GTE non VVTi to VVTi conversion, Facts and myths - Page 3
+ Reply to Thread
Page 3 of 6 FirstFirst 1 2 3 4 5 6 LastLast
Results 51 to 75 of 144
Thread: GTE non VVTi to VVTi conversion, Facts and myths
  1. #51
    Dr. Jeff Lange Jeff Lange's Avatar
    Join Date
    Aug 2003
    Location
    Canada
    Posts
    9,333
    To those curious, the block was changed and the the oil feed added in cars produced after May, 1995.
    Jeff
    2011 Lexus IS350 Obsidian "F-Sport 6MT" with LSD
    1986 AE86 Corolla GT-S Supercharged
  2. Remove Advertisements
    SupraForums.com
    Advertisements
  3. #52
    Follow the white rabbit -Defi-'s Avatar
    Join Date
    Dec 2010
    Location
    Colorado Springs
    Posts
    1,652
    Is there a place to source just the head or is purchasing a long block the only way to go?
  4. #53
    SupraForums Member
    Join Date
    Oct 2006
    Location
    supra land
    Posts
    1,975
    Does anybody know what is the part number for the2jzgte vvti head?
  5. Remove Advertisements
    SupraForums.com
    Advertisements
  6. #54
    SupraForums Member Jostar's Avatar
    Join Date
    Aug 2004
    Location
    Chicago IL
    Age
    38
    Posts
    3,318
    Quote Originally Posted by oddsupra1 View Post
    I checked how much is a 2JZGTE VVT-i brand new is 3,300 dollars plus shipping from JDM land. bare head too.
    Getting out Boosted by Turbobozzer... for now...
  7. #55
    SupraForums Member
    Join Date
    Jan 2002
    Location
    Finland
    Age
    38
    Posts
    5,330
    Here's the oil line I made for the VVTi.
    I used the extra port on the side of the block and then from the VVTi solenoid side I cut the original banjo and welded on a male pipe connector to it. Dont know what it's called, but like this:
  8. #56
    SupraForums Member FDNewbie's Avatar
    Join Date
    May 2004
    Location
    Tampa
    Posts
    410
    Quote Originally Posted by -Defi- View Post
    That's my question.
    And any recommendations for exporters who won't charge an arm and a leg based on the likely increased demand they're seeing? Or maybe even possibly a GB??
  9. #57
    Garage Queen Club dre99gsx's Avatar
    Join Date
    Oct 2001
    Location
    Somerset, NJ
    Posts
    2,799
    Make sure the AC Compressor fits!
    Quote Originally Posted by Krister View Post
    Andre
    2JZ in a BMW Z4 Project -> https://www.supraforums.com/forum/sho...1-BMW-Z4-Build
    PTE6768 RSP MKIV - 845whp/Pump/Meth -> http://www.youtube.com/watch?v=C6HEN...eature=related
    Start your supra with a push button -> http://www.youtube.com/watch?v=2n6F-owxgyY
    "I'd rather be a famous drunk than an anonymous alcoholic..."
  10. #58
    SupraForums Member
    Join Date
    Jan 2002
    Location
    Finland
    Age
    38
    Posts
    5,330
    Quote Originally Posted by dre99gsx View Post
    Yeah it fits no problem.
    Anyone know on the AEM V2 VVC map are the values cam angle or crank angle? With the oversize valves, high compression etc, the valves will hit the piston before the adjustment on the VVTi cam gear is on full advance. So I'll have to make sure I dont adjust the advance too much.
  11. #59
    SupraForums Member
    Join Date
    Jun 2006
    Location
    Auckland, New Zealand
    Age
    33
    Posts
    60
    Quick question. The way I understand it the vvti solenoid only adds timing. So if left unplugged it will set the timing advance to 0?
  12. #60
    SupraForums Member
    Join Date
    Dec 2007
    Location
    Philadelphia
    Age
    36
    Posts
    1,071
    The GTE VVTi is not interference when it's stock - correct? It's only when you add high lift cams over 9.2mm that you have interference.
  13. #61
    SupraForums Member
    Join Date
    May 2004
    Location
    San Diego
    Posts
    3,549
    Quote Originally Posted by Py7h0n View Post
    Depends when you unplugged it. It will be locked at the last place it was unplugged.
    Quote Originally Posted by Jeff Lange View Post
    Jeff
    Thanks Jeff! I will add this to the documentation.
    Quote Originally Posted by jdubs View Post
    Yes factory is non interference. I can tell you with my 10:1 compression and HKS cams it is still non interference. I have tuned another car with BC VVTi cams and it was also non interference. I have seen GSC2 VVTi cams work with 60degrees of advance, so interference isn't always a deal breaker. I think the biggest worry would be with larger +1 valves.
