JZA80 Differential Info! - Page 6
+ Reply to Thread
Page 6 of 12 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 LastLast
Results 126 to 150 of 290
Thread: JZA80 Differential Info!
  1. #126
    SupraForums Member HoeBag's Avatar
    Join Date
    May 2004
    Location
    Houston
    Posts
    127
    Quote Originally Posted by 360rwkw View Post
    Yes you can. I know because I have one in my UK spec TT auto diff. This is the big 220mm diff with 3.538:1 ratio. As far as I know you can buy a TRD LSD for both the small and big diffs (make sure you buy the correct one for your diff) and they will fit in to all the mkiv Supra diffs.
    do you know the part # for the trd lsd for the 200mm differential (v161)? i have been looking everywhere but cant find anywhere to buy it.
    2jznoshit.com
  2. Remove Advertisements
    SupraForums.com
    Advertisements
  3. #127
    SupraForums Member
    Join Date
    Apr 2004
    Location
    Auckland, New Zealand
    Age
    60
    Posts
    1,536
    Curt at Elmhurst Toyota sells the TRD LSD's.
    V8KILR - Precision 6870 AR 0.81, SPA manifold, 4" down/mid pipe, 3.5" AdrenalinR mufflers, Link G4, E85, 760whp @ 26psi (Dyno Torque), Getrag 6 spd, 10.94 @ 130 mph (19 psi low boost run as no cage).
    Owned and raced since Feb 1998.
    http://www.mkiv.co.nz
  4. #128
    SupraForums Member
    Join Date
    Feb 2001
    Location
    SE PA
    Age
    69
    Posts
    13,561
    Hopefully Wreckless Jeff will see this, or if anybody else has input on this point I'm curious what you all think:
    This has to do with proper installation of the OS Giken Super Lock LSD and a mod that is apparently required for some JZA80 diffs to make it fit right, but it's not clear to me what diffs need this mod. On their site http://www.osgiken.net/techcenter.php they have this mod note download:
    Does anyone know what diffs need this mod?
    PS: if this shouldn't even be in this thread please let me know and I'll try to have it deleted from here and moved to another thread about LSD diffs.
    Nick 95 6sp
    Twin Garrett GT2860's w/TiAL SS exhaust housings, WG's and BOV's, V-band moded HKS twin manifolds, AEM v2, AEM WB, ID1000's,
    AEM meth/water spray, GSC S1's, ported head, Ferrea valvetrain, CP pistons w/crown & skirt coatings, Carrillo H-beams,
    OS Giken triple clutch & Super Lock LSD, Racelogic TC, TRD gen2 catback
    street wheels: Veilside EvoV 9-1/2"F X 10-1/2"R with 265/35F & 285/35R NT05's
    track wheels: CCW LM5 10"F X 11-1/2"R with 285/30F & 315/30R R888's
  5. Remove Advertisements
    SupraForums.com
    Advertisements
  6. #129
    Car guy
    Join Date
    Sep 2005
    Location
    Hillsboro, Oregon
    Age
    49
    Posts
    803
    Quote Originally Posted by HoeBag View Post
    You will use a Auto TT TRD for the 200mm diff. MVP sells them as well as most any Toyota dealership. John
    1995 Supra Black/Black Hardtop, 6-speed single turbo 630 rwhp pump gas/meth. (my weekend car)
    1998 Supra Imperial Jade Mica Auto, single turbo 390 rwhp at 14 psi pump gas (wife's weekend car)
    2008 Tundra, Nautical Blue Crewmax Limited, something has to be stock.
    1995 Mr2 turbo, White/tan w/gen4 swap, 5-speed.
    1989 Mitsubishi Starion Red/Black turbo 5-speed hardtop (Retro beater)
  7. #130
    Super Moderator Wreckless's Avatar
    Join Date
    Feb 2002
    Location
    Albuquerque, NM
    Posts
    9,843
    Quote Originally Posted by Nick 95 6sp View Post
    Nick, thanks for posting this as this is good info!
    Long story short, the actual axle stubs that Toyota used with these differentials have a surprising amount of variety, considering the consistencies everywhere else in the car. For instance, when installing a clutch type LSD in a Supra or Soarer that came with the 200mm diff and a factory LSD, the axle stubs from LSD-equipped cars are slightly too long for a proper fit with a TRD or other clutch type LSD. For the most part, this is usually taken up by tolerance creep between parts and no problems are experienced, and the tension from the installed axle halfshafts themselves usually keeps the axle stubs in place, but this sometimes becomes problematic when wheelhop, etc, is experienced and the axle stubs actually pop out just enough to induce a gear oil leak, and because of that possibility, many LSD makers list a need for the factory Toyota OPEN differential axle stubs to be used when installing a clutch type LSD.
