Caring for the A340 Factory automatic trans / built or stock - Page 4
+ Reply to Thread
Page 4 of 8 FirstFirst 1 2 3 4 5 6 7 8 LastLast
Results 76 to 100 of 186
Thread: Caring for the A340 Factory automatic trans / built or stock
  1. #76
    SupraForums Member lithium14's Avatar
    Join Date
    Jan 2011
    Location
    Austin, Texas
    Age
    31
    Posts
    465
    I'm back with more questions!!! I got the trans pan, now the oil pump from an is300, I have the part number here for the "body sub assy, front oil pump" 35301‑50020 for the a650e. Is this the correct part that will fit in my 1988 a340e?? lmk, thanks!!!
    1988 SUPRA + 7M-GTE + 700HP WIP
    INSTAGRAM: JASMINE_A70
  2. Remove Advertisements
    SupraForums.com
    Advertisements
  3. #77
    SupraForums Member XempH's Avatar
    Join Date
    Feb 2009
    Location
    NJ
    Posts
    997
    wait wait wait wait......your saying to race with the overdrive OFF.. meaning the button is pushed out? When I do pulls with it pushed out it feels like I have 80hp and get 0 pull, and when I leave the button pushed in and mash it I get the typical downshift of the car and insane pull. Explain.
    '12 Chevy Silverado
    '93 BNR32
    '97 Supra TT ~
    Quote Originally Posted by MadMonkey View Post
    .....don't tell me you're using IE. Please.
    Quote Originally Posted by TRD91whtMK3 View Post
    More than you can surf, pal. Safari.
  4. #78
    Join Date
    Jan 2011
    Location
    Austin, Texas
    Age
    31
    Posts
    465
    From what I understand, you are not supposed to be in OD for extended periods of time in WOT, rather, during a highway pull, you mash the pedal and let the trans downshift etc etc. And only if you are doing something like drag racing, where you may be in OD for quite some time, to leave OD off. I think.
    Still need feedback on that part number... I have been searching frantically on SM and SF and can't find anything about the is300 oil pump...
  5. Remove Advertisements
    SupraForums.com
    Advertisements
  6. #79
    Not so boring anymore tissimo's Avatar
    Join Date
    Nov 2002
    Location
    Tampa, FL
    Age
    34
    Posts
    7,084
    Quote Originally Posted by XempH View Post
    what? are you in manual mode or something? it should act exactly the same but just have 3 gears vs 4. Still downshift when matted, and wont effect the hp at all. If you have manual mode on, it will stay in 3rd gear causing problems like you're saying.
    WOT at all on the weak OD clutch can cause issues, its best just to leave it off at all times and not go into it at WOT.
    92 Supra Turbo - Project 2019
    90 Supra Turbo - 1jz, HX40, EMU Classic, FIC 1200s
    87 Supra Hardtop - 7m, 60-1 bolt-on, EMU Black, ID 1050x
  7. #80
    Join Date
    Feb 2009
    Location
    NJ
    Posts
    997
    no i'm not in manual mode but what you guys are saying makes no sense. when the button is pushed in O/D is on. that's what I drive around in all the time and my RPM isn't at 4k on the highway, but instead 2-2.5k. When im doing 40mph on the highway and press the O/D button, the button releases out and now you have O/D Off. If you do a pull from 40mph while O/D is off you get absolutely shit power because the trans does not downshift, instead your basically in 5th gear. From what I see O/D is 5th gear. I guess im doing it 'wrong' by never letting O/D be OFF (the button pushed out) and mashing the gas and letting the trans downshift and getting the most power out of it.
  8. #81
    Join Date
    Nov 2002
    Location
    Tampa, FL
    Age
    34
    Posts
    7,084
    Thats really odd. Mine downshifts fine with OD button out (OD off)
  9. #82
    Join Date
    Feb 2009
    Location
    NJ
    Posts
    997
    so when your doing 40mph and u press the O/D button your RPM doesn't jump to 4k?? Mashing the pedal with the O/D Off just makes the car pull from that speed, and feels completely weak. If you do a 40mph pull with O/D on (not pressed) the pull is great when you mash it because it will drop into 2nd, instead of staying in (from what I see) 5th gear.
