The 1993.5-1998 Toyota Supra Discontinued Parts Thread
Page 1 of 12 1 2 3 4 5 6 7 8 9 10 11 ... LastLast
Results 1 to 25 of 292
Thread: The 1993.5-1998 Toyota Supra Discontinued Parts Thread
    I'm not serious
    Administrator
    FasTTurbo's Avatar
    Oct 2001
    CT
    36
    7,836
    A few forum members brought to my attention there isn't much of a definitive list of discontinued parts for the MKIV.
    The purpose of this thread is to list out any known or omitted parts without much discussion other than just that. If not sure if something is discontinued, message me and I'll confirm if it is or not and add it.
    Please also post the Toyota part numbers if you have them.
    This will be an evolution and I will update as time permits and I am taking the info from many existing threads.
    The second phase of this thread will be links to aftermarket alternatives to any of the parts discontinued listed next to the OEM discontinued part.
    Thanks,
    Matt
    Interior/Trim Parts
    1993-96 Specific
    Premiere edition logo on ash tray
    55420-14040 Panel Ctr Dash List 64.42 Cost 49.19 [ discontinued ]
    55410-14510 Panel Top Dash List 157.25 Cost 120.05 [discontinued ]
    55404-14530 panel sub left side dash panel [discontinued ]
    74320-14700-c0 sunvisor, left [discontinued ]
    74310-14640-c0 sunvisor, right [discontinued ]
    55537-14030 heater switch cover [ discontinued ]
    1997-98 Specific
    55404-14570 Panel Lh Dash [ discontinued ]
    55420-14060 Panel Ctr Dash [ discontinued ]
    55405-14170 Panel Rh Dash [ discontinued ]
    55410-14530 Panel Top Dash[ discontinued ]
    58804-14100 Panel Console 6 Speed With Boot[ discontinued ]
    58804-14110 Panel Console Auto [ discontinued ]
    74102-14140 Ash Tray[ discontinued ]
    74232-14121 Panel, Lh Door Switch [ discontinued ]
    97-98 dash plugs under radio in gray [discontinued ]
    97-98 polished 17" wheels [discontinued ]
    74310-14642-C1 - RH Sunvisor [discontinued ]
    1993-1997 MODELS
    84310-1B120 - MULTI-FUNCTION SWITCH
    84112-80152 - LIGHT SWITCH
    84329-14030 - TURN SIGNAL SWITCH
    84652-14620 - Wiper Switch
    84140-14100 - Headlamp/Dimmer Switch
    All Years
    Coil Pack Cover (the green one) 11304-46050
    Targa Air/wind Deflector "eyebrows" PN 63230-14040
    Rear seat foam
    ALL factory leather seat covers front and rear
    Overhead map light
    Tan seat track plastic covers
    93-98 FLOOR MATS
    45100-14630-C0 STEERING WHEEL
    rear speaker assys with black plastic encloseure
    rear trunk/hatch carpet
    AC Evap/heater Box assy
    16400-46430 Radiator Turbo Auto
    Rear Bumper cover - all years discontinued
    87615-24020 -DISCONTINUED- RETAINER, INSULATOR -This is the piece that surrounds the heater core hard lines that come out from the firewall
    82871-24490 -DISCONTINUED- PROTECTOR, WIRING HARNESS-This is the plastic shield/surround that goes on the front right hand apron for the chassis harness.
    Toyota Part No.: 69030-14260 LOCK ASSY, FRONT DOOR, RH [DISCONTINUED]
    Exterior/Trim Parts
    Gold emblems [discontinued ]
    Transmission Parts
    93.5-98 5 speed manual gear box[trans] [ discontinued ]
    33030-0w212 v160 6spd transmission assy [ discontinued ]
    93.5-98 na 5 speed LSD diff assy [ discontinued ]
    33370-0W010 HUB ASSY, SYNCHRONIZER, NO.2
    90069-10011 BEARING
    90069-10019 BEARING
    Counter shaft assembly 33421-0W060 [ discontinued ]
    6TH gear Counter 33429-0W010 [ discontinued ]
    5th gear Counter 33428-0W030[ discontinued ]
    1st gear driven 33032-0W030[ discontinued ]
    Suspension/Chassis Parts
    93-97 Rear lower control arms (shock and knuckle attach to) Discontinued
    48730-14030
    48740-14060
    Engine Mechanical Parts
    Engine lift hooks on cylinder head.
