GTE non VVTi to VVTi conversion, Facts and myths - Page 5
+ Reply to Thread
Page 5 of 6 FirstFirst 1 2 3 4 5 6 LastLast
Results 101 to 125 of 144
Thread: GTE non VVTi to VVTi conversion, Facts and myths
  1. #101
    SupraForums Member
    Join Date
    Jan 2002
    Location
    Finland
    Age
    38
    Posts
    5,330
    Same as above
  2. Remove Advertisements
    SupraForums.com
    Advertisements
  3. #102
    SupraForums Member bigkahuna2187's Avatar
    Join Date
    Sep 2007
    Location
    Florida
    Posts
    80
    Does having a factory ECU (Aristo, IS300 etc) serve any benefit for controlling VVT-i or only if its tuned with a standalone? I'm sure actually tuning it would use the VVT-i to its full potential but I'm wondering what benefits there are compared from a factory VVT-i tune to a non-VVT-i.
    2004 Lexus IS300 2JZ-GTE VVT-i
  4. #103
    SupraForums Member JDMricer's Avatar
    Join Date
    Jun 2008
    Location
    Canada
    Posts
    1,349
    I'm looking for the toyota emblem for the vvti valve cover. Anyone know if it's the same as the non vvti? Bonus points if you have the part number. Not sure if you can buy this separate.
    93 VVTI GTE, V161, PTE 6768, AEM Infinity 6 tuned by Vlad @ NationalSpeed.
  5. Remove Advertisements
    SupraForums.com
    Advertisements
  6. #104
    SupraForums Member
    Join Date
    May 2004
    Location
    San Diego
    Posts
    3,549
    Quote Originally Posted by JDMricer View Post
    The emblem is molded onto the valve cover. It is not separate.
  7. #105
    Join Date
    Jun 2008
    Location
    Canada
    Posts
    1,349
    Hmmmm mine is missing completely. Someone must have shaved it. I assumed it was stick on.
  8. #106
    SupraForums Member ATLspeed's Avatar
    Join Date
    Jan 2007
    Location
    Laurel, MD
    Posts
    162
    Technically, could you run a GTE non-vvti ecu with a vvti head? Of course vvti will be disabled, but couldn't you just run it that way like a non vvti until you get to a tuner? Since it's disabled there is no way for the gear to retard/advance.
  9. #107
    SupraForums Member
    Join Date
    May 2004
    Location
    San Diego
    Posts
    3,549
    Quote Originally Posted by ATLspeed View Post
    No. The motors have completely different trigger patterns. 12 tooth vs 36-2.
  10. #108
    Join Date
    Jan 2007
    Location
    Laurel, MD
    Posts
    162
    Ahhh forgot about the trigger ring
  11. #109
    SupraForums Member
    Join Date
    Sep 2011
    Location
    Lancaster PA 17602
    Posts
    299
    So I know this thread hasn't been talked on for a few months, but does anybody have access to the vacuum diagram for the GTE VVT-i? I am tearing my hair out trying to find it and am confused on the large port on the back of the upper intake.
  12. #110
    SupraForums Member supralover93's Avatar
    Join Date
    Mar 2002
    Location
    Sacramento, ca
    Age
    34
    Posts
    4,519
    do you have a pic? is it the one for the brake booster?
    93 turbo targa
    auto
    BPU
  13. #111
    SupraForums Member
    Join Date
    Sep 2011
    Location
    Lancaster PA 17602
    Posts
    299
    No, but close, it is the large one on the back of the upper intake manifold, the area on the manifold where there is a small bulge.
  14. #112
    SupraForums Member
    Join Date
    Sep 2011
    Location
    Lancaster PA 17602
    Posts
    299
    I took this picture from a google search. The one in the lower right of the picture just below the brake booster banjo that still has a cut section of hose attached to it. toyota_2jz_vvti_30_twin_turbo_supra.jpg
  15. #113
    Join Date
    Mar 2002
    Location
    Sacramento, ca
    Age
    34
    Posts
    4,519
    Pretty sure that's for the brake booster for the aristo
  16. #114
    SupraForums Member
    Join Date
    Sep 2011
    Location
    Lancaster PA 17602
    Posts
    299
    Then what is the banjo bolt one for?
  17. #115
    Game Over Boost Wang's Avatar
    Join Date
    Apr 2008
    Location
    Portland OR
    Age
    27
    Posts
    1,146
    Question,
    For the guys who have swapped in their non VVTi TB and Intake manifold to these heads, does the factory TRAC casting/motor on the non VVTi TB interfere with the oil feed banjo area?
