1 - 12 of 12 Posts
open up the sc430 carrier assembly. Check to make sure the ring gear has the same 10 bolt pattern. If it does, then you can. I would assume you can put it in either assembly, since the 00 gs400 carrier is the same size as the auto tt carrier.
Super Moderator
I have no experience of any kind with SC430's. Let us know what happens, it'd be good info to add to the differential sticky if it turns out that it works.
Super Moderator
The sc430 3.266 diff works! I took my lsd out of my factory auto TT 3.7 rear and went right in the 3.266.
Did the SC430 pumpkin/carrier bolt up into your Supra's subframe?
So. We just tried this and a Torsen LSD from a TT Auto does not fit in a 2005 SC430 3.266 Open Differential and the axel flange is too small as well.
@Egoguy, what year sc430 did you get the diff out of?
249404
249405
Okay, so this is from a 6spd 🤦‍♂️🤦‍♂️🤦‍♂️🤦‍♂️🤦‍♂️ and not auto. Any suggestions, or source a TT Torsen?
1 - 12 of 12 Posts