    Body/Frame/Crash Parts
    97 Anniversary emblems on fenders
    Pearl white side scoop extractors LH and RH
    LH frame rail assy to fire wall
    right rear qtr panel outer wheel house
    Engine/Body Electrical Parts
    97-98 Harnesses discontinued
    82121-1B112 - Wiring Harness Engine 6 speed
    82121-14891 - Wiring Harness Engine Auto
    84988-14020 - Trac On/off switch [discontinued]
    Blower motor 87105-14050 FAN SUB-AS SPORD
    complete key cylinder set (all doors + ignition) PN#6900514690
    Main engine compartment wire harness for turbo
    88002-14030 CRUISE CONTROL UNIT [discontinued]
    47990-14010 Trac Actuator [discontinued]
    TRD Parts
    Ptr04-00026 trd lsd a list 1582.11 cost 1186.58 [discontinued ]
    TRD Tachometer
    pink painted powerfucked cat's ass - Jeff (Wreckless) 2018
    Find me on IG: @sick_6
    supraforums on IG:@SUPRAFORUMSPICS
    Looking for turbo auto or 6spd Supras!
    93 Alpine Auto
    94 Alpine 6spd
    94 RR 6spd
    97 Alpine AT
    98 QS AT
    ①③⑤
    ②④⑥R
    Going for broke
    Mar 2010
    CT
    30
    622
    Floormats, rear hatch carpet, TRD single-disc clutch...
    '97 Deep Jewel Green TT 6 spd
    It's got some little trinkets attached to the motor and stuff
    @typical_suprahero on Instasuck
    Super Moderator Letsride's Avatar
    Apr 2003
    NC
    1,271
    V160
    "You know what? This will decimate all,
    after, you put about fifteen grand in it or more.
    If we have to, overnight parts from Japan.!!"
    Cardinals! codex's Avatar
    Oct 2007
    USA
    40
    1,547
    - Left & right interior door panels.
    About 98% sure all of these are long discontinued..
    - Euro hood scoop's under hood air deflector.
    - Glove box
    - Headliners
    - A/C control unit
    - Jeff
    1994 Supra 6-speed Twin Turbo
    2001 Lexus IS300
    SupraForums Member 2JZ_Freak_SE's Avatar
    Jul 2012
    Dallas
    1,657
    Quote Originally Posted by max3em View Post
    Shift knob
    Shift knobs are now discontinued?
    Also center 'crotch' vent panels, and rear quarter, front windshield, glass interior plastic panels are discontinued.
    I am looking for an Authentic TRD or MVP Widebody side skirts, rear fender, and bump.
    Jul 2012
    Dallas
    1,657
    Are we also going to count all the electronics such as factory sub and HUs?
    Captain Hammer raven97990's Avatar
    Apr 2002
    Gainesville GA
    35
    2,020
    Quote Originally Posted by codex View Post
    - A/C control unit
    The AC Amplifier? Just got one in today brand new from Toyota.
    Jared Pink - ASE Master Certified (A1-A8) ASE L1 Certified and Toyota Factory Trained Master Diagnostic Technician, Toyota Hybrid Certified
    Shop Manager for Speed For Sale LLC ([email protected])
    (Pre-owned Supra,GT-R,RX-7, 300zx sales & new parts sales/installs/tuning)
    All your boost are belong to us.
