This is for a 2001 Corolla S w/electric windows + power door locks...
I am looking for the multi-switch panel for the door locks and windows from the driver's side front door. From what I can tell, the "cover" and the switches themselves are all one piece. Don't need the wiring harness that goes into the door.
Also, got kind of a side-question here that belongs in tech but I don't want to make 2 separate threads. The outside door handle does not work. I took the door cover off and it looks like a little piece of plastic snapped in half thus disconnecting the door handle from the actuator rod assembly. I don't know if I need to buy a new door handle and that little piece is part of the door handle that then slides into the eye of the metal rod or if I need to buy the whole rod assembly.
Here is the right-side up picture of what I see thru the opening by the door latch.
Circled in yellow is what the broken piece looks like (body color, similar thickness) and circled in red is the actual broken piece. You can't see it in the right-side up picture because the metal actuator rod is in the way when trying to take the picture.
I'd like to come pick these up tomorrow afternoon.
