Caring for the A340 Factory automatic trans / built or stock - Page 3
+ Reply to Thread
Page 3 of 8 FirstFirst 1 2 3 4 5 6 7 8 LastLast
Results 51 to 75 of 186
Thread: Caring for the A340 Factory automatic trans / built or stock
  1. #51
    Fastest Factory Auto 1320ms's Avatar
    Join Date
    Nov 2004
    Location
    Los Angeles
    Age
    36
    Posts
    2,228
    Quote Originally Posted by tissimo View Post
    Any reason not to use the stock cooler? I would use it if available. I would run it out of the trans to the Aftermarket cooler then to the stock cooler though, to minimize the heat put into the coolant system. My radiator was leaking so bought a Koyo and just have 2 aftermarket fanless coolers.
    I do not use the stock cooler because I dont want my trans fluid getting to 220degrees just by going through the hot coolant system
    If you're worried about your trans fluid being too cold, buy an inline thermostat
    Matt
    Matt
    95 Supra Turbo - 1.33 60ft / [email protected] / [email protected] / NO nitrous / PTE7275 / 3.0L / BoostLogic TOYOTA auto / PFSupercars Tuned
    Sponsors - BoostLogic, Elmhurst Toyota, Driveshaft Shop, Ferrea, Freed Engineering, Fuel Injector Clinic, Gates, Headgames Motorworks, HFR Fabrication, Justice Racing Engines, Kelford Cams, PFSupercars, Real Street Performance, Wiseco
    Follow our Drag Racing progress - www.facebook.com/1320motorsports
  2. Remove Advertisements
    SupraForums.com
    Advertisements
  3. #52
    Banned Boosting89's Avatar
    Join Date
    Oct 2004
    Location
    Queens,ny
    Age
    41
    Posts
    2,386
    ok so you guys think it will be better to run stock cooler to aftermarket then to transmission or aftermarker cooler to stock cooler then to transmission?
    i just spoke with the guys who built my transmission and they just told me stick to one cooler and the stock
    keep this in mind fellas..i dont drag race and i hardly use this car..but if i do it will be some long distance driving or just cruising local
  4. #53
    Join Date
    Nov 2004
    Location
    Los Angeles
    Age
    36
    Posts
    2,228
    do not run stock cooler period.
  5. Remove Advertisements
    SupraForums.com
    Advertisements
  6. #54
    Not so boring anymore tissimo's Avatar
    Join Date
    Nov 2002
    Location
    Tampa, FL
    Age
    34
    Posts
    7,084
    Quote Originally Posted by HotSoup View Post
    This is what was explained to me by one of the best converter builders in the states(Greg Slack). Why would you want to put trans fluid into a radiator that is 180+ degrees, the point is to cool it down...not keep it hot! Remember, even though its a separate part of the radiator it still gets heat from the radiator fluid which is HOT.
    Makes sense, but I think it would still benefit. I dont think the bottom of the radiator is 180*, and assume its 150-160. Under load conditions, I dont think a cooler would lower the temps below that, so would still be pulling heat out. This is just my assumption.
    92 Supra Turbo - Project 2019
    90 Supra Turbo - 1jz, HX40, EMU Classic, FIC 1200s
    87 Supra Hardtop - 7m, 60-1 bolt-on, EMU Black, ID 1050x
  7. #55
    Why an Auto?? Justin777's Avatar
    Join Date
    Dec 2008
    Location
    Biloxi,Ms
    Posts
    361
    Quote Originally Posted by Boosting89 View Post
    The B&M cooler with the fan should be plenty by itself.
    "Obedience breeds discipline, discipline breeds unity, unity breeds power, power is life."
    Member since Aug. 2003
    1993 1JZ SC300
    1994 6766, BL AUTO, PI3800, FIC 850 fuel setup, twin denso pumps, Greddy FMIC and a few other things
  8. #56
    Join Date
    Oct 2004
    Location
    Queens,ny
    Age
    41
    Posts
    2,386
    thanks for all the great advice guys..one more question...what is the best route to run? stock cooler>>>aftermarket cooler>>transmission? or after market cooler>>>stock cooler>>transmission?
  9. #57
    SupraForums Member lithium14's Avatar
    Join Date
    Jan 2011
    Location
    Austin, Texas
    Age
    31
    Posts
    465
    Another n00b question!!! for the is300 trans pan and oil pump... wut year is300 are we talking about? are these components identical for all years of a340e's? or do i have to find an older version that works on mk3 a340e's? O.o
  10. #58
    Join Date
    Dec 2008
    Location
    Biloxi,Ms
    Posts
    361
    Keep the stock cooler out of the system completely. Forget you even have the stock cooler and just run the Big cooler with the fan we looked at
  11. #59
    Join Date
    Oct 2004
    Location
    Queens,ny
    Age
    41
    Posts
    2,386
    so basically just run one cooler? wouldnt it be better just to have the stock cooler there as well?
    sorry for all the dum questions guys, this is my first time dealing with a automatic ..