    Jul 2012
    Dallas
    1,657
    Here's a list from the local Texas Supra page. Many have been mentioned already:
    Gold emblems
    SE side stripes
    Floor mats
    Limited edition logo on ash tray.
    93.5-98 na 5 speed LSD diff assy.
    LH dash panel Gray 97-98
    Console bezel ATM and MTM gray 97-98
    AC Evap/heater Box assy.
    Overhead map light.
    Front end mask [bra]
    Alarm systems with and with out keyless entry.
    ALL factory leather seat covers front and rear.
    Main engine compartment wire harness for turbo.
    LH frame rail assy to fire wall.
    97-98 dash plugs under radio in gray.
    rear speaker assys with black plastic encloseure.
    Baltic blue touch-up paint.
    rear trunk carpet .
    evap drain hoses.
    right rear qtr panel outer wheel house.
    The metal plate on the firewall that goes around the heater core hoses in the engine bay and the rubber gasket beneath
    I'm not serious
    Administrator
    FasTTurbo's Avatar
    Oct 2001
    CT
    36
    7,836
    Quote Originally Posted by 2JZ_Freak_SE View Post
    All discontinued parts, so yes.
    Theres many small things people aren't aware of that are discontinued.
    Also anyone just posting please check the list before adding the item.
    Matt
    I'm not serious
    Administrator
    FasTTurbo's Avatar
    Oct 2001
    CT
    36
    7,836
    Shift knob
    Quote Originally Posted by SupraHKSx View Post
    Glad I got my parts for my 6 speed swap! Better now than feeling sorry later.
    I also ordered a 6 speed shift knob... So it ain't discontinued. Yet.
    Quote Originally Posted by jza80king View Post
    Can you give me the part number for the shift knob? I need to jump on this as mine is showing wear and I would like to replace it.
    6spd shift knob is not discontinued.
    Part number is 33504-14130
    Oct 2007
    USA
    40
    1,547
    V160 countershaft.
    Oct 2007
    USA
    40
    1,547
    Quote Originally Posted by raven97990 View Post
    The A/C control unit. The electronics assembly behind the dash panel that has all the buttons for controlling the A/C:
    55900-14520 HVAC Control Head Assy List 862.37 Cost 620.00
    Listed as discontinued on this site and a few members have tried to order it recently and have been told it's discontinued at local dealers:
    http://www.toyotapartsdeal.com/oem/t...900-14520.html
    Here's a new post by a member asking Elmhurst about that part number.. wait for a response for official verdict:
    https://www.supraforums.com/forum/sho...AC-price-quote
    Apr 2002
    Gainesville GA
    35
    2,020
    V160 countershaft.
    Here are the hard parts that are discontinued on the transmission.
    Although we will soon have stock fitment gears to replace every gear in the V160, designed so you don't have to buy a complete gear set to repair.
    Oct 2009
    tampa
    48
    complete key cylinder set (all doors + ignition) PN#6900514690 discontinued
  17. #15
    SupraForums Member mkivbren's Avatar
    Nov 2003
    PA/MD
    40
    1,294
    All of the sunvisors for 93.5-98 are discontinued.
    94 AP built 3.4 alpine
    93 1A1 htop wingless
    16 lp610-4
  18. #16
    Oct 2007
    USA
    40
    1,547
    Quote Originally Posted by FastTurbo View Post
    Regarding that...
    https://www.speedforsale.com/suprapa...on-p-4087.html
    Speed4Sale is now selling replica ash tray emblems.
  19. #17
    Inline for the win Suprafied's Avatar
    Dec 2001
    Dublin, OH
    4,660
    Blower motor
    V160 Parts:
    90069-10011 BEARING
    90069-10019 BEARING
    Do more with less......
    '95 Toyota Supra TT 6-spd Targa JRR/MoTeC M130 , Accelerated Performance , Sound Performance, Tilton, Precision, Recaro, HKS, ID, Radium, PHR, ETS, OS Giken....
