Auto Shifter Bushings
+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 25 of 30
Thread: Auto Shifter Bushings
  1. #1
    SupraForums Member T6Rocket's Avatar
    Join Date
    Mar 2002
    Location
    Raleigh, NC
    Posts
    4,165
    My automatic shifter is loose from side-to-side. Curt from Elmhurst sent me a diagram showing two bushings that could be the culprit. Replacing them looks very tedious as many cables/connectors, etc are in the way of removing the shifter assembly and console.
    Anyone had any luck with tightening up a loose auto shifter by replacing the bushings?
    Thanks,
    Al
    94TT Auto, 6466
    [email protected] 27 psi 4/16/16
    Previous setup: HKS Twin 2835's
    [email protected] 32 psi, 10/29/06
    Previous car: 90 Talon AWD, 5 spd, FP Red (60-1)
    [email protected] built motor, 28 psi, Sept 2000
  2. Remove Advertisements
    SupraForums.com
    Advertisements
  3. #2
    Luvs ( . ) ( . )s StickyRice's Avatar
    Join Date
    Nov 2005
    Location
    Richland, WA
    Age
    37
    Posts
    2,087
    I have a complete auto shifter if you got a pic of the bushings I can check and see how hard it would be to replace.
  4. #3
    The Great Kruso Kruso's Avatar
    Join Date
    Mar 2002
    Location
    Sugar Land, TX
    Posts
    3,876
    Al, when I did my manual conversion I recall it being very easy to remove the shifter assembly, the only tricky bolt to get to was the one you have to loosen from the bottom onto the trans.
    1991 MKIII Toyota Supra 1JZ, the "official" FFIM MKIII- Officially stolen.
    1994 MKIV Toyota Supra Single T70, Fuel, MAP ECU, RPS 6 puck................Sold.
    1993 MKIV TT w/ 79k original miles APU
    2011 Toyota Tundra 5.7 Rock Warrior
    Quote Originally Posted by Zach90Turbo View Post
    When I put 7M in the search it only came up with blown head gasket threads.
    "There is so much good in the worst of us, And so much bad in the best of us. That it behooves all of us Not to talk about the rest of us."
  5. Remove Advertisements
    SupraForums.com
    Advertisements
  6. #4
    Join Date
    Mar 2002
    Location
    Raleigh, NC
    Posts
    4,165
    Quote Originally Posted by StickyRice View Post
    I cant attach the pic, but they go on each side of the T shaped metal tube at the bottom (the pivot point for the shifter). Not sure what holds them in place.
    I can e-mail you the pic if needed.
    Thanks!
    Al
  7. #5
    Join Date
    Nov 2005
    Location
    Richland, WA
    Age
    37
    Posts
    2,087
    Quote Originally Posted by T6Rocket View Post
    Thanks!
    Al
    Gotcha, I'll check it out and report back.
  8. #6
    SupraForums Member
    Join Date
    Sep 2005
    Location
    Irving, texas
    Age
    34
    Posts
    101
    how much for the full auto shifter? pics?
  9. #7
    Join Date
    Nov 2005
    Location
    Richland, WA
    Age
    37
    Posts
    2,087
    Well looked at it, don't seem too hard. You take the whole assembly out, 4 screws 3 plugs and a little eclip or what not underneath the car. Then you remove the rubber boot, shifter knob, and the bolt that the boot is covering and should be able to get it out.
    But depending on the price of the bushings might be cheaper to just find a nice used assembly.
  10. #8
    SupraForums Member HotSoup's Avatar
    Join Date
    Feb 2002
    Location
    North Carolina
    Age
    40
    Posts
    9,478
    Al,
    What did you find out with this? Mine has alot of side to side slop that I dont remember it having before and I would like to fix it if possible.
