1 - 8 of 8 Posts
Does anybody actually know if this actually works? I found a MR2 spyder steering wheel on ebay without the airbag. And I have a guy locally that has a Celica GTS Airbag do you guys know if it will work? According to Curt they have different part numbers, making them different? Does anybody know by experience.
A right, not a privilege
My experience is that if Curt says something... that's the way it is.
Luvs ( . ) ( . )s
I installed a 2k celica gts wheel+ab it works. Only thing that dont work is the CC switch, so prepare to drive the car without cc. The wheel bolts right in you have to modify the plug to the clockspring a bit to get the horn to work and then you get the ab adapter from curt and your set.
Luvs ( . ) ( . )s
Should be the same thing, they might have different PNs cause of different materials maybe? Other than that I would try to find a leather 2k celica gts wheel.
1 - 8 of 8 Posts