    My Build Thread
    '16 Lexus IS350 AWD F-Sport
    '09 Dodge Ram 3500 QCLB Dually 6.7 CTD EFI Live by Anarchy
    '05 Toyota Camry XLE - 280K and rolling!
  20. #18
    SupraForums Member SupraHKSx's Avatar
    Oct 2003
    Los Angeles, CA - San Jose, Costa Rica - Miami Beach, FL
    3,913
    Can anyone confirm if the TRD tach is now totally discontinued?
    Per MVP's site....
    Part #: TRD Tach Supra 6
    Product: SOLD OUT AND DISCONTINUED!!
    Your Price: $500.00
    I lucked out then. Got mine about 3 weeks ago, but from someone else.
  21. #19
    I'm not serious
    Administrator
    FasTTurbo's Avatar
    Oct 2001
    CT
    36
    7,836
    The trd tachs I believe can still be purchased by a dealer I believe at 50 pieces at a clip to make a run of them Cost is around $150 a piece believe it or not. The markup on them is huge
  22. #20
    SF Contributing Member bitshftr's Avatar
    Jan 2009
    Raleigh, NC
    51
    2,925
    According to Robert at MVP, the company that made them for TRD is out of business.
    1995 Supra NA, Baltic Blue, targa, TRD LSD, Recaro Sport seats, Cusco carbon fiber front/rear strut tower bars, 97+ front turns
    Passport hardwired, w/ amped remote speakers in seat harness slots
    Hidden/hardwired garage door opener w/ custom Supra dash button
    1995 Supra TT, BPU+, Baltic Blue, targa, TRD front/Cusco rear strut tower bars, 98 headlights w/ 6k HIDs, 97+ front turns, BNR turbos, Tial BOV, HKS Super Drager exhaust, SSR Professor SP1 wheels, Racelogic TC, VPC/GCC
    Passport hardwired
    Subtle white LED dash backlights
  23. #21
    I'm not serious
    Administrator
    FasTTurbo's Avatar
    Oct 2001
    CT
    36
    7,836
    Quote Originally Posted by bitshftr View Post
    Well super then!
  24. #22
    SupraForums Member NgoFcukinWay's Avatar
    Feb 2004
    Houston
    31
    1,061
    '93-'96 front bumper is discontinued.
    1993.5 Toyota Supra ....with stuff.... .... and it's sorta broken....
    1998 Toyota Celica ....this one, too, has stuff.... ....and it's broken....
  25. #23
    SF Contributing Member AristoA's Avatar
    Jan 2002
    Pasadena, CA
    413
    Denso made them for TRD. How are they out of business? Maybe they just refuse to make any more.
  26. #24
    Apr 2002
    Gainesville GA
    35
    2,020
    Essentially this renders the V160 unreadable once the current limited inventory is gone. This updates the A to B syncros. So if you have a 95 or older box, and need new syncros, you're SOL.
    I'm working on getting this built from one of our transmission parts providers.
  27. #25
    SupraForums Member SupraPVB's Avatar
    Jan 2008
    Jacksonville, FL
    992
    Looks like A few more TRD items are gone according to the MVP thread
    PTR04-00004 FOR 15 AND ANOTHER ORDER FOR 10 TOTAL 25 – Discontinued 12360-JA800 TRD ENGINE MOUNT
    10 in US stock that will be released to you. The last 5 are in transit and when they arrive we will release them to you.
    PTR04-00008 FOR 20 – Discontinued TRD THERMOSTAT. 16340-SP020
    No replacement is planned at this time
  1. Misc parts thread, 1993.5 Toyota Supra Auto
    By SupraJZGTE in forum Elmhurst Toyota Scion
    Last Post: 10-28-2015, 11:36 AM
  2. Toyota supra mk4 parts for sale 1993.5-1998
    By supradani in forum Midwestern Forum
    Last Post: 12-18-2013, 08:58 AM