  14. #62
    Registered User
    Join Date
    Apr 2002
    Location
    WHP
    Posts
    5,110
    Quote Originally Posted by bigtwin41st View Post
    Without putting pro efi and MoTeC
    M800 in the mix, I would say hks fcon vpro 3.24, LinkECU LinkPlus, Autronic, Vi-PEC V88, Haltech
    Don't forget ECUMaster
    I picked up a VVTi GE motor for just a few hundred bucks off craigslist. I'll be switching from a 1JZ cylinder head, so I'm not concerned about manifold compatibility, plus the GE exhaust ports look better than the GTE ports at first glance. GTE VVTi motors are all imported, whereas there's a substantial supply of GE VVTi motors from Lexus vehicles.
    If you're concerned about keeping your existing manifolds, buying a complete JDM motor or sourcing a new cylinder head from Japan will be your best options.
  15. #63
    A zone of danger. Dego Red's Avatar
    Join Date
    Apr 2005
    Location
    SE Michigan
    Age
    38
    Posts
    1,175
    Quote Originally Posted by cwtt View Post
    ...I can tell you with my 10:1 compression and HKS cams it is still non interference. I have tuned another car with BC VVTi cams and it was also non interference. I have seen GSC2 VVTi cams work with 60degrees of advance, so interference isn't always a deal breaker...
    Good info as usual Chris, but I'm curious about that last part - You're referring to normal cam phase operation, correct? What about interference during belt failure with GSC S2, BC, HKS? I'm curious if the 9.2mm lift threshold still exists with a higher-than-stock CR piston.
    After my little incident we discussed, I'm going with a 9.5:1 piston, BC rods and a head lap, so right around 9.7:1 final CR and just not sure what to do for cams yet. A Gates race belt is a given though.
    1997 DJG 6spd - 10:1, VVTi, ProEFI, HRE, BBK, etc.
    2011 LP570-4 Superleggera - Stock...for now.
  16. #64
    SupraForums Member
    Join Date
    May 2004
    Location
    San Diego
    Posts
    3,549
    Quote Originally Posted by Dego Red View Post
    If a belt fails and you have an interference motor well, its not going to be pretty. When I built my personal motor I could physically turn the cam 360 degrees and it didnt touch a thing (HKS cams, 10:1 compression). So if a belt failed on my motor it would just spin and stall. Obviously when you get into the bigger lift cams you won't have the same luck if the belt snapped. Where that exact point is will vary on every setup.
    I don't have personal experience with higher than stock compression and big lift cams. I just know that it works. Dentguy has 10:1 compression and large kelford cams and Rocketman on here has GS2 with no issue.
  17. #65
    SupraForums Member
    Join Date
    Feb 2002
    Location
    Ft. Worth Texas
    Posts
    2,183
    It'll always return to full retard if the solenoid isn't being pulsed (disabled or unplugged) while the motor is turning. Cam advance will always be at full retard during cranking.
    1997 GE VVTi 6spd
  18. #66
    SupraForums Member
    Join Date
    May 2004
    Location
    San Diego
    Posts
    3,549
    Quote Originally Posted by Kurt View Post
    That would make sense. Can you elaborate by your statement "It'll always return to full retard." I have heard conflicting reports about this and I'm curious your view on it.
  19. #67
    SupraForums Member
    Join Date
    Jan 2002
    Location
    Finland
    Age
    38
    Posts
    5,330
    Were your piston at TDC? You could turn the cam even through the engine if interference if your piston isnt at TDC.
    Depends also if the block and head is milled. My engine was interference on HKS 264's. CP 8.5:1 and stock valves.
  20. #68
    SupraForums Member
    Join Date
    Feb 2002
    Location
    Ft. Worth Texas
    Posts
    2,183
    The OCV works with PWM, so it's either on or off but controlled at high speed with varying duty cycle. When it's on, oil pressure fills the chamber inside the cam gear. When it's off, that chamber is open and the oil can return and drain to the pan. The resistance of the cam pushing down on the valves is what drives that middle (piston) gear back and closes that chamber. What's happening with the PWM duty is oil is moving into and out of that chamber at different rates depending on duty cycle. Oil pressure is what's pushing it advanced, valvetrain resistance is what's pushing it back retard. There is a certain amount of duty cycle (oil flow) that will hold the cam at any given advance, so 78% duty cycle (could be ~45% depending on flyback diode) will hold the cam at 10° or 20°. When the target angle changes, duty cycle will increase or decrease a little from 78% to drive the cam to the desired angle and return to 78% to hold it at that angle.