    Jason
    1994 Red/Black TT
    86K miles
    Roller...6 speed swap coming soon
  11. #9
    Join Date
    Mar 2002
    Location
    Raleigh, NC
    Posts
    4,165
    I ordered four bushings from Curt (two for spares): 90385-11003 BUSH (FOR FLOOR SHIFT CONTROL SHAFT)
    He said that is the only part that seems to wear out. They are pretty flimsy plastic. He also sent an exploded view of the shifter, which is nice since that is one complicated component with all the switches, wires, etc you have to remove to get it out. I have no idea where that harness plugs in that keeps you from pulling the console all the way out.
    Have not installed them yet. I am waiting to do it while the car is down for other work.
    Al
  12. #10
    Join Date
    Feb 2002
    Location
    North Carolina
    Age
    40
    Posts
    9,478
    Is this something that could be machined from a billet piece that would eliminate the need for replacement ever again? Send me that pdf to [email protected] if you dont mind Al.
  13. #11
    SF Contributing Member Tayousei's Avatar
    Join Date
    Jun 2009
    Location
    Winnipeg, Canada
    Posts
    2,165
    I have the same sloppy shifter issue and if you come up with a billet or polyurethane piece I'm in for a buy.
  14. #12
    Join Date
    Mar 2002
    Location
    Raleigh, NC
    Posts
    4,165
    The bushings are a very thin plastic-like material. They might need to be plastic for the whole unit to snap in place, cause there appears to be no bolts to tighten to install them.
    Al
  15. #13
    Join Date
    Mar 2002
    Location
    Raleigh, NC
    Posts
    4,165
    Anyone install new bushings yet?
    I am working my way down in there, just looking for any tips to make it easier. About to cut the console in half so I can remove it completely despite the cable Toyota loops over the center mount so you cant get the console all the way out, fuckers!.
    Al
  16. #14
    Join Date
    Feb 2002
    Location
    North Carolina
    Age
    40
    Posts
    9,478
    Not yet Al, I am going to start on my interior soon and I will look and see what the deal is. I have noticed that the shifter is alot looser in 1,2,D than it is in R,P,N is yours the same?
    Jason
  17. #15
    Join Date
    Mar 2002
    Location
    Raleigh, NC
    Posts
    4,165
    I didnt notice which gears were worse, just that the last time I drove the car it was really bad. I am going to remove the whole shifter unit, taking off only the wires necessary (of which there are many!) The bolt/bushings look like they are below the mounting plate.
    Al
  18. #16
    Join Date
    Mar 2002
    Location
    Raleigh, NC
    Posts
    4,165
    I finally took the shifter out, the bushings were gone except for a few crumbs! The bolt that holds them in is under the mounting plate, have to remove the rubber cover.
    To get the thing off, start by completely removing the console (I had to cut mine b/c of cable over the center mount). Then, unhook all the wires, and pop off the zip tie wire mounts, and take the whole shifter unit out with the plastic covers for PRND21 and everything else intact. Dont have to take the shift knob or anything else apart.
    After putting some grease on the bushings and installing, the is no play whatsoever. I doubt you could make them out of alum, they are very thin.
    Al
  19. #17
    Join Date
    Feb 2002
    Location
    North Carolina
    Age
    40
    Posts
    9,478
    Nice Al! I will take a look at them when I get the shifter out. I can probably make them out of aluminum shim material if they are that thin. You didnt happen to take any pictures did you?
    Jason
  20. #18
    Join Date
    Mar 2002
    Location
    Raleigh, NC
    Posts
    4,165
    I still have the shifter out of the car, but you cant really see anything. You will need to get factory bushings to model alum bushings after.
    I think they are too thin to make out of alum (1/32" in one direction, 1/16" on the side). You would be fine with just new factory ones since the first set lasted 17 years and 90k miles! They are only $3.
    Al
  21. #19
    Join Date
    Feb 2002
    Location
    North Carolina
    Age
    40
    Posts
    9,478
    Al
    Very true Al! I will just get some new ones then. I will go ahead and buy 2 sets that way I can replace them again in 17 more years LoL
    Jason
  22. #20
    SupraForums Member
    Join Date
    Jun 2008
    Location
    Dallas, TX
    Age
    45
    Posts
    123
    Al
    You didn't have to cut anything! A serious pain in the rear yes, but you just have to unclip the overdrive and gear selector light connector. Although it is a B-Effin'
    Funny that I found this today... as I spent one of my days off this week jacking with *my* shifter (A '98 with 147K miles it just went loose overnight it seems) I was already in there and had things torn apart to install a new overdrive switch...so I wanted to get to the bottom of the recent loosening of the shifter.
