Bolt on 4-Piston front MB brakes & 2-Piston rear Evo brakes - Page 3
+ Reply to Thread
Page 3 of 6 FirstFirst 1 2 3 4 5 6 LastLast
Results 51 to 75 of 129
Thread: Bolt on 4-Piston front MB brakes & 2-Piston rear Evo brakes
  1. #51
    SupraForums Member TerrenceLP's Avatar
    Join Date
    Mar 2011
    Location
    Cary, NC
    Posts
    578
    My set up with a write up to follow -
    2001 S600 Mercedes Benz (345mm Brembo) Front Calipers / get the bolts if you can as the thread pitch is different
    2004 ML500 345mm x 30mm Rotors - these have the closes offset to our i could find, only 2-3 mm off
    2x 2mm washers on each Caliper Bolt
    2 M10x1.0 Banjo Bolts at 35mm lenght for the re-use of the stock banjo lines.
    my Wheels are 18x8 with a +35 offset so I needed to run 5mm wheel spacer, +30 or greater would not need wheel spacers.
    Here it is -
    https://www.youtube.com/watch?v=W8TW08qtQes
    1987 Supra Turbo - Megasquirt 3 w/MS3X & Holset 60/60 Turbo - Mega JOY!
  2. Remove Advertisements
    SupraForums.com
    Advertisements
  3. #52
    SupraForums Member
    Join Date
    Jun 2011
    Location
    Littleton Colorado
    Posts
    95
    I have been very interested in doing brake upgrades for some time now (specifically on the rear), but one of the things that keeps stopping me is loosing an ebrake. With the Evo 8/ Sti upgrade do you maintain full functionality of the ebrake?
    How come I am not finding any Evo 8 calipers on ebay for under $250... wtf!?
  4. #53
    Unlimited Time Attack A70 Twin2Turbo's Avatar
    Join Date
    Nov 2007
    Location
    Mill Creek, Wa
    Posts
    3,540
    Quote Originally Posted by kmichaelokelly View Post
    yes you keep the functioning e brake. theres a parking brake drum inside the rear hats
    And who said that Evo calipers were gonna be cheap? 250 bucks is way cheaper than 1500 for a rear setup.
    -Nick
    1JZ|Link|Precision|Brembo|DBA|Tilton|Carrillo|Diamond|InjectorDynamic|TurboSmart|Technico|ATI|BC|HKS|And Everything Else|
    My Build Thread <-> Www.projecthighrpm.com
  5. Remove Advertisements
    SupraForums.com
    Advertisements
  6. #54
    SupraForums Member
    Join Date
    Jun 2011
    Location
    Littleton Colorado
    Posts
    95
    Quote Originally Posted by Twin2Turbo View Post
    I have replaced my rear rotors and the ebrake shoes before so my assumption was that it should work. I just wanted to make sure rather than assuming that it did't require any further modification and still engaged/disengaged smoothly. I think we have all heard "bolt on" before only to find out that some people can use that term fairly lightly, so sometimes I wince a little upon reading it.
    Oh... you for sure are right about that! Seems most people scoring them way cheaper ($100-$140) so I figured I would humble myself and ask someone to show me their ways! haha
  7. #55
    Join Date
    Nov 2007
    Location
    Mill Creek, Wa
    Posts
    3,540
    definitely haha the word "bolt on" gets thrown around very loosely
  8. #56
    SupraForums Member MarkIII4Me's Avatar
    Join Date
    Oct 2002
    Location
    Charleston, SC
    Age
    38
    Posts
    449
    Quote Originally Posted by TerrenceLP View Post
    You have got to be kidding me. I just finish my setup with 02 S500 calipers and R350 330mm rotors.
    I could have gotten your setup for around the same cost and had a larger rotor with what appears to be better pad coverage.
    * Built 7mgte * JE Pistons * Crower Rods * Crazy Head Porting * 7M Turbo Cam Regrinds * ARP Head Studs * HKS Stopper HG * AEM Cam Gears * Turbonetics Hi-Fi 62-1 Bolt-on Turbo * 5" Blitz SUS Filter * 1JZ FFIM w/ all provisions * Greddy 24R Intercooler * Greddy 720cc low impedence Injectors * Denso 285lph pump w/ 12v mod * Aeromotive AFPR * Tial Q Bov * Trust Power Extreme II Exhaust * BIC Ceramic DDP * Fluidyne Radiator * Flex-a Lite Fans * RPS Max Dual Diaphram PP with Aisin Full Face Disk * AEM v1 Rev.B Mod.C EMS * DH61 Ignitor / Sequential Ignition mod *
  9. #57
    Join Date
    Mar 2011
    Location
    Cary, NC
    Posts
    578
    That would be correct!
    If it helps you I kind of Stumbled on this by buying the wrong calipers. With that fire lit I started doing massive research until I found what would make them work.
    Here is the kicker - s600 - 345mm are still cheap to find now that everyone and their mom knows about the s500 calipers.
    Install Video Update as soon as my new banjo bolts get here.
  10. #58
    Join Date
    Oct 2002
    Location
    Charleston, SC
    Age
    38
    Posts
    449
    In your video, it almost looks like the pad would hang off the rotor's edge. On my setup, the pad sits flush with the rotors edge, but there's a good 1/4" of missed coverage by the hats (look at the wear ring in my pic above). I will say, out of curiosity, I checked if both styles of calipers use the same pads and they do not. And I don't see a Brembo pad option for the S600. So I do like the pad options better on the s500 calipers.
  11. #59
    Join Date
    Mar 2011
    Location
    Cary, NC
    Posts
    578
  12. #60
    SupraForums Member
    Join Date
    Jun 2011
    Location
    Littleton Colorado
    Posts
    95
    Can anyone help out with how they were able to adapt the Evo 8 calipers to the stock line, or in my case Goodridge SS?
