gauges, WB, made EASY! Writeup included - Page 3
+ Reply to Thread
Page 3 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 51 to 75 of 103
Thread: gauges, WB, made EASY! Writeup included
  1. #51
    SupraForums Member slither's Avatar
    Join Date
    Aug 2002
    Location
    Virginia
    Age
    41
    Posts
    6,785
    Just ground using the factory grounding points. Works for me many times
    AboveFab(supra fabrication)
    Feel free to text me with any questions/tech/advice/info. Its quicker and more personal than pms and you are sure to get a quick response. 434-470-2700
  2. Remove Advertisements
    SupraForums.com
    Advertisements
  3. #52
    SupraForums Member
    Join Date
    Nov 2004
    Location
    Sacramento, CA
    Posts
    1,060
    Just wanted to thank Slither for the help! I have finally gotten enough knowledge and equipment to install this set up. And my first accessory install took me 5 minutes to set up.. and that included the wire cutting and terminal crimping time.
    Just a few follow up questions, the relay was starting to get warm and I am assuming that its normal? Also, I need to insulate the terminal connections to the relay... does electrical tape work? Finally, I want to install a switch to be able to turn off the wideband display for stealth look, do I install that in series to the ground wire or the switched 12v?
  4. #53
    Join Date
    Aug 2002
    Location
    Virginia
    Age
    41
    Posts
    6,785
    I use insulated terminals, however electrical tape will work or shrink tubing. As for turning off the wb display, either will be fine. Make sure its turning off just the display and not the wb controller though
  5. Remove Advertisements
    SupraForums.com
    Advertisements
  6. #54
    SF Contributing Member bitshftr's Avatar
    Join Date
    Jan 2009
    Location
    Raleigh, NC
    Age
    51
    Posts
    2,903
    Quote Originally Posted by shenofjo View Post
    +1 for heat shrink tubing. It works great, leaves no sticky residue, and makes a more refined-looking result.
    1995 Supra NA, Baltic Blue, targa, TRD LSD, Recaro Sport seats, Cusco carbon fiber front/rear strut tower bars, 97+ front turns
    Passport hardwired, w/ amped remote speakers in seat harness slots
    Hidden/hardwired garage door opener w/ custom Supra dash button
    1995 Supra TT, BPU+, Baltic Blue, targa, TRD front/Cusco rear strut tower bars, 98 headlights w/ 6k HIDs, 97+ front turns, BNR turbos, Tial BOV, HKS Super Drager exhaust, SSR Professor SP1 wheels, Racelogic TC, VPC/GCC
    Passport hardwired
    Subtle white LED dash backlights
  7. #55
    Join Date
    Jan 2009
    Location
    Raleigh, NC
    Age
    51
    Posts
    2,903
    I had forgotten about this thread, but remembered the concept, and just used it when wiring some accessories into my "new" Supra (TT). The install is very clean. I tapped into the empty Seat Heater fuse slot (driver's side kickpanel fuse box) for power when the ignition is ON, using a male "flag" quick-disconnect terminal and 12-gauge wire.
  8. #56
    Junior Member
    Join Date
    May 2011
    Location
    Houston, TX
    Posts
    126
    im thankful for this resurrection. Good info. Ill definitely be making use of these bars.
  9. #57
    Join Date
    Jan 2009
    Location
    Raleigh, NC
    Age
    51
    Posts
    2,903
    Instead of the terminal strip, I used CageClamps (see pic below) on my last wiring job. They're extremely simple to use, small, and don't expose any metal conducting material.
  10. #58
    Join Date
    Aug 2002
    Location
    Virginia
    Age
    41
    Posts
    6,785
    Bitsftr. Are they available at regular stores or only offered online?
    You can get as creative as you want, this writeup made it very simple to understand how to make your own circuit. You can get as crazy as you want.
    For example, for a customers car, a shop had done a ridiculously disgusting wiring job. When I rewired everything, I used kickass electronic tech approach using ferrels($3 each),quick disconnect "field connectors using pimped out hks purple can cable.
    My point is, for some this will be there first built circuit, when you understand the principal, go crazy with it! A lot of wiring issues comes from not knowing, if this writeup has helped wire up a mkiv correctly when otherwise it would have been done wrong, then goal accomplished
  11. #59
    Join Date
    Jan 2009
    Location
    Raleigh, NC
    Age
    51
    Posts
    2,903
    Quote Originally Posted by slither View Post
    Search Amazon for "Wago 222" and you'll see a bunch of sizes.
