Finding Part numbers for MK3 connectors.
+ Reply to Thread
Results 1 to 20 of 20
Thread: Finding Part numbers for MK3 connectors.
  1. #1
    Moderator
    l337 M0d3r4t0r
    ZaZZn's Avatar
    Join Date
    Feb 2002
    Location
    Toronto/San Francisco
    Age
    36
    Posts
    12,081
    Hi all,
    I'm looking for part numbers for the connectors for a mk3. Where can I find them? The TWED, just tells you the name of the connector like B1 ect.
    I'm looking for the ABS sensor female side connector 1N and the B connector for reverse lightsabs.jpgreverse.jpg
    Eric W
    87 TT E85
    91 T 60k miles
    98 SC 300
  2. Remove Advertisements
    SupraForums.com
    Advertisements
  3. #2
    SF Contributing Member bitshftr's Avatar
    Join Date
    Jan 2009
    Location
    Raleigh, NC
    Age
    51
    Posts
    2,903
    All of the connectors have a tiny 5-digit number printed on them, which starts with a 1. If you don't have the connector, look for the number on its mate. The mates are ususally 1 digit higher or lower. Once you have that number, you prefix it with 90980- and you have the Toyota part number for it, i.e. 90980-1xxxx.
    1995 Supra NA, Baltic Blue, targa, TRD LSD, Recaro Sport seats, Cusco carbon fiber front/rear strut tower bars, 97+ front turns
    Passport hardwired, w/ amped remote speakers in seat harness slots
    Hidden/hardwired garage door opener w/ custom Supra dash button
    1995 Supra TT, BPU+, Baltic Blue, targa, TRD front/Cusco rear strut tower bars, 98 headlights w/ 6k HIDs, 97+ front turns, BNR turbos, Tial BOV, HKS Super Drager exhaust, SSR Professor SP1 wheels, Racelogic TC, VPC/GCC
    Passport hardwired
    Subtle white LED dash backlights
  4. #3
    SF Contributing Member 87supramario's Avatar
    Join Date
    Dec 2008
    Location
    On the outside
    Posts
    2,437
    Not sure about those connectors specifically but you should find lots of early Toyotas with the same clips, and other makes that the company also supplied, like Honda and possibly Mazda from the same era as well. This is the case for even ECU clips and engine harness clips, but sometimes their pins would be different so keep an eye out for that possibility as well. Not to mention the R154 came in a variety of other makes and models as well.
    Resurrection complete. Build thread-> https://www.supraforums.com/forum/sho...surrection-1JZ
  5. Remove Advertisements
    SupraForums.com
    Advertisements
  6. #4
    SupraForums Member
    Join Date
    Oct 2013
    Location
    conyers ga
    Posts
    174
    What bitshftr said about the number being on the connector is generally true but what I have seen with older vehicles is it's not always there. I work at a dealership and I'm on vacation this week but when I get back Monday if you haven't found a number I'll look in the books and see if I can find something.
  7. #5
    SupraForums Member
    Join Date
    Oct 2013
    Location
    conyers ga
    Posts
    174
    From what I can find it looks like your numbers are 90980-10496 for the reverse lights and 90980-10432 for the ABS.
  8. #6
    Moderator
    l337 M0d3r4t0r
    ZaZZn's Avatar
    Join Date
    Feb 2002
    Location
    Age
    36
    Posts
    12,081
    Thanks so much guys for the help supposedbigfoot.
    How did you find them?
  9. #7
    Addict raysupra's Avatar
    Join Date
    Jan 2010
    Location
    NC again
    Age
    30
    Posts
    1,120
    You trying to buy some new ones from toyota? I haven't asked Dr Tweak in awhile but i know hes got the biggest stockpile of connectors :-)
    -Parker-
    1985 MKII:-2jz/R154/AEM EMS2
  10. #8
    SupraForums Member
    Join Date
    Oct 2013
    Location
    conyers ga
    Posts
    174
    I work in parts at a Toyota dealership. We have a book that is just connectors housings so I just matched the connector in your pics.
  11. #9
    Moderator
    l337 M0d3r4t0r
    ZaZZn's Avatar
    Join Date
    Feb 2002
    Location
    Age
    36
    Posts
    12,081
    yes i'm trying to buy them, I need the one for the ABS, becuase I can't find the male connector I don't know what I did with it but I misplaced mine and don't have a replacement connector and do not want to cut and use a new connector, I'd rather use the original.
    I found the reverse sensor terminal at cycleterminal.com they have just about every connector and pins to rewire everything. What turned out to be changing a few wires turned out to a complete harness revamp lol. I replaced every connector and any crusty wires. I then use non-adhesive vinyl for a wrap around the wires and then cover that with TechFlex from wirecare.
    It's looking really sharp, I just gotta finish the last 2 bits.
  12. #10
    SupraForums Member
    Join Date
    Apr 2014
    Location
    USA
    Age
    31
    Posts
    446
    I just got done stripping an 86 NA it's on it's way to becoming a drag car. If you need clips let me know as I am posting everything for sale on C list real cheap.