  10. #83
    Join Date
    Jan 2011
    Location
    Austin, Texas
    Age
    31
    Posts
    465
    I don't think Supras ever came with a 5 speed auto... it's an a340e/a341 the second number is what number of gears it has. toyoto didn't come out with aX5X trans until afterwards. Correct me if I'm wrong. and if your trans isn't downshifting when OD is off, then something is wrong. with OD on, if you are in 4th on the highway (any speed over ~45mph) when you go WOT, it will kick down to 2nd. Once it gets to 4th your pull should be about done... so you can let off, then you will no longer be WOT, so all is good. When you turn OFF OD in 4th, the trans will downshift to 3rd, and when you go WOT it will still kick down to 2nd, but not shift up to 4th. at least this is how my trans behaves.
    anyone know about that is300 oil pump compatibility?
  11. #84
    Join Date
    Feb 2009
    Location
    NJ
    Posts
    997
    ^i understand that when you press OD it "downshifts" and becomes 4~k, but when you step on it I just get a small pull from 4 to 5 to 6 really fucking weak and slow. So i never use it.
  12. #85
    SupraForums Member T6Rocket's Avatar
    Join Date
    Mar 2002
    Location
    Raleigh, NC
    Posts
    4,165
    Third gear is not going to pull as hard as second gear, but it should still pull. Though not as much with stock twins as with a single. At 40 MPH it should downshift into second anyway.
    There is a button under the gas pedal that is supposed to control downshifts under WOT, maybe you're not pressing the throttle far enough?
    Al
    94TT Auto, 6466
    [email protected] 27 psi 4/16/16
    Previous setup: HKS Twin 2835's
    [email protected] 32 psi, 10/29/06
    Previous car: 90 Talon AWD, 5 spd, FP Red (60-1)
    [email protected] built motor, 28 psi, Sept 2000
  13. #86
    Join Date
    Nov 2002
    Location
    Tampa, FL
    Age
    34
    Posts
    7,084
    RPMs will jump, only till like 2500-3k at 40mph though. When I floor it it'll downshift to 2nd and nail like 5500-6k and haul ass just like with OD on.
  14. #87
    SupraForums Member binster's Avatar
    Join Date
    Feb 2001
    Location
    Chicago
    Posts
    124
    With OD off the engine will be in a higher power band (rpms) and stay there during increased speeds. OD off basically takes you out of the 4th gear on the Auto (MKIV). Whenever we play on the highway I keep OD off. If I'm just cruising around then OD is on..
    Thanks for writeup on the care of the Auto trans. I'm studying trans coolers now to keep my tranny alive as I do engine upgrades.
    BK
    94tt -
  15. #88
    Join Date
    Feb 2009
    Location
    NJ
    Posts
    997
    thanks for clarifying all. I'm still on the twins so when I go single in ~ a month i'll see about the O/D Off.
  16. #89
    2JZ S13 Flicktitty's Avatar
    Join Date
    Jan 2005
    Location
    Kicking Xtoefields ass in Bowling.
    Posts
    2,204
    i know this isn't a supra auto, but i thought it's bad to drive an auto like this?
    At the 2:30 mark
    http://www.youtube.com/watch?v=uq2GB...JV1sKQ&index=2
    or will it just got hotter faster? Is there any issues with normal driving like this?
    1989 Nissan 240sx 19,000 Original miles | 2JZ-GTE | PT6266 | Titan 3500 Stall | FIC 750s | AEM EMS V2
    2010 Toyota Prius - 50+ MPG Daily
    2008 Lexus IS350 - Few light mods.
  17. #90
    SupraForums Member
    Join Date
    Oct 2006
    Location
    supra land
    Posts
    1,975
    So if you have your auto built for high hp can you have the o/d on?
  18. #91
    Why an Auto?? Justin777's Avatar
    Join Date
    Dec 2008
    Location
    Biloxi,Ms
    Posts
    361
    yes
    "Obedience breeds discipline, discipline breeds unity, unity breeds power, power is life."
    Member since Aug. 2003
    1993 1JZ SC300
    1994 6766, BL AUTO, PI3800, FIC 850 fuel setup, twin denso pumps, Greddy FMIC and a few other things
  19. #92
    SupraForums Member
    Join Date
    Apr 2005
    Location
    San Diego, CA
    Age
    41
    Posts
    2,182
    5th gear huh?
