1 - 20 of 25 Posts
Is it normal for the supra to consume 1/4 tank of gas starting from full after 8 runs up to 120 mph? The 120 mph was only sustained for 5 seconds each tme.
Savage Member
Sounds like mine.. I have 550 injectors.. you?
Ludicrous speed! GO!
I would assume that the supra drinks pretty hefty when driven hard, especially since its the turbo.
Hardtop FTW
I used more than that at the track the other night. 7 runs to 100mph took just over 1/4 tank.
Hardtop FTW
bandwagonpilot said:
You shouldn't race on a full tank anyways ^_^
:tongue:
you think that is bad
try pushing 832 lph and see how fast that fuel level goes down ;)
Supranian
What kind of mpg are you guys getting on running 550's during normal day to day driving?
your right foot determines everything
if you're boosting, you're guzzling fuel, more boost = more fuel
be thankful you don't have an engine that consumes that much air and fuel at all times...
Discussion Starter · #13 ·
I have the stock injectors and I'm running 15 psi. Didn't think the gas mileage would be this horrible on WOT though. lol.
My friend's accord raced his engine about the same amount of time/duration, but he only lost a notch on the gas gauge. This makes me jealous, but then again boost is to DIE FOR! haha.
With stock inj, I could eat up 1/4 on the lower end of the tank with those pulls but not the top end. From a full tank, it takes me a while to do 1/4 even with 550s.
RoastBeefCurtain Commando
racing around in boost will kill gas quick. Esp if you are making power.
Learn to live with it. Thats why I dont DD my Supra
thats about right...depending on your fuel setup and how much boost your running..
adrian
1.5JZ Turbo Supra
If i'm wrong please correct me but,
if at the drag strip running 8 runs up to 120 mph with 5 seconds tops on a full tank eat 1/4 of a tank.
if you had a 1/4 of a tank to begin with and did the same 8 runs up to 120 mph with 5 seconds tops @ 120 wouldn't you use less fuel seeing you don't have 18 gallons of gas to weight you down.
as a rough estimate if 18 gallons weights 144LB's that .1 added to your overal 1/4 mile time + added weight.
so if 4.5 gal. (1/4 tank) weights 36lb's thats .1 taken off your 1/4 time + saved weight wouldn't it some what of a gas saver? I don't know just an idea.
Each gallon @ 8lb's roughly just as an estimate could be more could be less....
1.5JZ Turbo Supra
mustangman05 said:
whoa wait a minite this got real technical real fast ^^^^
hahah not really just something to think about. Only took 2 minutes to type :)
1 - 20 of 25 Posts
