1 - 9 of 9 Posts
VIN: 5TBRN34171S191811
2001 Tundra extended cab 2x4, 3.4l v6, auto
Could you please quote the following;
Drivers side mirror assy.
Drivers side latch assy. for extended cab window
LH & RH brackets which attach to the rear bumper bar on one end and the frame of the truck on the other end
Front oxygen sensor
Thanks,
Front oxygen sensor
Thanks,
Drivers side mirror assy. 87940-0C040 $133.72
Drivers side latch assy. for extended cab window 62920-34012-B0 $22.10
LH & RH brackets which attach to the rear bumper bar on one end and the frame of the truck on the other end 52016-0C010 & 52015-0C010 $50.59 ea.
Front oxygen sensor **By VIN it shows to be an air fuel sensor, not an O2**
89467-34021 $147.85
all in stock except the qtr. glass latch, quote # Q539251
After speaking to you on the phone, I checked the air fuel sensor and did confirm that the part number you listed matches what I now have on the truck.
Thanks,
Richard
Discussion Starter #9
Could you quote front rotors and brake pads and any other items that would be needed for a front brake replacement for this truck? Also, if the parts are in stock I will be in Houston tomorrow afternoon/evening and would like to just pick them up. How late do you guys work on Sat.?
Thanks,
1 - 9 of 9 Posts
