Caring for the A340 Factory automatic trans / built or stock - Page 2
+ Reply to Thread
Page 2 of 8 FirstFirst 1 2 3 4 5 6 7 8 LastLast
Results 26 to 50 of 186
Thread: Caring for the A340 Factory automatic trans / built or stock
  1. #26
    SupraForums Member mwsupra23's Avatar
    Join Date
    Jun 2006
    Location
    fredericksburg v.a
    Age
    38
    Posts
    367
    yes thats what im asking. what do you wire in and where to allow lock up manually on hwy driving with a stock ecu?
  2. Remove Advertisements
    SupraForums.com
    Advertisements
  3. #27
    Not so boring anymore tissimo's Avatar
    Join Date
    Nov 2002
    Location
    Tampa, FL
    Age
    34
    Posts
    7,084
    Quote Originally Posted by mwsupra23 View Post
    On the ECU harness have a switch on 14B to ground out IIRC.
    92 Supra Turbo - Project 2019
    90 Supra Turbo - 1jz, HX40, EMU Classic, FIC 1200s
    87 Supra Hardtop - 7m, 60-1 bolt-on, EMU Black, ID 1050x
  4. #28
    SupraForums Member lithium14's Avatar
    Join Date
    Jan 2011
    Location
    Austin, Texas
    Age
    31
    Posts
    465
    k. noob question. I am assuming that these rules also apply to mk3 a340e's. If this is the case, what do you do if you want to do a pull on the highway? do you turn off o/d, perform pull, then turn o/d back on? or is it not good to turn o/d on and off while driving? I am assuming turning off/on will occur around 50mph?
  5. Remove Advertisements
    SupraForums.com
    Advertisements
  6. #29
    SupraForums Member T6Rocket's Avatar
    Join Date
    Mar 2002
    Location
    Raleigh, NC
    Posts
    4,165
    Tap onto the 14B wire, dont cut it. Run a ground to a switch.
    Also, dont forget to turn it off when braking or downshifting! You can do some real damage to the clutch if you turn it on at the wrong time. That is why it took me 7 years to get up the nerve to install it. When you hit the brake, the TC is supposed to unlock.
    I wanted to install a lighted switch, but I was afraid to run power to the switch, since when the switch was off, power would run to the TC wire! I even was going to run the power thru a relay.
    tissimo: do you have a lighted switch?
    Al
    94TT Auto, 6466
    [email protected] 27 psi 4/16/16
    Previous setup: HKS Twin 2835's
    [email protected] 32 psi, 10/29/06
    Previous car: 90 Talon AWD, 5 spd, FP Red (60-1)
    [email protected] built motor, 28 psi, Sept 2000
  7. #30
    Join Date
    Mar 2002
    Location
    Raleigh, NC
    Posts
    4,165
    Quote Originally Posted by lithium14 View Post
    If you want to do a pull, just punch it! The car will downshift to 3rd, then when you let off, it will shift to OD. Now if you are making a pass at the track, or expect to redline it in 3rd, then turn off OD, and turn it back on just as you're letting off.
    On my car, if I am just cruising in 3rd and manually shift to O/D, it clunks really hard. That is why I only turn it off at the track.
    Al
  8. #31
    2JZ S13 Flicktitty's Avatar
    Join Date
    Jan 2005
    Location
    Kicking Xtoefields ass in Bowling.
    Posts
    2,204
    there is some great info in this thread.
    Thanks to all who are contributing.
    1989 Nissan 240sx 19,000 Original miles | 2JZ-GTE | PT6266 | Titan 3500 Stall | FIC 750s | AEM EMS V2
    2010 Toyota Prius - 50+ MPG Daily
    2008 Lexus IS350 - Few light mods.
  9. #32
    Join Date
    Jan 2011
    Location
    Austin, Texas
    Age
    31
    Posts
    465
    Quote Originally Posted by T6Rocket View Post
    Al
    hmmm ok I'm still just a little bit confused, if I punched it while in OD and the trans downshifts to 3rd, won't the eventual shift back to OD be what the OP is addressing in terms of the clutch pack not being able to handle the power? Sorry for the redundancy, I just want to fully understand what I am doing since I am about to replace my trans and I don't want to be treating it wrong =D
  10. #33
    Function over form
    Join Date
    Oct 2005
    Location
    TX
    Posts
    2,465
    If you floor it in OD then the trans will unlock the converter and kickdown to 3rd gear. The transmission won't shift back in to 4th gear until you redline or let off the gas. That's why you turn OD off so it stays in 3rd gear until you decide to put it in 4th.
    Get the car moving in overdrive. Push the accelerator all the way to the floor. Let the transmission shift.
    2JZ-GE | Turbonetics T66 | AEM
  11. #34
    Join Date
    Nov 2002
    Location
    Tampa, FL
    Age
    34
    Posts
    7,084
    Al
    I have a stock ECU, I just let it do its thing. No switch or anything.
    As for the OD thing, the gear is weaker (think stock clutch on a manual car, vs upgraded on 1-3 gears). Its weaker and can overpower it to causing it to slip throw clutch material through your trans and will develop other issues.
    For best longevity and least likely to kill the trans DO NOT GO WOT UNTIL O/D SWITCH IS OFF.
    When switching OD Off/on be off throttle for the smoothest transition.
  12. #35
    Fastest Factory Auto 1320ms's Avatar
    Join Date
    Nov 2004
    Location
    Los Angeles
    Age
    36
    Posts
    2,228
    Additional info on converter lockup in post #2.
