Mk2 Roll Call - Page 12
+ Reply to Thread
Page 12 of 16 FirstFirst ... 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 LastLast
Results 276 to 300 of 388
Thread: Mk2 Roll Call
  1. #276
    Join Date
    May 2010
    Location
    Marysville, Ohio
    Posts
    5
    1983 P-Type All Stock in black
    Marysville, Ohio
  2. Remove Advertisements
    SupraForums.com
    Advertisements
  3. #277
    Join Date
    Aug 2010
    Location
    Oreogn
    Posts
    10
    Bryan
    Woodburn, OR
    1986 supra celica, 5-MGE
  4. #278
    greasemonkey williamb82's Avatar
    Join Date
    Aug 2002
    Location
    spring hill, florida
    Age
    37
    Posts
    3,121
    Quote Originally Posted by williamb82 View Post
    ive had
    blue 83 p type auto(sold)
    red 84 ptype manual with 7mgte(totalled last year)
    brown 85 p type manual(totalled in 2001)
    blue 85 p type manual(parts car)
    black 88 turbo manual(7mgte donor)
    silver 87 turbo maual(parts car)
    white 86.5 n/a manual(pos turned into parts car)
    maroon 86.5 n/a manual(sold)
    currently
    blue 85 ptype auto with trd header, hks exhaust, and 15x7 are's, and xxbadges in storage. (tripple carb 6m in progress)
    black 84 ptype manual, rebuilt 7mgte, 2mm mhg, arp studs, 57 trim ct26, custom 3in outlet elbow, dp, exhaust, hks smf intake,solid motor mounts, dr j. mbc, apexi s-afc2, maft with 3in gm maf, 6 puck metalic sprung clutch disc with centerforce pp, true trac lsd with 3.727 r&p, kyb rear shocks, st rear springs, addco sway bars, ljm front strut bar, drop zone coilovers front, aw11 rear tokico illumina's up front with ttt strut tube spacers, 16x7 enkei 92's 225/50/16 michelin pilots front, 245/50/16 nitto nt555r's rear, and lots of other "goodies" soon to be installed.
    some things have changed. the 85 wont be getting the webers. it is a 5m, with trd header, hks exhaust with magnaflow muffler, custom intake pipe, cone filter, technafit ss braided brake lines. if my ls400 is totalled, ill swap the 1uz into this car as i already have the custom mounts.
    the 84, has a 7mgte, 1.2mm hks mhg, arp head studs, 780cc/min injectors, 57 trim ct26, 3in dp/exhaust with magnaflow muffler, megasquirt 2 standalone with aem wideband and coil on plug ignition. reg cone filter. solid motor mounts, dual electric fans from a v6 ford contour, jim king front bbk, techanfit ss brake lines, 16x7 enkie 92's with 0 offset. 225/50/16 front and 245/50/16 rear (15x7 A.R.E. mesh wheels with 275/50/15 nt555r drag radials for track). drop zone coilovers up front, st springs rear. tokico illumina short stroke shocks front, kyb gas adjust for a trooper 2 for the rear. true trac lsd with 3.727 r&p. ljm front strut brace. wes hetrick v1 rear brace. addco sway bars, 6 puck cermetalic clutch with stock pp and r154 trans, mk3 power booster and aluminum master cylinder, wilwood 2psi residual valves front and rear. summit line lock front. auto meter boost and egt gauges.
    now, in storage for this car i have jim king rear bbk with calipers, pads, cadium plated rotors, etc..., 17x7.5 +4 and 17x8.5 +4 rota rb's in hyper black with polished lip, lt1 t56 6 speed trans with hurst short shifter, quarter master button flywheel and qm1 throwout bearing, tilton twin plate cermetalic 7.25in rally clutch, garrett gt4082 with 0.68 a/r turbine housing, raptor racing turbo header, x02 44mm wastegate, 75mm polished ford tb, ffim in production, 2nd walbro 255lph fuel pump, cx racing aluminum radiator and 3in aluminum i/c pipe kit, 24x12x4 fmic, auto meter 160mph speedo, 8k rpm tach, water temp, and oil pressure gauges in a custom gauge cluster, early 82 "supra" badges, after market steering wheel with trd horn button, two 1qt add on sumps for the oil pan, weld in spring eight adjusters for the rear. rear poly control arm bushings. jim king 75mm rca's, cadium plated rotors for the front bbk, two 13in fal fans, por-15 to fix any and all rust, wiseco 9:1 84mm pistons with moly coated skirts, p&p 7m head, 1mm os ss valves, comp cam valve springs, ferrera titanium retainers, 92 block and crank good at std., arp main studs, and more im forgetting.