    Slither, this thread should be required reading for anyone thinking about doing any wiring in their car. Like you said, the principal is sound, whether you use a terminal block or "Wago 222" cage clamps. I used terminal blocks on my 4Runner, and the cage clamps on my new Supra. I hate to see a hack job of wiring. Just today, I was removing some stuff from my new Supra and found several vampire taps (hate them...PosiTaps are much cleaner), but the worst part was where someone had stripped off some OEM wire insulation, spread the copper wires, inserted a non-native wire, and just twisted it and covered it with electrical tape. I almost barfed.
  12. #60
    Join Date
    Aug 2002
    Location
    Virginia
    Age
    41
    Posts
    6,785
    Haha got ya beat. How about a customers car that was built by a shop using speaker wire for fuel pumps lol
  13. #61
    Join Date
    Jan 2009
    Location
    Raleigh, NC
    Age
    51
    Posts
    2,903
    You win.
    Here's another I found this weekend: one of the previous owners removed the stock sub box. To do it, they cut the two wires that run thru the subbox, thru the bottom of the car, to the wheel hubs (I'm guessing these are the wheel speed sensors for the ABS). If that wasn't bad enough, they then spliced them back (they did solder them at least) and wrapped them in electrical tape, but didn't wrap each of the 2 conductors separately. So occasionally, I was getting complete ABS/Traction control failure (4 warning lights on the dash all at once) when the two wires touched each other...even for a moment.
  14. #62
    SupraForums Member
    Join Date
    Nov 2004
    Location
    Sacramento, CA
    Posts
    1,060
    Just wanted to say I was able to install the innovate WB with the set up and it worked flawlessly! I also added the toggle switch to manually turn off the gauge. its also my first day with my RT DP back on and boosting to 0.9bar... and saw my AF ratio go straight to 10.1 on WOT!! otherwise, it stays around 14.0-14.4 on idle. gonna have so much fun noob tuning with EMB and my innovate WB.
  15. #63
    Join Date
    Jul 2010
    Location
    Boise, ID
    Age
    35
    Posts
    13
    I'm planning on using this concept for wiring in my car but I'm going to have 3 terminal strips (ordered the wago 222-415) for constant 12v, switched 12v and ground. That way I'll have all my bases covered when it comes to adding accessories to my car. Thank you for the ideas this will be SO much easier!
  16. #64
    Join Date
    Jan 2009
    Location
    Raleigh, NC
    Age
    51
    Posts
    2,903
    ^^ 208SUPRA, that's the takeaway from this entire thread...well said.
    I'm a big fan of the Wago 222-415, a.k.a CageClamps.
  17. #65
    Join Date
    Aug 2002
    Location
    Virginia
    Age
    41
    Posts
    6,785
    208supra. Remember that anything that needs a dedicated 12 is usually pulling many amps, hence the need for the relay, so if you go this route remember than you will have to have the line side much larger. In cases like this I usually run quality distribution blocks normally found installed on vehicles with upgraded sound systems
  18. #66
    SupraForums Member
    Join Date
    Mar 2001
    Location
    Atlanta
    Posts
    248
    Another option is the Centech AP-2. Below is a photo of the board itself so you can see how it has the three common lines (eight ground/three batt/five pwr).
    SP
  19. #67
    Cultured Development Dominator19's Avatar
    Join Date
    Mar 2004
    Location
    Charlotte NC/SC
    Age
    30
    Posts
    319
    Sorry for bumping an old thread but I'm still an amateur when it comes to wiring. I'm currently adding 3 Greddy gauges to my current setup and they all require a: 12v power source, ignition source, light source, and ground. Ive got the 12v power source covered thanks to this thread and grounding them is no problem. My issue is figuring out how to apply the terminal strips to the ignition and light sources needed. Where can I tap into these sources and how exactly would I hook the terminal strips up? Will these strips need relays or not since they wont be used to power the gauges? Sorry again in advance but like I said, I am pretty inexperienced when it comes to electrical work and I want to set this up right and not have to worry about it again if I ever add anything else. I should probably also mention that I have a prosport oil pressure gauge and plx m300 wide band currently hooked up via the oem clock harness and hvac harness.