  13. #11
    Supra Tech Bmettie's Avatar
    Join Date
    Mar 2010
    Location
    Florida Brevard
    Age
    37
    Posts
    1,740
    https://drive.google.com/open?id=0B0...jFLTklaSGNDTmM
    Female- 90980-10432 pg 130
    Male- 90980-104336 pg 295
    Terminals - pg 326
    Female- 90980-10496 pg 78
    Male - 90980-10495 pg 261
    91 White Package Targa Turbo
  14. #12
    YotaMD.com author
    Join Date
    Sep 2007
    Location
    Arizona
    Posts
    650
    I went through this when I built my harness a few years back. Toyota has a few of them still and as earlier stated there is a part number embossed on some connectors. Many connectors are discontinued and unavailable through Toyota even if you can find that number, but they can be found through other online vendors as the actual manufacturer part. Toyota doesn't make any of the connectors (at least that I found) so you have to determine the actual manufacturer. Tyco/TE and Sumitomo seem to have made most the connectors/terminals.
    I got a lot of the info used for my build documented, but never cleaned it up enough to be presentable. It's a TON of work to track down some of them. I was never able to find the M1 connector...
    Good luck!
  15. #13
    Join Date
    Mar 2010
    Location
    Florida Brevard
    Age
    37
    Posts
    1,740
    M1 90980 -10830
    I got a new one thru toyota about a year ago. Lower left
  16. #14
    Canada, Eh? Enraged's Avatar
    Join Date
    Oct 2001
    Location
    Victoria, BC, Canada
    Age
    37
    Posts
    2,392
    yotaconnectors has some of the connectors, driftmotion has some others. Eastern Beaver sells some that look similar, the Sumitomo lines http://www.easternbeaver.com/Main/El...ed/sealed.html
    Mouser has the ECU connectors:
    ECU 52 pin:
    http://ca.mouser.com/Search/ProductD...ey571-172319-7
    Harness connectors are in the same TE AMP line, 12pin, 16pin, and 24pin IIRC
    88 Turbo, Burgandy
    Shiny makes you faster!
  17. #15
    YotaMD.com author
    Join Date
    Sep 2007
    Location
    Arizona
    Posts
    650
    Quote Originally Posted by Bmettie View Post
    M1 90980 -10830
    I can't seem to find that as a Toyota part number. Was your local dealer able to get it or did that require some digging? We are talking about the 10 pin connector in the ECU area (but not attached to the ECU), right? I can't really see anything in the pic.
    That album has some good looking harness making pics though!
    Quote Originally Posted by Enraged View Post
    ECU 52 pin:
    What?! Awesome! I'll be picking up one of those!
  18. #16
    Join Date
    Mar 2010
    Location
    Florida Brevard
    Age
    37
    Posts
    1,740
    Quote Originally Posted by suprarx7nut View Post
    Thanks, I'm very happy how the harness came out when I was complete.
    My Bad, My 91 M1 connector is an 11 pin with that PN. The earlier M1's are 10 pin like what you need and that PN is 90980-10469 pg 124 Here https://drive.google.com/open?id=0B0...jFLTklaSGNDTmM
    I got my Toyota connectors through Curt @ Elmurst. He may have had an unconventional way of finding them but he did.
    This is what I put together when I built my harness.
    https://drive.google.com/open?id=14L...dNHkepgys2jp4U
  19. #17
    Rock'n Death with Spikes! Supranaut's Avatar
    Join Date
    Jul 2004
    Location
    Land of Rape and Honey
    Age
    48
    Posts
    154
    Thats some nice info on that spreadsheet!
  20. #18
    Join Date
    Oct 2001
    Location
    Age
    37
    Posts
    2,392
    im not sure if thats the 88 or 89+ one though
  21. #19
    YotaMD.com author
    Join Date
    Sep 2007
    Location
    Arizona
    Posts
    650
    Thanks for the number! Unfortunately a quick google search leads to a thread with Curt on here saying they're discontinued and not in the system anymore. Oh well.
    Nice info, that's awesome. One of my "eventually" projects is to create a solid info database for wiring the mk3 engine harness (7MGTE). It's a lot of work to track down all the various terminals and connectors.
    For $20, that's a worthwhile gamble for me! I'd love to make a good patch harness to use with piggybacks that doesn't require hacking the factory harness.
  22. #20
    Join Date
    Oct 2001
    Location
    Age
    37
    Posts
    2,392
    Found another one: https://www.efihardware.com/products...ota-Connectors
    If you have plugs but need to repin everything with new wire, this would be helpful: https://www.efihardware.com/products...-EFI-Pin-Kit-1
+ Reply to Thread
Quick Reply Quick Reply
Register Now
List your Car(s)
Where you live
Log-in
Similar Threads
  1. Finding gasket part numbers
    By jdmmr2guy in forum MKIV (1993-1998)
    Last Post: 05-11-2015, 12:24 AM
  2. Hey Curt, need help finding MKIII IC part numbers
    By smartguy54321 in forum Elmhurst Toyota Scion
    Last Post: 05-04-2015, 09:21 AM
  3. Part Numbers for electrical connectors?
    By 808steeze in forum 1JZ/2JZ Swap
    Last Post: 06-11-2012, 02:59 PM
  4. MK3 Supra Euro Part numbers and price quote
    By Trishool in forum Elmhurst Toyota Scion
    Last Post: 01-19-2011, 08:10 AM
Posting Permissions
  • You may post replies
  • You may not edit your posts
