1 - 17 of 17 Posts
With dual pumps such as Walbro's or the stockers, 1000rwhp is kind of pushing it but I'd say 950rwhp safely!
The Hustler
I have seen people make 1000rwhp on 1000cc injectors, but I wouldn't really want to max them out. I just went with 1600s in mine.
Super Moderator
James,
With two OEM pumps, I ran out of injector at 1,031 whp. Rsky, who recently made 1006 whp ran out a bit earlier with one OEM pump and another brand I can't recall and Jim Swantko made 1,028 whp with six 1000 cc injectors (can't recall his fuel pump set-up). Both Rsky and I now run eight 1000 cc injectors which provide a bit more headroom if needed.
Ken.
The Hustler
KenHenderson said:
James,
Ken.
Ken, why not just go with a bigger injector? Whats the benefit to running 8 smaller ones?
the two additional injectors only come on under boost therefore making lower duty cycle tuning more effictive... saving small amounts of gas...and overall a better idling better performing vehicle
lotsa street/strip cars are setup this way
Super Moderator
Actually, my eight 1000 cc injectors are driven full-time by my F-CON V-Pro. They are Densos which I believe to be the best 1000 cc injectors available, especially as it relates to idle quality. Keep in mind, my car is a totally street car and has never been drag raced. Idle quality, part-throttle, steady-state cruise and overall fuel economy are still important in the scheme of things and I have never seen a 1600 cc equipped car acquit itself well on the street. The 1600 cc street cars I have seen at SILV have all had idles at 2000 rpm or higher.
Now, I understand AEM has a new injector driver that handles this problem, but I think my set-up in terms of overall tractability and the ability to make big power is difficult, if not impossible to match for a 1600 cc car. I mean, I got 24 mpg on the way to Vegas last year at a steady 80-85 mph. Again, my car is a 100% street car that occasionally participates in bike racing and LSR activities. For guys that want to go 9s regularly, a 1600 cc set-up may be the way to go.
Yes, there are formulas that indicate how much power you can expect at 43 psi and 80% duty cycle with an assumed BSFC. Alter static fuel pressure just a bit and hone in on your actual BSFC and those formulas go out the window. Hope this helps.
Ken.
I made 1028 rwhp on 1000's - a 3rd pump would be a safer way to push without having to change the injectors.
1,150+ rwhp club
Discussion Starter · #12 ·
How are you plumbing the 3rd pump in assuming your running 2 feeds and 1 return?
3 pumps combine in the hanger, -10 feed to a Y-block feeding both ends of the rail. Single return from FPR.
Ken, I read in your other posts that you always run race gas. How do you make it to Vegas?
I'll update this thread in a few weeks with results because I will have twin densos supplying 6 x 1200cc's with -6 lines and a -10 rail. I wouldn't trust my weedwacker on a walbro pump.
Woon likes the set-up.
FUEL:
1600cc injectors
WOTM -10 fuel rail
WOTM CNC billet fuel hanger
Walbro Pumps (3)
Weldon regulator
SX fuel filter
Why do you not like Walbro when I see alot of other members have great performance from them?
Super Moderator
Vegas is a tad over 250-miles from where I live and I have no problems getting there on about 3/4 tank of gas, even less if I focus exclusively on maximizing my fuel mileage.
Ken.
1 - 17 of 17 Posts
