S
Supra_Showgirl
·Guest
I've been browsing the internet lately, looking at potential purchases. I am new to car audio, so I am taking my time trying to absorb as much information as possible before diving in and investing in car audio components. I am not the familiar with brands other than the typical Sony and Panasonic that everyone has heard of.
I recently came accross Volfenhag subwoofers, from Germany, I assume. They're quite an attractive woofer, I must admit. But, are they any good? Below are the specs that came up on one site (for 12"). They seem to have everything I am looking for, including 4 - ohm dual voice coils. Is the brand reliable? Should I invest? I am not necessarily looking to compete as of now, but are these good quality subwoofers? I appreciate your response; if you have personal experience with Volfenhag, I would love to hear about it. If they suck, why? What other name do you suggest, then? Thanks for EVERYthing!
Jade Estrada
Volfenhag ®
12" 1000watt DVC Cast Aluminum Subwoofer "The German Concept"
*1000 Watt, 12" Dual Voice Coil Subwoofer
*500 Watts Continuous
*1000 Watts Max
*4 Ohm Per Coil
*Efficiency: 89.5dB 1W/1M
*Cast Aluminum Basket
*Dual 4 Ohm Voice Coils for 2, 4 or 8ohm operation
*Bumped & Vented T-Yoke
*High Temperature 4-Layer Voice Coil
*Double Damper
*Heavy Duty Industrial Magnet Structure
*Gold Push-Type Terminal Posts
*Protected/Shielded Tinsel Lead for Improved Excursion Ability
*Ships In Custom Designed "Treasure Chest" Packaging
*6.3" Mounting Depth
*Fs: 30Hz,
*Qts:0.526
*Vas: 1.98 cu. ft.
*Qes 0.614,
*Qms: 7.698
Jade Estrada
Volfenhag ®
*1000 Watts Max
*4 Ohm Per Coil
*Double Damper
*Fs: 30Hz,
*Qts:0.526
*Vas: 1.98 cu. ft.
*Qes 0.614,
*Qms: 7.698
