Auto Shifter Bushings - Page 2
+ Reply to Thread
Page 2 of 2 FirstFirst 1 2
Results 26 to 34 of 34
Thread: Auto Shifter Bushings
  1. #26
    SupraForums Member milkoman's Avatar
    Join Date
    Apr 2012
    Location
    Savannah GA
    Posts
    367
    Quote Originally Posted by HotSoup View Post
    Just did this today MAN what a difference in the shifter feel! Before it was had 1/8" of "slop" in it, now it is solid as a rock. Very worth the $5 for both bushings. To do this, follow the directions Al stated. VERY easy to replace.
    Got this done this weekend & it was a little tedious but pretty easy overall to do. Well worth the couple bucks to do this. Thanks to those I asked questions to!
  2. Remove Advertisements
    SupraForums.com
    Advertisements
  3. #27
    SupraForums Member LiuKang's Avatar
    Join Date
    Aug 2009
    Location
    Fremont / Spain / Taiwan
    Posts
    2,642
    in for future mod
  4. #28
    Just did this fix on my '89 Supra and thought I'd share my pics. As others have noted, the blue plastic bushings just disintegrate literally into dust, as shown in the 5th image.
    1989 Supra | Stock 7MGE | AT | Sport Package | White Package | Targa Top
  5. Remove Advertisements
    SupraForums.com
    Advertisements
  6. #29
    Stock Twins King Stu Hagen's Avatar
    Join Date
    Jan 2002
    Location
    Kirkland, Wa.
    Posts
    4,337
    Just found this being on page 1. I just got a RHD Auto TT and there is slop right and left as described above. First, I cant even figure out how to take the shifier knob off lol...Someone said there is a Phillips down low. If some has a picture of where this Id appreciate it.
    So it sounds like a PITA to replace the bushings that causing this?....damn...
  7. #30
    Quote Originally Posted by Stu Hagen View Post
    I didn't realize this was an MKIV-specifc thread until after the fact, but it really seems like the steps are about the same between the IV and III. And for the MK3, you don't even need to take the shifter knob off. I'll let someone else confirm for the MK4.
  8. #31
    Join Date
    Jan 2002
    Location
    Kirkland, Wa.
    Posts
    4,337
    Can someone give me the OD and ID and Thickness of this washer? I have a mix box of nylon washers to see if I can use one.
  9. #32
    SupraForums Member T6Rocket's Avatar
    Join Date
    Mar 2002
    Location
    Raleigh, NC
    Posts
    4,173
    I don't recall taking the shifter knob off. The console? Yes, that's coming off, have fun with that one! I ended up cutting the console frame where that wire harness is, then epoxying it back together. Then the harness is underneath the console frame after that, where it's supposed to be!
    Stu, I don't remember there being any washers, just very thin blue bushings made out of some type of flexible material. So this is a very specific part.
    Al
    94TT Auto, 6466
    [email protected] 27 psi 4/16/16
    Previous setup: HKS Twin 2835's
    [email protected] 32 psi, 10/29/06
    Previous car: 90 Talon AWD, 5 spd, FP Red (60-1)
    [email protected] built motor, 28 psi, Sept 2000
  10. #33
    Join Date
    Jan 2002
    Location
    Kirkland, Wa.
    Posts
    4,337
    OK I have removed most of the parts down to the big plate. I see that there are maybe 4 bolts holding down the big surround plate. So my question is, I remove these 4 bolts then the whole shifter can be lifted up to get to the bolts holding in the bushings? Someone thought you had to get under the car to be able to lift the whole plate and assembly up? So this is where I am...I guess I will take out the 4 perimeter bolts and lift to see if I can access the bolt where the new bushing goes. I can see that the bushing is shot
  11. #34
    Join Date
    Mar 2002
    Location
    Raleigh, NC
    Posts
    4,173
    You have to get under the car to unbolt the shift lever from the shift rod (be sure to mark it!), but I don't recall taking the whole unit out of the car, just the shift lever itself to expose the bushings. Once the console is out, you have all the access you need.
    Attached is a diagram with part #'s.
    Al
+ Reply to Thread
Quick Reply Quick Reply
Register Now
List your Car(s)
Where you live
Log-in
Similar Threads
  1. shifter bushings.
    By Rety1 in forum Elmhurst Toyota Scion
    Last Post: 10-16-2014, 02:31 AM
  2. AP Shifter Bushings
    By Supramike1 in forum For Sale/Wanted
    Last Post: 08-06-2008, 08:38 AM
Posting Permissions
  • You may post replies
  • You may not edit your posts