    Since the 220mm diff as found in the pre-'minor change' JDM 6-spd TT models (which includes ALL of the US TT 6-spd's and European delivered TT big diff vehicles, I should mention) always came with a Torsen LSD, the axle stubs are also slightly longer than would be used with most clutch type LSD's. The TRD LSD was probably designed to accommodate those stock axles, but because of possible fitment issues, OS Giken has published this just in case a tolerance issue arises and those axles have occasion or cause to pop out under wheelhop conditions, etc. As long as your LSD is working normally and no leaks or problems with the axle stubs popping out has been experienced, I'd say you're probably just fine.
    But if you go back into the diff for any other reason, probably wouldn't be a bad idea to take the stubs to get milled down as shown in the pics to ensure that it never becomes a problem later on.
    Cliffs:
    If you've got a clutch type LSD in a 220mm diff, and you're experiencing an issue where the axle stubs pop out after hard launches, high speed pulls, or after wheelhop, and thus cause an oil leak, pull both axle stubs and have them milled in accordance with the pictures. The TRD LSD was probably designed to accommodate the stock axle stubs though.
    If you're installing an OS Giken Super lock into a 220mm diff, you might as well have your axles modified 'while you're in there' during the installation. The modified axles will not affect the stock torsen LSD should you chose to revert to the OEM Torsen for any reason.
    Jeff
    "I spent a lot of money on booze, chicks and fast cars. The rest I just squandered." -- George Best
    Quote Originally Posted by KING View Post
    Who would have ever thought.....the impact an automobile can make.....
  8. #131
    SupraForums Member
    Join Date
    Feb 2001
    Location
    SE PA
    Age
    69
    Posts
    13,561
    ^ Thanks a lot, Jeff. My Super Lock has been in there for several thousand miles and a few track days with no issues, leaks, or noises, so I feel pretty good that all is fine. But I'll make it a point to do an inspection sometime soon. I'll report back in this thread for the record.
  9. #132
    Turbo Pilot Since 1983 BamaDave's Avatar
    Join Date
    Apr 2003
    Location
    South Alabama "Gulf Coast"
    Posts
    1,116
    Nick,
    Thanks for posting this and getting the ball rolling!
    Jeff,
    Thanks for the certification as I located this tech article when doing some research on the LSD as I’m undecided between the OS Giken Super Lock and a Carbonetic LSD. I guess this condition will apply to any clutch type LSD and now I’m wondering if this clearance issue will apply to the Carbonetic as well. Hopefully others will see this and chime in with their experience. Although, if this was a common occurrence we’d have seen someone’s posting before now.
  10. #133
    SupraForums Member
    Join Date
    Feb 2001
    Location
    SE PA
    Age
    69
    Posts
    13,561
    Dave,
    I'm glad you saw this and thanks for bringing our attention to that Giken tech note.
    Since my Super Lock is working perfectly, making no noises, and no leaks at all for several thousand street miles and a few track days, it minimizes my concern about a clearance problem. In any case, sometime in the near future I'll have it opened and inspected and report back here.
  11. #134
    SF Contributing Member miller11386's Avatar
    Join Date
    May 2012
    Location
    Canton, Ohio
    Posts
    1,227
    I am trying to identify what differential this is. Can anyone help? I am having the guy get the part number off of it, but I was curious if anyone can tell me from these photos. The ring gear has 000-6y00103 on it. I am confused because from what I read, a 10 bolt is an NA differential pumpkin, however it looks like this one actually has an LSD vs an open differential to my eye. I have to drive a distance to get it, so I would rather know before hand if it is an LSD diff than getting there and spinning it and seeing its open. Any help is appreciated.
  12. #135
    Join Date
    Feb 2002
    Location
    Albuquerque, NM
    Posts
    9,843
    The NA's and TT Autos had the same carrier and 10 bolt ring gear aka 200mm housing aka 'small diff' so all we know from it being a 10-bolt is that it isn't from an export TT 6-spd or early JDM TT 6-spd. The finned housing tells us it probably came from a JZA80 Supra or a JZZ30/UZZ30 Soarer, as GS400 and later Aristo pumpkins were smooth.
    Have the seller or whoever has this diff rotate the axles until the pinion gears of the differential are visible.
    From that angle it looks like an open diff to me but there's no way to tell, and I suspect the seller probably knows that. Have the seller count the teeth on the ring gear and you can use that number to cross reference the ratio charts on the first pages of this sticky so you can narrow down the potential vehicles it came from, and make your own decision on whether or not it might be an LSD from there.
  13. #136
    SupraForums Member
    Join Date
    May 2010
    Location
    Greenville,SC
    Posts
    442
    Will LS400 diff work too?
  14. #137
    Join Date
    Mar 2012
    Location
    Oman
    Posts
    63
    Are the any difference between 2j turbo 6speed differential and 2jz automatic transmit ion differential what is the difference between them from out side shape and internal please I need the corect info thanks for all
  15. #138
    Join Date
    May 2011
    Location
    Okinawa, Japan
    Age
    31
    Posts
    10
    I truly appreciate the info
  16. #139
    Bullseye Dealer mk4umha's Avatar
    Join Date
    Sep 2001
    Location
    Round Rock
    Posts
    1,082
    If I have the JDM 200mm Diff with the subframe and axles attached, then bought a US Spec 220mm, do I need to also buy L/R axles too?