    That's interesting, since the Supra's automatic transmission is a 4 speed automatic. Having a "5th gear" in a 4 speed transmission has to be a first.
  20. #93
    SupraForums Member
    Join Date
    Apr 2005
    Location
    San Diego, CA
    Age
    41
    Posts
    2,182
    There is no 5th gear in the Supra's automatic.
  21. #94
    SupraForums Member
    Join Date
    Apr 2005
    Location
    San Diego, CA
    Age
    41
    Posts
    2,182
    It would be nice if someone made a 5 speed or 6 speed automatic for the Supra that did not use an overdrive gear system for the final gear.
    The A340 transmission is only a 3 speed with overdrive making it a 4 speed. But the 4th gear, being an overdrive gear, doesn't allow as much power to get to the wheels. Because it's an overdrive gear, it robs more power from the engine so that it puts less power to the wheels. I have confirmed this in testing.
  22. #95
    Join Date
    Feb 2009
    Location
    NJ
    Posts
    997
    ^ if you read my other posts I put in quotes "5th gear" but forgot to there. I guess only my trans never downshifts if I mash it with O/D Off, just picks up from the 4k where its at.
  23. #96
    SupraForums Member
    Join Date
    Nov 2008
    Location
    Miami,Fl
    Posts
    417
    Considering line pressure control amongst other things. Is it worth running a built auto and stall on a stock ecu/ piggyback setup. ?
    1994 3p0 Red Supra
    BWS366 / ProEfi / 6 Speed
  24. #97
    Yup. TJG's Avatar
    Join Date
    Aug 2003
    Location
    Southeast WI
    Age
    36
    Posts
    684
    How about some dialogue on how people run on the dyno? I know it's available via search, however as long as we are getting good info in one thread. . . .
    The first time I dyno'd, I used the info from mkiv.com, however what concerns me is the end of the dyno run. Do you guys press the O/D button during the run so it shifts to 4th? Do you bounce off the rev limiter, then let off and let the dyno brake slow the car down in third gear? Manually push the gear shift to neutral?
    TJ
    1994 TT 6sp
    ProEFI / PHR / Sound Performance / ETS / KW / TITAN / CCW / PWR
    679whp / 630wtq
  25. #98
    SupraForums Member
    Join Date
    Oct 2004
    Location
    South Dakota
    Age
    44
    Posts
    151
    Just stop before the rev limit. When you hit the dyno brake it should immediately bring it down to speed. No reason to hit the rev limit. Definitely don't shift up (O/D off).
  26. #99
    SupraForums Member
    Join Date
    Oct 2004
    Location
    South Dakota
    Age
    44
    Posts
    151
    Quote Originally Posted by fmx81style View Post
    stock ecu controls line pressures fine, so yes, it is worth running built w/stall. Piggyback won't alter that.
  27. #100
    Kinda Broken Supra Biologist's Avatar
    Join Date
    Jun 2010
    Location
    Chicago, IL
    Age
    26
    Posts
    3,755
    Question when you change the fluids are you COMPLETELY flushing it out or just dropping the pan and filling it in? wouldn't it build Heat faster than usual? also Im racing on the Auto from a roll 40-140 and my speed limiter stopped at 135MPH. do i pull the TRAC fuse out? been searching all day and couldnt find a legit answer. also upgrading to a GS300 Trans Pan. thanks.
    - Bio
    1994 Toyota Supra Renaissance Red Built 3.0
    2008 Lexus IS-F Ultra Sonic Blue Full Bolt On
    fullsizeoutput_f09 by Tuan Nguyen, on Flickr
    fullsizeoutput_f07 by Tuan Nguyen, on Flickr
+ Reply to Thread
Quick Reply Quick Reply
Register Now
List your Car(s)
Where you live
Log-in
Similar Threads
  1. Built Auto A340
    By adidas00 in forum MKIII (1986.5-1992)
    Last Post: 02-25-2010, 06:09 AM
  2. question about stock tt automatic trans cooling lines
    By Morefaster in forum Tech Corner
    Last Post: 03-08-2009, 08:44 AM
Posting Permissions
  • You may post replies
  • You may not edit your posts