  13. #61
    Finally up and running! foreverpsycotic's Avatar
    Join Date
    Jul 2006
    Location
    Southern CT
    Age
    32
    Posts
    3,984
    Will the S600/ML500 setup fit under a MKIV TT wheel?
    1989 Super White Hardtop - Old Hotness (HX35w, 1JZ/R154)
    1991 Super Red Targa - New never-ending project (sxe 63/68, 1JZ/R154, ecumaster)
  14. #62
    Moderator SideWinderGX's Avatar
    Join Date
    Mar 2007
    Location
    Syracuse, NY
    Age
    30
    Posts
    4,893
    They threaded right in, its the same thread pitch.
  15. #63
    SupraForums Member
    Join Date
    Jun 2011
    Location
    Littleton Colorado
    Posts
    95
    Quote Originally Posted by SideWinderGX View Post
    Quote Originally Posted by survyor2 View Post
    Brake fittings: threads do not match. my understanding is that one fitting is flared and the other is inverted flared. They appear to fit at first but I had a leak. I used the stock evo banjo bolts and added a banjo fitting to my brake lines.
    Can anyone else speak to this, and what they did on their install.
  16. #64
    Join Date
    Nov 2016
    Location
    Temecula, CA
    Age
    37
    Posts
    30
    I did the same setup but used 350Z "Brembo" package rotors. Had to go with a 18x10.5 +15 up front and they cleared by less than a .25"
    SHEEPDOG VETERAN
    89 1JZGTE VVT-i PTE 6262 DBB E85 • 585HP on Stock Block
  17. #65
    7M Fanatic sixpack's Avatar
    Join Date
    Jun 2006
    Location
    San Antonio, Texas
    Age
    66
    Posts
    2,976
    Hm, would have thought that the 350Z track rotors would have fit 17" wheels just fine.
    Are those calipers overly tall ?
    I run 13.06" Wilwood rotors (slightly larger than the 350Z track rotors) with the R32 GTS calipers, and they fit my BBS LM 17" wheels just fine.
    By the way, the 350Z track rotors weigh about 6 lbs more than the Wilwoods.
  18. #66
    Join Date
    Nov 2016
    Location
    Temecula, CA
    Age
    37
    Posts
    30
    Yes they may fit 17" I was referring more to the width and low offset for a front wheel. Could also be due to spoke design.
  19. #67
    SupraForums Member
    Join Date
    Jun 2011
    Location
    Littleton Colorado
    Posts
    95
    I found a inverted flare adapter fitting on Summit Racing! This seems to me that it should solve the issue of both sides having concave fittings and convert one side to convex so the stock brake lines match up.
    https://www.summitracing.com/parts/brg-925122/overview/
    survyor2 was this the only issue with the stock lines?
  20. #68
    SupraForums Member
    Join Date
    Jun 2011
    Location
    Littleton Colorado
    Posts
    95
    Another seller that sells essentially the same thing but with O-rings.
    http://www.tallonhydraulics.com/stor...roducts_id=267
  21. #69
    Join Date
    Mar 2011
    Location
    Cary, NC
    Posts
    578
    Hi all,
    To reuse my SSlines I used these - Goodridge Banjo Bolt BREMBO 10MM X 1.0 Stainless Steel
    Will be in a UP position lil funky but is working like a charm and no leaks-
  22. #70
    SupraForums Member
    Join Date
    Jun 2011
    Location
    Littleton Colorado
    Posts
    95
    Some lines don't have a banjo style fitting to just update the banjo bolt, mine are just a straight male that going to the caliper.
  23. #71
    Join Date
    Mar 2011
    Location
    Cary, NC
    Posts
    578
    Lock to lock and full extension and compression on stock shocks and springs. So Far so good! Like I said it's a little funky but IM also running the 345mm rotors.
  24. #72
    SupraForums Member
    Join Date
    Aug 2014
    Location
    Canada
    Posts
    68
    Can someone measure the thickness of the hub centric ring required for this install. I found an eBay seller who will custom make these. This will save having to trim the hub ring. Was going to ask for a specific thickness. Was thinking 29mm or so...? The rotor I’m looking at is the 330mm R350.
    My Supra Thread: Red 1991 Supra w/ 1JZGTE
  25. #73
    Join Date
    Nov 2007
    Location
    Mill Creek, Wa
    Posts
    3,540
    Quote Originally Posted by YYCSupra View Post
    do the math.... Mercedes uses 66.6mm hub bore and Toyota uses 60.10mm
    6.5mm
  26. #74
    SupraForums Member
    Join Date
    Aug 2014
    Location
    Canada
    Posts
    68
    Bolt on 4-Piston front MB brakes &amp; 2-Piston rear Evo brakes
    6.5mm
    I’m not sure I explained myself very well. I guess what I’m looking for is the thickness of the rotor hat. The “length” of the hub ring needs to be less than the thickness of the rotor hat so that it doesn’t stick out (which is why I keep hearing of people having to trim the length of their hub rings). I’ve never used hub rings before so this is my assumption???
  27. #75
    Join Date
    Nov 2007
    Location
    Mill Creek, Wa
    Posts
    3,540
    yea you definitely did not explain yourself very well
    Both manufacturers have a hat thickness of around 7mm
+ Reply to Thread
Quick Reply Quick Reply
Register Now
List your Car(s)
Where you live
Log-in
Similar Threads
  1. FS: LS400 4 piston front brakes
    By karies in forum Canadian Forum
    Last Post: 02-17-2014, 09:00 PM
  2. AP 6 piston front brakes
    By FabShop in forum Florida For Sale/Wanted
    Last Post: 06-03-2010, 11:01 PM
Posting Permissions
  • You may post replies
  • You may not edit your posts
