just be exchanged for an Extrude Honed one? I've seen some VERY dramatic extrude honed exhaust manifolds...Thoughts?
  21. #119
    Join Date
    Jan 2002
    Location
    Kirkland, Wa.
    Posts
    4,315
    OK Cool, things are progressing~! We are getting closer to the roll-out of the 1st 12 sets. Will keep you guys posted. As soon as I get the lines and the new sets, I will get cracking on modifications if any on the fitments.
    Now, to give people a little more "specifications" these are the GT28 specs.
    compressor dimensions: 47.22mm inducer and 60.12 mm exducer
    turbine dimensions: 53.00mm inducer and 47.12 mm exducer
    shaft dimensions. 9.16mm Journal and 5.94mm shaft
    GT is a newer design of turbine wheels. There are GT ball bearing and non
    ball bearing types. What you are getting is custom GT28 non ball bearing
    CHRA's. A/R still remains factory for the compressor and turbine housings.
    Stu
    PS: You can get OEM specs for the CT12's on the AU sites. (to compare)
  22. #120
    SAP R/3 Guru 2DIE4's Avatar
    Join Date
    Sep 2001
    Location
    Sweden of course home of the Vikings
    Posts
    834
    CT12B (Steel)
    Turbine Size 52mm/44mm (inducer/exducer)
    Compressor Size 58mm/39mm (inducer/exducer)
    Steel
    740
    0.53
    http://mkiv.supras.org.nz/ look under "specs" in the menu.
    The t28 turbos is very similiar to the ones i bought for my Skyline R34 GTR the GT28 Family > GT2860R - 707160 - 5 aka HKS 2530 good for around 320-350 a piece . This will be great ..... http://www.turbobygarrett.com/turbob...R_707160_5.htm
    A evil Protomotive Beetle :-).
    EU-Spec. 6-speed Supra MKIV aka Eagle II.
  23. #121
    SupraForums Member
    Join Date
    Feb 2001
    Location
    Hilliard, OH
    Posts
    330
    Do you think the stock reed valve is going to be an issue, or have you addressed this?
  24. #122
    Join Date
    Jan 2002
    Location
    Kirkland, Wa.
    Posts
    4,315
    Quote Originally Posted by Hwilli View Post
    Actually, that is real good question. I don't forsee any issues. These new turbo's don't flow enough that would cause this to malfunction. But, on the other hand I think the reed valve is a weak link in the "seq" system anyways. It's like other parts, its a restriction. What I am currently doing is re-shaping the reed area so it will offer a better release of back pressure. EBT covers the exhaust side, but nothing really addressses the pressurized side. So that is why I am seeing if porting out this area may reduce the "dip" and allow more air to flow.
    Stu
    1998 TT 6 Sp Hardtop-GT28 Hybrid Turbo's-1/4 Mile [email protected]
    Aug-2015 722whp: 715TQ- Std 26psi. E85 tuned Vipec
    Technical Info/Scans & Specs Seq FAQ
  25. #123
    SupraForums Member
    Join Date
    Apr 2001
    Location
    Cerritos, CA
    Posts
    1,355
    Stu,
    I haven't seen anyone ask about a front mount intercooler with these hybrids. How much, if any, difference would that make, and what type would be the best?
    This is a really exciting subject that a lot of people are interested in. Great stuff!
  26. #124
    SupraForums Member aaron300's Avatar
    Join Date
    Aug 2002
    Location
    Cincinnati OH
    Age
    48
    Posts
    281
    Quote Originally Posted by $9ktt View Post
    I am booked through August. When my current batch is done I could do another batch of 4-5 sets in September if there is enough interest. People should contact me through Stu or send me a PM if they are interested. If money is no object and you have the time/skills to make the GT upgrade work I would have to agree that in theory it is the better option for reliability and increased power.
    Also, as a possible solution for people overseas I could make sets of just the compressor wheels and compressor housings, and then the rest of the upgrade work could be done at a local reputable shop. The compressor wheels and housings are fairly light, so shipping would not be terribly expensive. I shipped a fully assembled set to Australia and the best I could with insurance was around $450 for shipping... not so good.
    89T 325 RWHP
    Ported head 1mm over valves
    Probe/Eagle/Std Clevite/Titan 1.4mm
    60-1 CT26
    Lex Afm Venom 550's
    Defcon DP, Blitz Nur Spec
    Profec B Spec 2
    3.73 Torsen ('Personal' model LOL)
    20X12X3 IC ($400 home brew kit)
    Apex-i SAFC
    Haste Radiator & twin Flex-a-lites
    XTD Clutch
    Autometer AFR & FP Gages
    Aeromotive AFPR
    Trust/Grex front strut bar, Eibach Springs, ST Sway Bars
    94 Supra TT
    Profec B Spec 2
    Old school Trust/Greddy Twin 3" catback 3" DP
    02 Lexus IS300
    Revived from the depths of repo hell
  27. #125
    Join Date
    Sep 2005
    Location
    Posts
    1,001
    Good stuff good stuff!
+ Reply to Thread
Quick Reply Quick Reply
Register Now
List your Car(s)
Where you live
Log-in
Posting Permissions
  • You may post replies
  • You may not edit your posts