    i also now own a black 86 mk2. parts i have for this are a 6m crank pulley, 7m block and crank with 7mgte rods, 7m timing gears. new 20 over 5m domed pistons, p&p head, oversized ss valves, trd valve springs, hks cams, hks rear cam mount ignition, hks intake manifold and thermostat housing, 3 rebuilt weber 40mm dcoe carbs, origonal tri-mil 6-1 header that will be modded to a 3in collector for 3in exhaust, celica xx badges, celica xx rear vents, 3.0gt grille badge, 4 puck cermetalic clutch disc with centerforce pp, 82 5mge ignitor and msd blaster 2 coil
    lots planned, just too broke to do anything at the moment so everything is collecting dust.
    http://www.cardomain.com/ride/2042690/1 black 84 7mgte, ms2, truetrac lsd, bbk, etc... lots more in the works
    http://www.cardomain.com/ride/2117186/1 blue 85 trd header, hks exhaust, custom intake pipe, cone filter,etc... my beater.
    http://www.cardomain.com/ride/2965297/1
    black 86 bought with rod knock. hks tripple weber setup in the works
  5. Remove Advertisements
    SupraForums.com
    Advertisements
  6. #279
    Join Date
    Sep 2010
    Location
    Victoria Australia
    Posts
    1
    Red '83 7MGE 3litre, 5speed, 5 lug conv.
    White '83 1GZFE 5litre, 6 speed, 5 lug conv. (still in the build)
  7. #280
    SupraForums Member
    Join Date
    Dec 2006
    Location
    Prescott, AZ
    Posts
    3
    Tucson, AZ
    Hi Folks,
    Bob here, from Tucson, AZ. I have an '82 that has gone through the 5MGE and 7MGTE efforts, and is now receiving a 1JZGTE with the stock twins. Looking forward to the new setup!
  8. #281
    Join Date
    Oct 2010
    Location
    New Zealand
    Posts
    1
    Me too.
    Celica XX - 1GGTE 1981
  9. #282
    SupraForums Member
    Join Date
    Jan 2007
    Location
    Indianapolis
    Posts
    164
    1986 MKII Supra with 2JZGE swap...
    Carlos
  10. #283
    SupraForums Member CasperMK2's Avatar
    Join Date
    Mar 2010
    Location
    Area51
    Posts
    543
    Casper
    1985 MKII Supra (German import)
    5mge
    Mods: intake and exhaust
    The Netherlands
    1996 Toyota Supra Turbo
  11. #284
    Join Date
    Jul 2010
    Location
    Oakville, Ontario
    Age
    27
    Posts
    55
    Evan
    1984 MKII Supra Custom Blue
    Mods- 7mgte in progress 300/300 hp/tq 10-14 psi
    Rota P45 rims
    Dobinson Springs
    KYB AGX Shocks
    Whiteline Swaybars
  12. #285
    Join Date
    Oct 2010
    Location
    Stone Mountain, Ga
    Posts
    6
    1984 MKII with 5mge
    stock
    stone mountain, ga
  13. #286
    SupraForums Member black_veilside's Avatar
    Join Date
    Aug 2003
    Location
    Fresno, CA
    Age
    46
    Posts
    737
    1985 sdr
    fresno, ca
  14. #287
    Join Date
    Nov 2010
    Location
    Atlanta, GA
    Posts
    3
    1985 p-type
    Atlanta, GA
  15. #288
    Join Date
    Nov 2010
    Location
    California
    Posts
    44
    Carlos, p-town, 86, 5m soon to be 7mgte
    86 MKII 5m (7mgte swap coming soon ) "Turbo baby yea!"
  16. #289
    83 P-Type
    Stock
    Austin.