    Matt
    95 Supra Turbo - 1.33 60ft / [email protected] / [email protected] / NO nitrous / PTE7275 / 3.0L / BoostLogic TOYOTA auto / PFSupercars Tuned
    Sponsors - BoostLogic, Elmhurst Toyota, Driveshaft Shop, Ferrea, Freed Engineering, Fuel Injector Clinic, Gates, Headgames Motorworks, HFR Fabrication, Justice Racing Engines, Kelford Cams, PFSupercars, Real Street Performance, Wiseco
    Follow our Drag Racing progress - www.facebook.com/1320motorsports
  13. #36
    Banned Boosting89's Avatar
    Join Date
    Oct 2004
    Location
    Queens,ny
    Age
    41
    Posts
    2,386
    OK so is it better to just drive with the.OD off all the time?
  14. #37
    SupraForums Member TT BomB's Avatar
    Join Date
    Feb 2001
    Location
    MASS
    Age
    47
    Posts
    438
    This is what I followed when I installed my TC lockup: http://www.ttbomb.com/tmp/lockup/lockup_led.JPG
    TTBOMB.com
    10.51 at 132.25
    679rwhp & 576ft/lbs
  15. #38
    Join Date
    Jun 2006
    Location
    fredericksburg v.a
    Age
    38
    Posts
    367
    Rule #6 - External trans filter mount with the CORRECT type of filter on it. Its $28 for the bracket on summit racing. The filter you want is a Napa #1624 - this is a $20 filter, it is designed for hydraulic/transmission use, and filters to 19 microns. Put this filter BEFORE YOUR FIRST COOLER. The point is not so much to keep the fluid clean as it is to keep junk out of the coolers.
    theres a couple different filter mounts on there site for $28 do you happen to know the part number for the one you run? i only ask so that i get the one that uses the filter from napa and not always have to order from summit. thanks
  16. #39
  17. #40
    Join Date
    Jun 2006
    Location
    fredericksburg v.a
    Age
    38
    Posts
    367
    thats the one i thought was it!! thanks again
  18. #41
    Join Date
    Nov 2004
    Location
    Los Angeles
    Age
    36
    Posts
    2,228
    up
  19. #42
    Join Date
    Mar 2002
    Location
    Raleigh, NC
    Posts
    4,165
    Quote Originally Posted by TT BomB View Post
    That is the same diagram everyone uses, but I have not seen the Radio Shack light option. Where does that tap in?
    The problem that I saw (with my limited elec expertise!) is that you are sending a ground to the TC lockup instead of power. So, getting a lighted switch to light with a relay was no problem, but when the switch was off, power would be going to the TC lockup.
    Al
  20. #43
    Join Date
    Oct 2004
    Location
    Queens,ny
    Age
    41
    Posts
    2,386
    hey guys question..when running the trans cooler on the pass side..do i run the cooler ..from the stock cooler then to aftermarket trans then straight back to transmission?
    do i use -6 fittings and lines as well?
  21. #44
    Join Date
    Oct 2004
    Location
    Queens,ny
    Age
    41
    Posts
    2,386
  22. #45
    SupraForums Member HotSoup's Avatar
    Join Date
    Feb 2002
    Location
    North Carolina
    Age
    40
    Posts
    9,478
    No, do not use the stock trans cooler, bypass it.
    1994 Red/Black TT
    86K miles
    Roller...6 speed swap coming soon
  23. #46
    Join Date
    Oct 2004
    Location
    Queens,ny
    Age
    41
    Posts
    2,386
    ok bypass this by buying another aftermarket trans cooler? if so what size would be ideal to use..do i need a fan on this one as well or no since the other trans cooler will have one?
  24. #47
    Join Date
    Feb 2002
    Location
    North Carolina
    Age
    40
    Posts
    9,478
    I only run one cooler, so you will have to ask Matt about that one. I use a HUGE B&M with a fan and never felt the need for a 2nd cooler.
    Jason
  25. #48
    Join Date
    Oct 2004
    Location
    Queens,ny
    Age
    41
    Posts
    2,386
    thanks bro..i think i will stick to one cooler with a fan
  26. #49
    Join Date
    Nov 2002
    Location
    Tampa, FL
    Age
    34
    Posts
    7,084
    Quote Originally Posted by HotSoup View Post
    Any reason not to use the stock cooler? I would use it if available. I would run it out of the trans to the Aftermarket cooler then to the stock cooler though, to minimize the heat put into the coolant system. My radiator was leaking so bought a Koyo and just have 2 aftermarket fanless coolers.
  27. #50
    Join Date
    Feb 2002
    Location
    North Carolina
    Age
    40
    Posts
    9,478
    Quote Originally Posted by tissimo View Post
    This is what was explained to me by one of the best converter builders in the states(Greg Slack). Why would you want to put trans fluid into a radiator that is 180+ degrees, the point is to cool it down...not keep it hot! Remember, even though its a separate part of the radiator it still gets heat from the radiator fluid which is HOT.
+ Reply to Thread
Quick Reply Quick Reply
Register Now
List your Car(s)
Where you live
Log-in
Similar Threads
  1. Built Auto A340
    By adidas00 in forum MKIII (1986.5-1992)
    Last Post: 02-25-2010, 06:09 AM
  2. question about stock tt automatic trans cooling lines
    By Morefaster in forum Tech Corner
    Last Post: 03-08-2009, 08:44 AM
Posting Permissions
  • You may post replies
  • You may not edit your posts