    Maybe I should just buy an Auto clutch diff and live with the 200mm?
    BEP374R FTMFW! 690WHP/620WTQ @ 22.5 PSI E85 - 198K Miles on the motor!
    2JZ-GTE VVTi Swap into SC300
  17. #140
    Champagne Papi Shant's Avatar
    Join Date
    Dec 2002
    Location
    Burbank, CA
    Age
    31
    Posts
    5,661
    Blog Entries
    1
    Is this a TT diff?
  18. #141
    SupraForums Member
    Join Date
    Apr 2004
    Location
    Age
    60
    Posts
    1,536
    Its not the big diff, but it could be from a TT auto or post May 96 JDM TT 6 speed. Check the ratios to find out and open the back to see if its a torsen diff.
  19. #142
    SupraForums Member
    Join Date
    Feb 2011
    Location
    NC
    Posts
    402
    Doing the 6 speed swap in my 93 TT auto and recently purchased (from what i was told) a US spec TT 6 spd diff. Before i go through the process of installing is there anything i should or could look for on the diff to confirm which it is? All i can tell from the outside is it does have the cooling ears on the cover and the cover has never been removed. also when taking both output axle flanges and turning them in the same direction the pinion flange turns.
  20. #143
    SupraForums Member
    Join Date
    Apr 2004
    Location
    Age
    60
    Posts
    1,536
    If it has the cooling ears then it is the big torsen diff. Could be US or JDM diff, but ratios are very similar so that will not matter.
  21. #144
    SupraForums Member
    Join Date
    Feb 2011
    Location
    NC
    Posts
    402
    Yeah looking at it and reading the swap page. It is longer front to rear than the auto diff and the left side sticks out more as well.
  22. #145
    SupraForums Member VoodooMan's Avatar
    Join Date
    Jun 2007
    Location
    Orlando/FL
    Posts
    142
    Anyone try 2.937 raito from Lexus IS-F?
    スープラ TT 6MT
  23. #146
    Join Date
    Feb 2002
    Location
    Albuquerque, NM
    Posts
    9,843
    Quote Originally Posted by VoodooMan View Post
    I haven't been able to get eyes on an IS-F diff with the cover plate removed to see if it'd swap into either the large or small Supra diff. I know the cover plate is very different from any Supra designs but the diff carriers themselves look VERY similar to the Supra/SC/GS pattern diffs. Of particular note is that the IS350 diff seems very similar in size to a 200mm TT auto diff, and even the casing bears a very strong resemblance to the 200mm carriers found in Lexus SC's and GS's. The IS-F diff seems to be a bit larger, and somewhat similar to that of a 220mm diff pattern, but I've also read about IS-F guys swapping to an IS350 diff for shorter gearing without changing the axles or driveshaft or anything else. So the actual sizing and its potential compatibility in a Supra is still something of a mystery.
    If I get a chance to snag an IS350 diff for cheap, I might do that just for the sake of research, and investigate IS-F compatibility from there.
    In the meantime, anyone that happens to have a Supra and an IS-F and wants to drop both differentials for an experiment over the weekend, and take pictures & measure accordingly, I'd love to see that info, and I'd update this sticky accordingly.
  24. #147
    Join Date
    Jun 2007
    Location
    Orlando/FL
    Posts
    142
    Draw of IS F diff, it have 8.2" 208mm final gear
  25. #148
    SupraForums Member
    Join Date
    Jul 2013
    Location
    United Kingdom
    Posts
    176
    Great thread this very helpful info, it will be the B03B big case I shall be after then
    93 UK6 BPU+
  26. #149
    Join Date
    Jul 2013
    Location
    Tampa BayArea
    Posts
    24
    Wow lots of great info here. I was out looking at a local guys Toyota parts for sale and he had a torsen LSD. Said it was for a supra. Took a chance and brought it home. Didn't have time to research it. Well, come to find out thanks to this thread.. its an LSD for a 6 speed and will not fit in my SC300 diff case. I did learn about the 12 bolt vs the 10. Question is, will this LSD fit anything else besides the larger 6speed diff? Did I buy a cool looking paper weight??
  27. #150
    Join Date
    Feb 2002
    Location
    Albuquerque, NM
    Posts
    9,843
    Quote Originally Posted by Soarin96 View Post
    At this point the only confirmed fitment I know of for the 12-bolt Torsen LSD are the 6-spd 220mm pumpkins they came in. So it's paperweight status unless you find a 6-spd diff casing, ring, and pinion randomly without a diff section. Sorry man
+ Reply to Thread
Quick Reply Quick Reply
Register Now
List your Car(s)
Where you live
Log-in
Posting Permissions
  • You may post replies
  • You may not edit your posts