    OK so what is the total?
    Jim
  17. #290
    Join Date
    Jan 2011
    Location
    Ontario, Canada
    Posts
    2
    Thomas, Ontario, 85' P-Type, all stock.
    Full restore here we come...
  18. #291
    So... Yeah... tdubz04's Avatar
    Join Date
    May 2006
    Location
    Appleton, WI
    Age
    36
    Posts
    422
    Trevor Wentzel, Appleton WI. White 85 P-type, 5mge
    1994 Black Toyota Supra TT Targa.
    1985 White Toyota Supra P-Type(SOLD).
    1992 Crimson Red Metallic Lexus SC300.
    www.facebook.com/tdubz04
  19. #292
    Join Date
    Feb 2011
    Location
    Sacramento CA
    Posts
    10
    Danny, Folsom CA 1982 Supra. No idea what the engine is though...
  20. #293
    Join Date
    Jan 2011
    Location
    missoula, mt
    Posts
    4
    Ryan
    85 Celica Supra
    Missoula, Mt
  21. #294
    Join Date
    Apr 2011
    Location
    Phx, AZ
    Posts
    1
    Kev. See left margin.
    Black 85 w/5m bone stock.
  22. #295
    Join Date
    Mar 2011
    Location
    Portland, Or
    Age
    38
    Posts
    3
    Brad
    Metallic Blue 83, 5M parts car.
    Black 85, 5M Auto, two owner daily driver.
  23. #296
    Join Date
    Apr 2011
    Location
    las veags
    Posts
    1
    just signed up been on celica supra for a while.. any how
    1985 P Type with a just finished 1UZFE Swap and loving it!!
  24. #297
    Join Date
    Apr 2011
    Location
    Orlando, FL
    Posts
    3
    Brian Orlando 1985 p-type with BMW M3 midnight blue paint
  25. #298
    Join Date
    May 2011
    Location
    el paso texas
    Age
    31
    Posts
    2
    Blog Entries
    1
    Tommy v
    El paso, tx
    85 p type no engine.. in the process of saving up for 2jz swap no where near close to being done haha.. wish me luck
    Out of pocket builds destroyed my life
  26. #299
    SupraForums Member
    Join Date
    Feb 2007
    Location
    Lafayette, CO
    Posts
    11
    S. Lee
    Lafayette, CO
    1984 Celica Supra, 7MGTE, 3" DP to 2.5" catback,Magnaflow muffer,Sparco 383 suede steering wheel,Sparco Corsa seat,AGXs shocks around, Addco Bars front and rear,TSC bar rear strut bar,LJM front strut bar,GC Coilovers with Eibach springs front,T3 Camber,T3 RCA,Dobinsons rear springs, SuperPro rear & PST front,16x8 Circle Racing wheels,Cressida Lip,JK Big Brake Kit,PG Power Brute LSD,black interior
    1984 Celica Supra, 7MGTE, 3" DP to 2.5" catback,Magnaflow muffler,Sparco 383 Suede,Sparco Corsa,AGXs, Addco Bars,TSC bar,LJM,GC Coilovers, Eibach springs,T3 Camber,T3 RCA,Dobinsons, SuperPro rear & PST front,16x8 Circle Racing,Cressida Lip,JK BBK,PG Power Brute LSD,black interior
  27. #300
    Join Date
    Jun 2010
    Location
    Queens NY
    Posts
    2
    Rocky W.
    Queens NY
    84 P-type
    5mge soon to be a 5mgte...
    -Rocky W.
    87 Cressy DD
    84 P-type in the O.R.
+ Reply to Thread
Quick Reply Quick Reply
Register Now
List your Car(s)
Where you live
Log-in
Posting Permissions
  • You may post replies
  • You may not edit your posts