    Can you look at the pics and tell me if this is the same location where you put your bushings?
    I went to Home Depot, and found some nylon spacers and ground them to fit...
    Then I simply "press fit" them into place. vs pulling down the rubber boot to get at the retaining bolt and taking the whole thing apart.
    Plain view...
    Label View. I'll try and grab some pics tonight so you can see one of the home grown nylon bushings.
    Link to video of loose shifter...
    -Jacques
    The Dallas Canadian
  23. #21
    SupraForums Member
    Join Date
    Apr 2003
    Location
    MIAMI
    Age
    44
    Posts
    516
    Just ran across this thread, I had the same issue years ago and resolved it by taking apart the shifter and wraping the shaft (where the shifter mounts with aluminum tape until it fit snug. I then applied thick grease to the outside of the aluminm tape and assembled the shifter been solid ever since. getto fix FTW! lol
  24. #22
    Join Date
    Mar 2002
    Location
    Raleigh, NC
    Posts
    4,165
    Quote Originally Posted by yibuy4n View Post
    You didn't have to cut anything! A serious pain in the rear yes, but you just have to unclip the overdrive and gear selector light connector. Although it is a B-Effin' ..
    Mine had a huge cable that ran from under the carpet up over the console then under the dash that prevents the console from coming all the way out. I would rather cut the console than take the dash panel off again! I will reinforce it good as new.
    I cant see PB pics at work. I dont see how you can put spacers in w/o taking the bolt out, unless they are "half moon". The bushings are $3 each, just do it the right way!
    Al
  25. #23
    SupraForums Member
    Join Date
    Jun 2008
    Location
    Dallas, TX
    Age
    45
    Posts
    123
    Photos Auto Shifter Bushings Installed
    <<I cant see PB pics at work. I dont see how you can put spacers in w/o taking the bolt out, unless they are "half moon". The bushings are $3 each, just do it the right way!>>
    Yep. I pulled the bolt last night, got a few larger i.d. nylon bushings...trimmed them down to slightly thicker than 1/32 and slipped them on the inner collar that runs through the base of the gear selector then bolted it all up nice and snug.
    Man...does it feel NICE! Very solid. (I also ordered some spare bushings just in case I have the car for another ten years.) LOL
    Rubber boot off, fixed side of bolt. (Nut & Washer are on the driver side)
    Driver side top down view
    BTW if the bushings are too thick you won't be able to get the assembly back together!
  26. #24
    Join Date
    Feb 2002
    Location
    North Carolina
    Age
    40
    Posts
    9,478
    Just did this today MAN what a difference in the shifter feel! Before it was had 1/8" of "slop" in it, now it is solid as a rock. Very worth the $5 for both bushings. To do this, follow the directions Al stated. VERY easy to replace.
  27. #25
    SupraForums Member milkoman's Avatar
    Join Date
    Apr 2012
    Location
    Savannah GA
    Posts
    367
    Glad this thread popped up since I've been wondering if it was just my shifter that was sloppy. I'll be ordering the bushings Mon. from Curt. Removed & dyed my carpet this week & waiting on rear speakers to come in so may as well do this now before I put everything back together. Great timing on this thread!
+ Reply to Thread
Quick Reply Quick Reply
Register Now
List your Car(s)
Where you live
Log-in
Similar Threads
  1. shifter bushings.
    By Rety1 in forum Elmhurst Toyota Scion
    Last Post: 10-16-2014, 02:31 AM
  2. AP Shifter Bushings
    By Supramike1 in forum For Sale/Wanted
    Last Post: 08-06-2008, 08:38 AM
Posting Permissions
  • You may post replies
  • You may not edit your posts