  12. #60
    Join Date
    Dec 2008
    Location
    Biloxi,Ms
    Posts
    361
    Quote Originally Posted by 1320ms View Post
    Matt
    This is the reason why you dont want to run the stock cooler
  13. #61
    SupraForums Member T6Rocket's Avatar
    Join Date
    Mar 2002
    Location
    Raleigh, NC
    Posts
    4,165
    I have never had any issues with running the fluid thru the stock cooler, then thru the 28,000 B&M, then back to the tranny. I cant see the stock cooler adding heat to the fluid once the car is at normal temps. Stabilize temps, yes. Add heat, no.
    Mine is street driven, and even with the stock cooler still in-line, it takes a couple miles for the clutch to lock-up on cold days, because of the add'l cooler. My coolant temps with a stock T-stat were 203 deg on a Techtom. Now I have a TRD stat, and it is typically ~195 deg.
    Priorities for a street/strip car are different than a strip-only car.
    Al
    94TT Auto, 6466
    [email protected] 27 psi 4/16/16
    Previous setup: HKS Twin 2835's
    [email protected] 32 psi, 10/29/06
    Previous car: 90 Talon AWD, 5 spd, FP Red (60-1)
    [email protected] built motor, 28 psi, Sept 2000
  14. #62
    SupraForums Member
    Join Date
    Apr 2005
    Location
    San Diego, CA
    Age
    41
    Posts
    2,182
    Then why would Toyota put a trans cooler in the radiator? They were stupid?
  15. #63
    Join Date
    Nov 2002
    Location
    Tampa, FL
    Age
    34
    Posts
    7,084
    Quote Originally Posted by KevinB6876 View Post
    There is no other cooler.
    If running the stock cooler, it would be best to run it to the stock one then an aftermarket to pull the most heat out of the fluid.
  16. #64
    Join Date
    Dec 2008
    Location
    Biloxi,Ms
    Posts
    361
    Instead of going through the trouble of routing through the stock cooler just buy another b&m without the fan and run 2. Simply because if you ever upgrade the radiator you won't be able to use the stock cooler anymore anyhow. So you won't have to buy more trans line and route lines all over again.
  17. #65
    Join Date
    Jan 2011
    Location
    Austin, Texas
    Age
    31
    Posts
    465
  18. #66
    SupraForums Member
    Join Date
    Feb 2009
    Location
    Orange County, California
    Age
    28
    Posts
    2,145
    Cost? Same reason they used a water-to-oil engine cooler. It's better than nothing and decent enough for stock.
  19. #67
    ส็็็็็็็็็็็็็็็็็็็ ส็็็ 93MSB's Avatar
    Join Date
    Feb 2001
    Location
    Waco, Texas
    Age
    36
    Posts
    919
    heres the part number for the deep pan, also came on the gs300
  20. #68
    Join Date
    Oct 2004
    Location
    Queens,ny
    Age
    41
    Posts
    2,386
    Question...the metal lines that runs to the transmission..can i just keep them metal or do i change them to steel braided lines..if so..do anyone know the fittings used in order to run braided lines to the transmission?
  21. #69
    dude just keep the hard line. the DP is inches from the linee ,braided lines might melt. also there is no difference in size ,-6an is 3/8 and the factory hard line is 10MM
  22. #70
    Join Date
    Oct 2004
    Location
    Queens,ny
    Age
    41
    Posts
    2,386
    thanks, so i guess the only lines that will be steel braided will be the ones comming from the aftermarket trans cooler?
  23. #71
    yes . thats the way i did mine with two cooler. one 10x7 B&Mand one 10x13 DERALE both wit fan.
  24. #72
    Join Date
    Nov 2004
    Location
    Los Angeles
    Age
    36
    Posts
    2,228
    Quote Originally Posted by mikesautoservices View Post
    Unbolting/bolting the hard lines gets to be tedious - literally cuts time in half to remove trans by going with braided lines. I went with Goodridge Teflon lines rated to over 400deg and put 1500deg firesleeves over them, no issues. The Goodridge teflon -6 is a larger inner diameter than any other -6 I've seen, and its got a smaller outer diameter to boot.. real slick stuff.
  25. #73
    SupraForums Member HotSoup's Avatar
    Join Date
    Feb 2002
    Location
    North Carolina
    Age
    40
    Posts
    9,478
    wrap the DP and run braided lines.....thats what im going with.
    1994 Red/Black TT
    86K miles
    Roller...6 speed swap coming soon
  26. #74
    Join Date
    Oct 2004
    Location
    Queens,ny
    Age
    41
    Posts
    2,386
    So the only advantage of this is that it makes taking out the trans easier?
  27. #75
    Join Date
    Nov 2004
    Location
    Los Angeles
    Age
    36
    Posts
    2,228
    Theres a few advantages, flexibility, you can run them where you want, etc..
+ Reply to Thread
Quick Reply Quick Reply
Register Now
List your Car(s)
Where you live
Log-in
Similar Threads
  1. Built Auto A340
    By adidas00 in forum MKIII (1986.5-1992)
    Last Post: 02-25-2010, 06:09 AM
  2. question about stock tt automatic trans cooling lines
    By Morefaster in forum Tech Corner
    Last Post: 03-08-2009, 08:44 AM
Posting Permissions
  • You may post replies
  • You may not edit your posts