    -Sam
    1993.5 White turbo hardtop. 1 of 26
  18. #116
    Join Date
    Aug 2016
    Location
    Wichita KS
    Posts
    2
    good info nice read
  19. #117
    SupraForums Member mkivsoopratt's Avatar
    Join Date
    Jun 2010
    Location
    South Florida
    Posts
    791
    would also like to know if a non vvti intake manifold and throttle body will fit with a vvti oil control valve
    “Lag is foreplay” - Biologist
    1995 Toyota Supra Single Turbo 6 Speed Hardtop VVTI
    1991 Nissan Skyline R32 GTS-T 5 speed
    2017 Toyota Tacoma V6
  20. #118
    Boost Addicted. 4wd-eclipse's Avatar
    Join Date
    Apr 2008
    Location
    Muscat - OMAN
    Posts
    1,217
    Anyone using PHR Cam and Crank Hall Effect Sensor Kit with 2JZ VVTi?
    https://www.supraforums.com/forum/sho...or-2jz-and-1jz
    MK
    *95 Supra TT 6-Speed Hardtops .. Stock long block, VVTi head with GSC S2, AEM Infinity EMS, PTE PT7275 Gen2, HKS turbo manifold, TMS intake manifold, ETS Intercooler, ID1300, LQ9, HKS Super Drager, VR TE37, GReddy Big Brakes, ...
    My Supra pics thread : https://www.supraforums.com/forum/sho...t=#post9787793
  21. #119
    I blame the Midwest Sect.
    Join Date
    Jul 2003
    Location
    Indianapolis, IN
    Age
    32
    Posts
    1,097
    A digital crank sensor will not work with the vvti crank trigger. The teeth are too small and too frequent for the sensor to pick up.
    '91 MR2 Turbo
    '93 RX7 9.97 @ 134 NA LSx
    '95 Supra Turbo Billet GT42-76 1050whp 9.60 @ 150
  22. #120
    Join Date
    Jun 2010
    Location
    South Florida
    Posts
    791
    I'm about to swap in a vvti motor to my supra that currently has a non vvti gte. Ms3x ecu single turbo e85. Is it possible to drop the vvti motor in and not have the oil control valve connected until I can get the car to my tuner? Will it run fine like that? From what I understand it will be at 0 degrees at all times
  23. #121
    Join Date
    Aug 2010
    Location
    lubbock tx
    Posts
    45
    so , if i dont want to do a head swap like you guys are refering too, i have a 97 na i want to just do a whole vvti gte swap , how hard is it to put a jdm vvti swap into car? what is main differences vs a non vvti gte swap on a Na?
  24. #122
    SupraForums Member
    Join Date
    Jul 2013
    Location
    Los Angeles
    Posts
    271
    A breakdown of my GTE swap costs to help guide some people that want to attempt it themselves. Includes a lot of costs for parts you don't really consider at first.
    https://docs.google.com/spreadsheets...it?usp=sharing
  25. #123
    Join Date
    Mar 2002
    Location
    Sacramento, ca
    Age
    34
    Posts
    4,519
    That's great info. Thank you
  26. #124
    SupraForums Member suprahero's Avatar
    Join Date
    May 2006
    Location
    Roll Tide
    Age
    48
    Posts
    1,574
    subscribed. I'm putting one in my MKIII right now.........slowly........on weekends..........when I'm not working or playing golf.
    1.5jz 640 RWHP, 606RWTQ
  27. #125
    Join Date
    Apr 2012
    Location
    Cincinnati
    Posts
    48
    Everything about this makes me happy.
    I've been preaching VVTI for years.
+ Reply to Thread
Quick Reply Quick Reply
Register Now
List your Car(s)
Where you live
Log-in
Similar Threads
  1. 1JZ-GTE VVTi drive by wire conversion????? !HELP!
    By I_LOVE_BOOST in forum General Supra Forum
    Last Post: 06-18-2014, 11:28 PM
  2. 1jz gte vvti head 2jz gte (non vvti) block
    By memoriesofmotion in forum MKIV (1993-1998)
    Last Post: 07-26-2012, 01:50 AM
  3. Replies: 3
    Last Post: 01-06-2009, 12:56 PM
Posting Permissions
  • You may post replies
  • You may not edit your posts