    EDIT: Sorry, I have it slightly wrong. There are two chambers in that gear and that valve will control oil to both front and rear. The tolerances allow the oil to drain, though, and while cranking the drag from the valvetrain will slide the helical center gear to full retard.
  21. #69
    SupraForums Member
    Join Date
    May 2004
    Location
    San Diego
    Posts
    3,549
    Kurt, I understand the physical workings of the OCV, however I was confused when you used the word "full retard." I'm assuming you mean it reverts back to 0 degrees (no advance/no retard). It is my understanding that the cam only advances 0-30degrees in an OEM application, so the cam is never retarded. Meaning -4degrees etc.
    I think this may just be a misunderstanding/interpretation of the wording on how it works.
  22. #70
    SupraForums Member
    Join Date
    Feb 2002
    Location
    Ft. Worth Texas
    Posts
    2,183
    Yeah, that's what I mean. 0 degree = no advance = full retard = whatever you want to call it.
  23. #71
    SupraForums Member
    Join Date
    Jan 2002
    Location
    Finland
    Age
    38
    Posts
    5,330
    The VVTi head only has the rear cam sensor and AEM uses the front one. Should I use the front cam sensor plug to the rear cam sensor? 26B is the front one and 25B the rear one.
    For some reason I'm not getting cam sensor signal to AEM and AEM isnt syncing. Same issue with either cam sensor plug. I'll need to check the wiring and another cam sensor.
  24. #72
    spracingonline.com DentGuy's Avatar
    Join Date
    Aug 2008
    Location
    Algonquin, IL
    Age
    37
    Posts
    2,875
    Yes plug the front cam plug into the rear sensor, you'll also need to adjust you TDC ignition offset accordingly. You are using a 36-2 crank trigger wheel right?
    Bob W.
    MoTeC M150
  25. #73
    SupraForums Member JoeSupra's Avatar
    Join Date
    Aug 2005
    Location
    New Jersey
    Age
    29
    Posts
    3,461
    Great post for sure. Can anyone throw up links on where to source out the parts for the vvti oil line from the block to the head? I think that will be a helpful source of info for the people who are just going to buy the head itself.
    Also if someone who buys a vvti complete motor obviously it would come with the oil line, but would it be necessary to replace the stock vvti oil line with a larger line if your shooting for a high horsepower?
    2012 Ram 3500 HD CTD
    1993 Toyota Supra
    1995 Toyota Supra SE
  26. #74
    Join Date
    Aug 2008
    Location
    Algonquin, IL
    Age
    37
    Posts
    2,875
    Quote Originally Posted by JoeSupra View Post
    The VVTi feed line would not need to be upgraded or changed at all. The cam is only advanced in the lower Rpms.
  27. #75
    SupraForums Member
    Join Date
    Jan 2002
    Location
    Finland
    Age
    38
    Posts
    5,330
    Quote Originally Posted by DentGuy View Post
    OK thanks. Yes, I'm running the 36-2 trigger wheel. I tried another cam sensor and checked the wiring, same issue. What is strange that when I select on AEM V2 setup wizard the non-vvti trigger system, I start to get cam count. But with the VVTi 36-2 selected, I cant get cam count. Here's an AEM log of the cranking if someone wants to check it out.
    https://dl.dropboxusercontent.com/u/...20starting.daq
    What do you mean by adjusting TDC ignition offset?
    Also I've been doing some reading and came across this:
    http://www.adaptronic.com.au/forum/i...p?topic=2634.0
    According to that thread, with the VVTi, you would need to run wasted spark. Any input on this?
    The 3 evenly spaced teeth on the intake cam cannot be used as a 720 degree reset as there's no way for the ECU to identify a complete camshaft revolution like would be the case if there were only one tooth, or for example 4 evenly spaced teeth plus an additional tooth after one of the 4 (referred to as 4+1 as used by some manufacturers). From what I can see after googling some VVTi 2J cylinder head pics there is only one cam position sensor on the VVTi 2J which reads the 3 teeth. The ECU determines crank position from the missing teeth on the crank but has no way of determining the start of the engine cycle. This probably explains why these engines run from factory in wasted spark configuration.
+ Reply to Thread
Quick Reply Quick Reply
Register Now
List your Car(s)
Where you live
Log-in
Similar Threads
  1. 1JZ-GTE VVTi drive by wire conversion????? !HELP!
    By I_LOVE_BOOST in forum General Supra Forum
    Last Post: 06-18-2014, 11:28 PM
  2. 1jz gte vvti head 2jz gte (non vvti) block
    By memoriesofmotion in forum MKIV (1993-1998)
    Last Post: 07-26-2012, 01:50 AM
  3. Replies: 3
    Last Post: 01-06-2009, 12:56 PM
Posting Permissions
  • You may post replies
  • You may not edit your posts