    95 Ren Red 6speed MKIV APU
    ~ Original 3.0 w/ GSC S1 cams, ProEFI, ID2000's, PTE7675CEA, RPS C/C,, TRD, CCW ~
    - 612whp on 93oct -
    - 871whp on e85 -
    Tuned By [email protected]Induction Performance
  20. #68
    Join Date
    Jan 2009
    Location
    Raleigh, NC
    Age
    51
    Posts
    2,903
    Dominator, a good source of ignition power is the unused seat heater fuse socket in the fuse box at the driver's left kickpanel. Stick a "flag" terminal into the top contact of that fuse socket, add an inline fuse, then run that wire (14 or 12 gauge) to wherever your gauges are. This is your "ignition power bus". Tap into that wire with Posi-taps (or something similar) for each component that needs ignition power. You will not need a relay since the gauges don't draw a lot...the seat heater circuit is rated at 15 amps...but good practice is to add up the current draw of each thing you're connecting to the circuit to make sure the total doesn' exceed the circuit's rating.
    For light source, I run an "illumination+" bus using the same concept, but my source is the cigarette lighter illumination+ wire. I use a Posi-tap on this wire, which is 12v hot when the parking lights or headlights are on. Note that there's also an illumination- (negative) wire connected to the cigarette lighter, which is grounded through the dash-light-dimmer rheostat. I generally run an "illumination-" bus off this wire, which I use as illumination- for the backlights of added buttons, and some stereos. Neither of my gauges allows for the use of this wire though.
  21. #69
    Join Date
    Jan 2009
    Location
    Raleigh, NC
    Age
    51
    Posts
    2,903
    ^^ Also, forgot to mention that the seat heater circuit is on when the key is in the IGN or START positions, which makes it nice because that power doesn't cut out while starting the car.
  22. #70
    SupraForums Member
    Join Date
    Jul 2002
    Location
    Tampa, FL
    Posts
    5,231
    Dunno why this hasn't been stickied yet... Am replacing my carpet soon and planning to do separate ground/key/B+ strips, when I pull the dash. Thanks again for the write up (am sure it's helped many of us already)!!!
  23. #71
    SupraForums Member
    Join Date
    Nov 2004
    Location
    Sacramento, CA
    Posts
    1,060
    good tip on the seat heater fuse.. will look into that over the weekend as well!
  24. #72
    SupraForums Member
    Join Date
    Jun 2008
    Location
    South FL
    Posts
    561
    here is a little trick, instead of using a bunch of small jumper wires on the terminal block, use metal jumpers. works great and makes for a cleaner install
    as the boost rises and the adrenaline set in, the world stops, life stands still and for the first time i feel at peace
  25. #73
    Join Date
    Jan 2009
    Location
    Raleigh, NC
    Age
    51
    Posts
    2,903
    ^^ Yes, as stated in post #36, there's a single strip you can use:
    One suggestion: instead of making 7 "jumper" wires for the terminal block, pic up an "8-Position Jumper" strip (Model 274-650, $2.19) while you're at Radio Shack. Much neater and more reliable.
    But this still leaves metal exposed, which is a bad idea for power buses. The Cage Clamps make a quicker connection and don't expose any metal.
  26. #74
    Join Date
    Aug 2002
    Location
    Virginia
    Age
    41
    Posts
    6,785
    Guys you can go as crazy as you want, hell you could run a plc based system if you have the time. I showed the simple terminal strip because there's nothing to ever arc(no metal exposed) and no circuits to screw up. Go nuts with it now that the idea is in ur head.
    Bitshifter, pm coming. Just seen I had one from u from a while back
  27. #75
    SupraForums Member
    Join Date
    Nov 2004
    Location
    Sacramento, CA
    Posts
    1,060
    SO I followed the wiring set up this way to set up my innovate WB and all is good. today I decided to check on my amp draw since my battery cant last more than 3 days and its a new battery. I find that the fuse to the set up goes way up to 136.6ma. how do I modify the wiring to not do this? add a switch to before power gets to the relay? permanent solutions appreciated
    93 Alpine Silver TT Auto BPU: HKS Super Dragger, Random Tech hi flow cat, IK22 .032", K&N filter, Synapse DV diverter valve, MVP bcc, ebv spring mod x2 @ 13 psi, wg spring mod x3, innovate SCG-1 ~17 psi, emanage blue
    Cooling: AIS W/M injection 12GPH, SM auto trans cooler external filter, CSF rad
    Suspension and Handling: TRD front strut bar, bilstein shock/oem spring combo
+ Reply to Thread
Quick Reply Quick Reply
Register Now
List your Car(s)
Where you live
Log-in
Posting Permissions
  • You may post replies
  • You may not edit your posts
